#113 |
Just reached out to my Dealer connect to see if I can assist with this build for you.
#114 | |
Drives: 13 SWP BRZ
#115 | |
Drives: 2020 BRZ Sport Tech RS
#116 | |
Drives: 2015 FR-S
Our engines are actually symmetrical with the starter relief already available on both sides. I think this is because they want to start off with the same block half as other FA20/24 engines and CNC differently depending on model. This makes sense in the whole Subaru global platform thing. Mounting our Bellhousing onto FA20DIT or FA24DIT would only require us omit one stud circled in red. Would this matter for strength/rigidity? probably not in the short/intermediate term. That leaves machining the bell housing which can be done at a CNC/machine shop. There's enough room without upsetting the slave cylinder mounting, but will need some cad work but not too hard. Mount points for the starter already exists on the opposite side but you do need to shave down or "deck" themount points a bit to get the starter in the right depth. This can be done in the same subtraction process of the bell housing relief. The brz starter might even be mounted on the other end, its still rotating in the same direction. Just need to look at clearances a bit. 2013-2022 MT Bellhousings are the same parts so you can even use 2022 beefy transmission instead of fitting CD009 if power levels aren't ridiculous. plenty of free bellhousings laying around. What other problems do you guys foresee? would like some community inputs THIS IS NOT WORTH THE TROUBLE for an Accent motor or even 2022 WRX...This is only worthwhile for the STI FA24 motor which should be even stronger then the 86 FA24. Won't know or even get one for another 1.5 years. |
| The Following User Says Thank You to FrickingReallySlow For This Useful Post: | Tatsu333 (12-16-2021) |
#117 | |
Drives: None
Someone got ahold of one, copying the translation / images here since Facebook
https://www.facebook.com/permalink.p...24654421103670 Quote:
#118 | |
The trigger wheel for the crankshaft sensor could be an issue. I wonder how it "doesn't fit" - are they trying to fit the FA20D's trigger wheel to it? Is the tooth pattern different, or the diameter, or...? Is there a reason the FA24's trigger wheel can't be used? Could be that a custom one would need to be machined... EDIT: just looked up some pictures, and I guess the trigger wheel is a pretty convoluted stamped steel piece. Might be hard to replicate. Maybe it would be necessary to use the FA24's trigger wheel and sensor, and THAT makes it difficult to adapt to the 2017 ECU? EDIT #2: Looking at this thread RE: swapping a 2017+ MT (red aluminum intake manifold) motor into a 2013-2016 car, maybe the issue between the FA24D and 2017+ FA20D is similar - the signal from the crank position sensor to the ECU is different enough that they're incompatible (E.G. one is reading high when the other reads low?). This post specifically says that a Subaru tech told him the 2017+ AT (plastic manifold) motors don't need to swap the trigger wheel and sensor, but the MT (aluminum manifold) motors do (which makes sense because the AT motors were a carryover). If that's the case, then it would seem it will be necessary to somehow make the 2017 trigger wheel and sensor work to use the 2017 ECU. I'm also curious about the motor mounts, since they don't mention anything about them as an issue, though Subaru's info on the 2nd gen said something about the mounts being moved. Interested to see where this goes! I've "Liked" their page on Facebook, so hopefully we'll see updates.
#119 |
Drives: 2013' Toyota 86 (EU spec)
Anybody already knows about the weight difference of the shortblock only and/or complete engine with accessoires between FA20 and FA24?
#120 | |
Drives: Crapcan
I don't see why they couldn't modify the FA20 trigger wheel to work or have one made that will work. solidsnake11 used the FA20 trigger wheel and crank position sensor when he made his K swap run on the OEM twin ECU.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Tatsu333 (12-29-2021), Ultramaroon (12-27-2021) |
#121 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Interesting to see the work being done on a hybrid. With how difficult FA20 cores are to get this is very viable.
Trigger wheel for the crankshaft is not a big deal, machining one to fit is no big deal using a BRZ core. The 2017/2013-2016 is around the cam tooth pattern. On the older cars they are one way and the 17+ and DIT models it is the opposite (male/female) so the ECU will have an inverse shape and thus not work. But if you're using cam phasers from whichever generation you're working with it should be a non-issue. The bigger issue to me looks to be the piston design. Those valve cutouts don't look nearly big enough for the FA20 but hard to say 100% from the pictures alone. As for the FA20 heads, we had them flow tested a good bit ago (http://www.moto-east.com/main/fa20-h...vs-ported-wrx/) and the FA20 flows more than you'll generally need for most setups. I don't see any issue with the bigger displacement motor. Quote:
| The Following 7 Users Say Thank You to Xero-Limit For This Useful Post: | BrahmaBull1990 (01-02-2022), DustinS (12-29-2021), FunnyGopher (01-02-2022), Lantanafrs2 (12-28-2021), NoHaveMSG (12-28-2021), PulsarBeeerz (12-28-2021), Tatsu333 (12-29-2021) |
#122 |
I am watching this thread. Rather go Hybrid FA20/24 block then a K swap when my current FA20 is done
2013 Series 10 FRS #553
#123 | |
Road-hole
Drives: 2013 Whiteout FR-S
Me too...
Jaden Who wouldn't like to have a brand new short block with 30% more displacement for practically nothing other than a little elbow grease? p.s. you're in Mo Valley? I used to be the IT director for Moss bros. It's where I got my FRS... Last edited by Jaden; 01-01-2022 at 01:49 AM. |
#124 | |
Drives: None
I mulled it over a few weeks ago and ended up buying a Jack's Transmission. The real "solution" would be someone making a bell housing and rear trans mount that doesn't require welding (due to rulebook restrictions) to adapt a T5 or TKX to a FA.
#125 |
Drives: Crapcan
It is going to be nowhere near that easy, even at it's easiest.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | PulsarBeeerz (01-03-2022) |
#126 |
Drives: 2015 FR-S
Check out the savage geese video they specifically mentioned this as well as other improvements in the gen2 trans when talking to their engineers. but yeah gen1 trans are now so cheap you can get 10 of those for the price of a new gen2
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 11:18 AM |
| FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 09:27 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 11:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 04:59 PM |
| Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 01:33 AM |
