Old 08-01-2021, 08:55 AM   #113
Kaotic Lazagna
Drives: GR Corolla
Maybe - or the wire from the button to the chime is bad/broken.
If it's any of the wires, then that's gonna suck.
Old 08-01-2021, 11:43 AM   #114
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Kaotic Lazagna View Post
Hey guys, need some troubleshooting help. Our doorbell stopped working, specifically the chime. The doorbell button works. It's a Nest doorbell, and I'm still getting video as well as notifications. Put the multi-meter to the original transformer, and it read ~17 volts. So I'm guessing it's okay (got a 16V 30vA transformer thinking the original one died). When I put the multi-meter on the chime and had someone press the doorbell button, the voltage only read 1-2 volts. Does that mean the chime is bad?
Lots of issues lately with everyone converting to video doorbells
I just had a customer a few months ago with a nest doorbell that wouldn't activate their mechanical doorbell as well. Taking off the nest, I could touch the wires together and make the doorbell work(this is what the doorbell button does in a safer mechanical method, also the best way to test for operation), but despite all the configuration settings within the nest app being correct for a mechanical doorbell, I couldn't get it to work.
Yes, you need the 16v 30va transformer size for a video doorbell. Most are 10-15va, and it will burn out given half a chance installing a video doorbell. It was actually part of Rings official response when I called them after burning out 3 ring units at another customer house in 1 month... They asked if I changed the transformer size as it was required, despite nothing in any literature in the box or online stating that...
My suggestion to you as it was to the customer I had with the nest doorbell is to contact nest about it, after you take the nest off and touch the 2 wires together to verify the chime operates correctly. I haven't been back to that house since, so I don't know if they resolved it...
Ring includes a little 'power pack' module that gets wired into the chime to help everything work that nest doesn't
Old 08-01-2021, 11:45 AM   #115
soundman98
soundman98's Avatar
Nah, if that was the case, the nest wouldn't work.
Old 08-01-2021, 01:31 PM   #116
Kaotic Lazagna
Drives: GR Corolla
I forgot to mention that we had this issue prior to installing the Nest Hello doorbell. I actually replaced the chime then. Things worked again. Installed the Nest Hello, and things remained working up until a week or two ago.
The Nest Hello has a chime connector module, could that be affecting anything? I get the same 2 volts or so reading at the wires connecting to that module from the house.
Last edited by Kaotic Lazagna; 08-01-2021 at 03:13 PM. Reason: Edit: not a power module
Old 08-01-2021, 03:10 PM   #117
Kaotic Lazagna
Drives: GR Corolla
I popped off the Nest Hello and took the multi-meter to the set screws. It gave a 16-17v reading. Didn't try removing the wires and touching them together tho.
Old 08-01-2021, 04:09 PM   #118
soundman98
soundman98's Avatar
I'm not familiar with that module. Best recommendation is to take off the module and check the doorbell for standard/typical operation, and then work the new parts back in
Old 08-08-2021, 03:01 PM   #119
soundman98
soundman98's Avatar
yup, my garage workbench is now nicer than my kitchen.
old setup-- they were 50-ish year old spec-grade cabinets that i had gotten overly-enthusiastic on project yanking and cranking a few months ago and managed to pull the cabinet backs away from the wall. they were held onto the wall then with only about 6 trim nails.
planning
electrical, the easy part
final layout
i set up for a 1/2-switched outlet in the cabinet, and will be doing some led undercabinet lights for the working surface, whenever i get the motivation to deal with it.
Old 09-06-2021, 03:39 PM   #120
Jacky Smith
Jacky Smith's Avatar
Drives: Subaru
The other day ordered a security camera to watch what is going on around my house when I am not at home. Also I read a lot of such articles on recfaces to be in the know of what is going on in this industry.
Jacky Smith is offline   Reply With Quote
Old 09-06-2021, 08:43 PM   #121
Kaotic Lazagna
Drives: GR Corolla
Well, update on my doorbell situation. After a few people telling me it won't be the transformer that's causing my issue, I went ahead and got a new chime. Didn't work. Found and ordered a new Nest Chime Connector. Didn't work. Got fed up and installed the transformer I got before replacing everything else. Chime works!
Old 09-06-2021, 09:56 PM   #122
soundman98
soundman98's Avatar
interesting, so the old nest chime connector works fine, the lower power transformer was what was preventing everything from working?
Old 09-06-2021, 10:48 PM   #123
Kaotic Lazagna
Drives: GR Corolla
I didn't check the original Chime Connector with the new transformer. I had other stuff to do, so I just wanted to get it over with. I'm guessing it still works. I kept it as a back up. LOL. Had the new Chime Connector solved the issue, I was going to cut up the original one to see if the fuse inside blew (it's a solder on/SMD kind).
I honestly don't know what's wrong with the original transformer. It was giving me a 16/17v reading on the set screws on it, as well as at the wires right before the Chime Connector. Same with the new one. Oh well. haha
Old 09-06-2021, 10:59 PM   #124
cjd
cjd's Avatar
Drives: 2017 BRZ
Today: tearing out failing grout from the shower. Plan to let it sit for a week before I try my hand at regrouting... Maybe get a little more time before having to tear the whole shower out and have a new one made. Signs of shoddy work but so far nothing points to a mold problem or leaking...
Old 09-07-2021, 08:03 AM   #125
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Last shower I had torn out had a window in it facing the backyard. Workers started on the demo when I went to work. When I came home, about 15 feet of wall was gone. It's amazing how much damage a little leak can do over the years.
Old 09-07-2021, 09:09 AM   #126
cjd
cjd's Avatar
Drives: 2017 BRZ
I know. It's question of not using the shower till we can gut/replace or good 'nuff. Only signs of water were outside the shower pan where wood baseboard was run up right against the tile, hinge side of the door. It'll be a mess when we get there I am sure. Finding quality contractors right now...
diy, home, living
Brought my BRZ home today Smokinbuffalo Northwest 8 05-31-2012 11:49 PM
WRB-Got it home!!! jaytaurus BRZ First-Gen (2012+) — General Topics 28 05-29-2012 11:33 AM
#64 brought home today. FujiwaraTofuShop Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 09:04 AM
