Old 06-24-2011, 02:57 AM   #113
serialk11r
Drives: '06 AM V8V Coupe
Okay completely hijacking my own thread, but I kinda want to see what effect charge cooling has. Okay on the compression stroke assuming 12:1 compression would be, about 1atm*V(12^-0.3-1)/-0.3=1.75 atm * V or actually in terms of temperature is better so 1.75 nRT. So for each mole air (let's just say, 20% O2 molecule 80% N2, they have similar atomic weights so this approximation should be fine), we are adding 1.75*8.31J/molK * 300K (let's say it's a nice day out) = 4.36kJ. This is probably way too low since heat ratio drops at higher pressure. I wouldn't be surprised if it were more like 10kJ.
Okay we need 2/3 of 20% of methanol, which I'll just call 1/8. 1/8 mol methanol takes 35/8 or about 4.3 kJ to vaporize Okay obviously there's a huge problem since towards the end of the compression stroke the pressure is very high and the temperature shoots up a lot more than that. But we can see that methanol provides extremely significant charge cooling. Theoretically methanol could cut the compression stroke power loss by a huge percentage.
Yea one day I am going to definitely have to try tweaking a car to run on methanol. Hippies be damned about toxicity.
Old 06-26-2011, 07:00 AM   #114
bigbcraig
Drives: 2013 BRZ / 2015 WRX
Good luck with methanol...
It's an awesome fuel but also an awesome oxidizer, and it's expensive to replace your fuel system every few months
It's actually used pretty often in dragsters and the like, but there are huge problems with corrosion there and they basically purge the methanol fully out of the system after every raceday.
(Technically, methanol itself isn't very corrosive but the contaminants it loves to dissolve, for instance chloride ions, are essentially always in with your fuel and are extremely good at galvanic reactions)
It's also very hygroscopic which is inconvenient.
And, as you mentioned, toxic.
bigbcraig is offline   Reply With Quote
Old 06-27-2011, 05:58 PM   #115
Allch Chcar
Drives: N/A
Originally Posted by serialk11r View Post
Crap I typed a bunch of calculations and lost it all somehow. :mad:
Okay so you need twice as much methanol as ethanol to get stoichiometric. Okay so after factoring in the fact that we burn gaseous fuel in engines, methanol comes out to make about 750kJ/mol, 1500kJ/2mol. Ethanol makes about 1370kJ/2mol. The greater cooling effect (32kJ/mol approximately) helps make more power by reducing the work on the compression stroke. At full throttle there's going to be waste pressure anyways, thus the cooling effect isn't actually taking much away from the amount of energy we can get. So methanol looks like it makes about 10% probably a little less more power than ethanol, which looks like it makes about the same power as gas. Good stuff.
Methanol takes twice the fuel volume of Gasoline not Ethanol. It's actually somewhere near 60-80% more fuel but some people don't like to dice numbers. And when you're talking about power look at the rich mixture not just Stoich. Methanol and Ethanol run better a bit richer than Gasoline only looking at the numbers.
Heh. Pretty much. Ethanol isn't as corrosive as Methanol and it's even less corrosive mixed with Gasoline. E85 at least, is more fuel system friendly and probably cheaper/easier to find compatible parts. Even if it means less power.
Although for racing you pretty much have to stick with DIY blending no matter what fuel you use.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-29-2011, 12:05 AM   #116
Streetice
Local Nut...
Streetice's Avatar
Drives: Soon FR-S
I am up for advancement in cars 100% and that gose for all ends.
If you building a car for the future make it for the future, im so sick of this retro fad and the over done eco class, and what drives me up te wall the most is the in betweener car. No good for looks, power, tech, usage all of it. The no try fail from top to rock bottom just gets me.
Lines are a must when building a car, if you design a car that looks like the smart car and expect it to take the world over then crawl in a cave wrap your head in tin foil and hope the aliens dont find because your freeking nuts!
Were as fuel sets its very hard for me to give up that godly sound gas puts out but I will take an electric if it can do 0 to 60 in 5.0 and gose 700+ miles before needing a charge. If they build there battery like my cell phone ill be lucky to get home from work!
With all that said if they can make something as good as E85 but with less power loss from pump gas ill take it because gas prices and my lead foot are not making nice anytime soon my fellow speed demons.
Streetice is offline   Reply With Quote
Old 08-29-2011, 12:55 PM   #117
Allch Chcar
Drives: N/A
Unrealistic, you can't get that from a single Gasser now.
And there is no "power loss", it has less BTU per gallon which is heat energy, you mean MPG right?
-Allch Chcar
Old 08-29-2011, 07:02 PM   #118
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
I truely believe E85 and Ethanol is the future. Just look at the bio-ethanol reactor technology, not to mention renewable energy from sugar cane.
I'm all for electric cars, but both batteries and hybrids put me off lol! Not to mention costs. I think we can expect more and more small turbo engines, the Europeans are there, the Japanese are starting to catch on.
Type[R]+ is offline   Reply With Quote
Old 09-01-2011, 11:54 PM   #119
The4kBeast
Old-School Toyota Nut
The4kBeast's Avatar
Drives: '91 MR2 Turbo, '85 MR2, '83 Starlet
Variable timing -> Gasoline Direct Injection -> Smaller displacement engines -> Turbos -> Even smaller displacement engines -> Variable compression -> acticellary electric assists powered by regenerative braking, using very small and light batteries -> hydrogen -> Flinstone-mobile
I think I'm going to plan on hanging onto my pre-2016 hot rods... Govt regulations are going to ruin it for us all.
The4kBeast is offline   Reply With Quote
Need Help Picking rims for my future is200 Calais Other Vehicles & General Automotive Discussions 30 06-03-2011 12:42 PM
Who has future plans to molest their FT-86? (examples inside) SOB Scion FR-S / Toyota 86 GT86 General Forum 132 05-03-2011 09:33 PM
AE86 production numbers vs future? EJ20 Scion FR-S / Toyota 86 GT86 General Forum 84 03-24-2011 05:21 PM
FT-86 Future Said to may include hybrid ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 47 03-14-2011 09:40 PM
Edmunds Inside Line talks future Vehicles e10rice Scion FR-S / Toyota 86 GT86 General Forum 7 06-10-2010 01:22 PM
