#113 |
Drives: 16' BRZ
Probably against my better judgement but I've decided to drive the car across the country. I'll be leaving from Maryland on the 24th. My route is the following
Richmond<Athens<New Orleans<Dallas<Albuquerque, then Sedona with my wife for the last leg of the drive. If anyone is along this route and wants to checkout the car just let me know and I'll see if we can coordinate. This will be my first time driving across the country and I'm kind of looking forward to it. Something I've always wanted to do in the back of my head but never got the chance. Surprisingly, I'm less worried about having trouble with car and I'm more worried about speeding tickets. I'm good for the first 4 to 5 hours after that my right foot starts to get heavier. Brady will have put several hundred miles on the car before pick up and I no longer consider it a "tuner car" we'll see, I'm sure there will be growing pains. If anyone has suggestions for fun driving/karting related things to do on my route please chime in. Or just cool places to see or must stop places to eat. So far I'm thinking of checking out Sim Seats in Richmond and see if they'll let me try out some of their 40K racing sims. Also considering stoping at the Porsche Driving Experience in Atlanta for a little bit of fun... |
#114 | |
#115 |
My buddies Corvette is going to be 600+ hp and toque basically everywhere... and it will weigh the same as my brz.
#116 |
Drives: 14 BSP Edelbrock BRZ
#117 | |
#118 |
Drives: '17 BRZ M6 & '17 Corvette Z06 M7
I know you're wanting more of an AutoX setup, but would you have room to run a pair of turbos if you wanted to? I'm currently debating the 2JZ single turbo vs LS3 motor swap, but I really am addicted to the power curve that turbocharging brings and would love to have that flexibility to add a pair of turbos to push the LS to 700+
#119 | |
Drives: 16' BRZ
#120 |
Drives: 16' BRZ
Car has been weighed...
According to my calculations she has gained 121 lbs over stock. What a fat pig she has become. Oh well, eventually she will be put on a diet. I think all of the torque should make up for it in the meantime! The big plus is the front to rear weight distribution remained practically unchanged from factory at 56.2% front and 43.8% rear. I believe factory is 56-44. Don't think I'll notice .2% Car weighed 2979 lbs with a full interior, spare, tools and a full tank of fuel. Minus 2776 for a stock brz and 82 lbs for 13 gallons of fuel, I came up with the number 121 lbs gained which sounds about right. Please feel free to chime in if you think I'm mistaken. For reference my Jackson Racing supercharger weighed 66 lbs when it was boxed and ready to ship. My Edelbrock kit was 99 lbs shipping weight. So to sum things up I'm pretty happy with the weight gain compared to FI. And I'm very happy that weight distribution remains practically unchanged front to rear. |
The Following 5 Users Say Thank You to GrabTheWheel For This Useful Post: | Dadhawk (04-15-2019), DustinS (04-15-2019), Irace86.2.0 (04-15-2019), Sportsguy83 (04-15-2019), strmshadow84 (04-15-2019) |
#121 |
Drives: 2JZ FRS
the nice part is we have a 50% cross weight without driver and got it to 49.6% with a 225lb driver without having the car sit at awkward heights on each corner from balancing.
The Following 2 Users Say Thank You to spitfire481 For This Useful Post: |
#122 |
Drives: 16' BRZ
For those of you who think LS swaps are cheap and simple. Sure they can be but if you get all new parts and go the extra mile with things like MoTeC and AC it's far from it. Sure there are a few things on here that aren't related to the swap but I'm sure there's a few I've forgotten as well.
It has given me more respect for very clean swaps like the Flyin Miata LS builds. My hope is that the BRZ turns out to be a better platform for an LS swap compared to the Miata because of the slightly longer wheel base among other things. I am confident that the car Pure has built for me will far exceed what Flyin Miata has produced. I will let everyone know very soon... Build Parts List: Motec M130 ECU OEM Alternator Bracket OEM AC Compressor Callies Compstar H Beam Connecting Rods Diamond Racing Pistons, Custom Spec LS3 11:1 Flat Top Comp Cams Camshaft (Custom Spec) Timing Set And Gears LS To T56 Magnum Bell Housing T56 Magnum 2.66 First Gear Vorslag LS To BRZ Trans and Engine Mount Kit Radium MC Brace Radium LS3 Fuel Rails Whiteline Front and Rear Bars ID1050X Injector Dynamics DSS 600HP Axles Radium Surge Tank With 2 Walhbro 450 Pumps CX Racing LS Swap Headers For BRZ LS Swap Radiator Hose Kit MSD Custom Length Ignition Wire Set SPAL 12" HP Slim Fans LS3 Engine Aseembly, Long Block 6.2L Aluminum Comp Cams Max-Lift BSR Shaft Rocker Kit Chevy LS3 Comp Cams Dual Spring Kit With Retainers And Keepers Setrab 25 Row Series 9 Oil Cooler Core M22 Adapter For Top Of Oil Cooler Improved Racing LS2 Oil Pan With Baffle, Pickup, Dip Stick And Windage Tray Mantic Twin Disc Clutch Kit Ethanol Content Sensor With Fittings Coolant Temp Sensor Alternator ACDelco OEM New TR55 Spark Plugs NGK Water Pump Gasket Idler Pulley Harmonic Balancer OEM Exhaust Manifold Gasket Water Pump OEM Cam Position Sensor OS Giken Differential 3.73 Ring and Pinion GM Throttle Body For Swap OEM Starter 3" Tips Stainless Steel QTP Screamer Muffler, Integrated Cutout Improved Racing Oil Cooler Adapter Short Shifter Adapter, Tremec Clutch Pilot Bushing 2x Resonators, 2.5" Piping, 3.5" Piping, 02 Bungs, Misc Supplies AC Compressor Adapter Billet Driveshaft, Custom Length Raceseng Circuit Sphere 150 Shifter AC Belt, Stretch Fit Serpentine Belt K&N Air Filter Alternator And Starter Power Cable -8AN Fittings For Oil Cooler Adapters For Fuel Filter Silicone Adapter For Water Pump Custom Length, High Strength Trend Pushrods ARP Main Studs Crane Rocker Shims King Racing Rod and Main Bearings, Custom Spec Front and Rear Seals, Front Cover Seal Johnson High Performance Race Linkbar Lifters Melling High Volume Oil Pump Last edited by GrabTheWheel; 09-01-2019 at 04:18 PM. |
The Following User Says Thank You to GrabTheWheel For This Useful Post: | spitsnaugle (04-18-2019) |
#123 |
Drives: Q5 + BRZ + M796
When the popo sends you to the Cali ref, and you decide to part out the car, I'll take the oil cooler.
haha, jk.
#124 | |
Drives: 16' BRZ
On top of all that I am fully prepared to go full race car with it. Would like to enjoy as a street car for a couple years first though. Maybe I am just lucky but I've NEVER had a cop ask me to pop my hood. I avoid things like loud exhausts, tinted windows, big wings, excessive camber, widebody etc. So I tend not to get pulled over in the first place. Cops by me hangout in town looking for people speeding in highly populated areas. Pretty simple don't speed around town and just enjoy the canyons, autoX and track instead. No street racing or "take overs" for me. I guess I'll be missing all the fun of the "car scene." |
The Following User Says Thank You to GrabTheWheel For This Useful Post: | Irace86.2.0 (04-18-2019) |
#125 | |
Drives: Broken Blue BRZ
The Following User Says Thank You to spagti For This Useful Post: | GrabTheWheel (04-18-2019) |
#126 |
Drives: 16' BRZ
I'll be with wifey at that point (picking her up in Flagstaff) but I could probably still take you for like a 15-20 min drive just wouldn't be able to hangout for too long. I've gotta be home on Saturday the 4th. Gonna try and see the Grand Canyon as well. I'll be in Sedona on Wed. and Thursday the 1st and 2nd of May.
