Old 05-31-2019, 10:41 AM   #113
Racecomp Engineering
Originally Posted by phunky.buddha View Post
Thanks Andrew! Will PM and also give you a heads up on travel days...
Will PM you soon...been in and out this week.
- Andrew
Old 06-01-2019, 12:16 AM   #114
phunky.buddha
Drives: 17 BRZ Premium
- Andrew
No prob- thanks!
phunky.buddha is offline   Reply With Quote
Old 06-06-2019, 07:38 AM   #115
Chuckls
Moutain Runner
Hey Andrew, when is the next stock coming in?
Chuckls is offline   Reply With Quote
Old 06-06-2019, 10:45 AM   #116
Hold up.
Old 06-06-2019, 10:56 AM   #117
tr_racing
We can deal directly with you...send us a PM.
- Andrew
I send you a PM
tr_racing is offline   Reply With Quote
Old 06-06-2019, 01:31 PM   #118
Originally Posted by tr_racing View Post
I send you a PM
PMed you back.
Sorry, returning from vacation and making my way through messages!
- Andrew
Old 06-07-2019, 09:52 AM   #119
Chuckls
Moutain Runner
We have a couple sets in stock.
Might want to tell FT86SF then. I got an email from them stating it was on a 6wk backorder.
So I cancelled.
Old 06-09-2019, 10:18 PM   #120
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I don't have plans to drop my car much, and probably won't drop it at all. My plan has been to replace the stock shocks with B6s and use the stock springs. I want better suspension control but do not want to have to become even more obsessive about dragging hard parts. Given those goals, would there be any point in going with something like these coilovers? Can they be set up at near oem ride heights? If so, would doing so compromise performance?
TIA
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
why? (06-10-2019)
Old 06-11-2019, 10:31 AM   #121
TIA
The tough part will be the "near OEM ride height" thing. I've run them at a range of ride heights, from too low to too high. The max you can go comfortably is about 15mm down from stock, but 20-25mm is the sweet spot.
Other than that, you can run these all day every day (and I do that on some really terrible roads). I've actually only scraped my BRZ bumper at stock height...
- Andrew
Old 06-11-2019, 10:44 AM   #122
femaledog
Drives: 2017 BRZ Perf. Pkg.
A quick update from me. I've been driving around on the street and on the track and I'm very happy with this coilover. The ride is comfortable enough for the street but you've got plenty of stiffness for when you need to go FULL SEND on a closed course.
femaledog is offline   Reply With Quote
The Following User Says Thank You to femaledog For This Useful Post:
Racecomp Engineering (06-11-2019)
Old 06-11-2019, 05:04 PM   #123
Capt Spaulding
Persona Non Grata
Thanks for the info Andrew. I'll need to give this some thought. It's not a pressing decision, so I have time. Much appreciated.
Racecomp Engineering (06-12-2019)
Old 06-12-2019, 10:02 AM   #124
No worries. Even I ran stock springs for a while on my car....it's pretty good with a few bushings and bits + a good alignment. Adding coilovers on top of that just take things another (big) step forward.
Alignment
Good wheels/tires
Whiteline rear subframe inserts
Whiteline rear diff inserts
Perrin steering lock down
Mtec shift springs
For me, that's the BRZ/FRS/GT86 starter kit and it's something you can easily build on if you want to add more later.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Capt Spaulding (06-12-2019), lamawithonel (06-20-2019), Scracho (04-24-2020), tobin (06-12-2019)
Old 06-12-2019, 12:12 PM   #125
Capt Spaulding
Persona Non Grata
Alignment
Good wheels/tires
Mtec shift springs
- Andrew
Thanks. I'm about 1/3 of the way there.
Installed:
Camber bolts
Whiteline rack bushings in lieu of Perrin Lockdown
alignment
Wheels and tires on the way
Old 06-16-2019, 10:20 PM   #126
cueball89
Drives: 15 Impreza
I now have 4 autox events, only one of those was in the dry, with these coilovers. The one dry event I did have was a champ tour sporting my well worn 225mm RE71's from street class last year. Not having a whole lot of seat time, my 2nd event of the year, I under drove and was not even close to the new limits of the car.
The following 2 events in the rain the car was a handful. I chocked it up to me not being used to the car. 12 events on my street class RE71's that had been flipped on the wheel left the outsides and now the insides pretty well smoked. I was slower than last years street class competition, I was 42/79 in pax where I used to be top 10 fairly consistently.
For today's event I had on a fresh set of 245mm RE71's while still figuring out the setup I was 2/43 in pax and raw time in the rain. I managed to hit 12 cones in 10 runs for the day. The car drove really well and was very predictable. I felt I had tons of grip the balance felt spot on to really start pushing the car. I was starting to get some nice 4 wheel slip angle out of the car. I left the shock settings on their street setting given the conditions, 65 degrees and rain.
Many of the local drivers I usually compare myself to are driving different cars this year and are in the same boat, getting accustomed to their car. While only a local event I think the result is promising. I'm excited to get some more seat time and hopefully some dry weather with the setup.
Video from the event is below. My fastest clean run which is a bit jerky and my fastest dirty run. I think the rear end stepped out a hair crossing the finish and it shoved the 2 double cones out of their boxes. Driving tips are always welcome.
[ame]https://www.youtube.com/watch?v=WY1AjjCULU8[/ame]
Edit, this video is better.
cueball89 is offline   Reply With Quote
SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos PMok Northern California 5 02-09-2015 05:26 AM
-0.5 for RaceComp Engineering wrxneffect User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-04-2014 04:21 PM
Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 12-07-2013 10:20 PM
Racecomp Engineering industrial User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-02-2013 04:17 PM
Racecomp website down? Mikepage Off-Topic Lounge [WARNING: NO POLITICS] 8 04-22-2013 03:12 PM
