#113 |
Drives: 2017 toyota 86
https://www.fensport.co.uk/products/...loy-pulley-kit
That is the full set. I already purchased these last night except i bought each peice individually bcs I wanted black coated and didn’t want crank pulley. They said belts will be back in stock ready to ship by Tuesday. |
#114 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
#115 |
#116 |
Drives: 2017 BRZ
Is the alternator under load while the car is accelerating? I've noticed that the voltage spikes when I let off the throttle.
#117 | ||
Only happy when it rains.
Drives: series.blue
| The Following User Says Thank You to why? For This Useful Post: | new2subaru (07-06-2018) |
#118 |
Drives: 2016 FR-S
#119 | |
| The Following User Says Thank You to SuperTom For This Useful Post: | why? (07-11-2018) |
#120 |
Drives: 2017 BRZ
#121 |
Curious where you put your slime kit? I tried to figure out a secure way to place it where the spare was, but ended up just wedging it behind the passenger seat.
With your shorai battery what is the longest you have gone without driving or being hooked up to the charger? After I get my pulleys in that’s prob next mod if I go that route. But sometimes I don’t drive car for days at a time. Did you ever swap out steering wheel I think stock is 7lbs? And there are roughly 3lbs ones I think? Hard to find weights on aftermarket ones. You see Anthony’s build? Anthony’s 4 steps to weight reduction. Dude went all out dropped 400lbs. His car is 22xx lbs. |
#122 | |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I have a 13 limited brz which weighs heavier than a base frs. |
#123 | |
#124 | |
The car has easily gone 5 days,started while parked in the airport no problem. Can probably go longer. I keep that cellphone looking jumper about 1lb in the glovebox just in case. Yes steering wheel is on the list after I decide on seats with buddy club mounts. I've narrowed it down to 2 options 1.Cheaper route NRG CF seats 13lbs and NRG steering wheel https://www.carid.com/nrg-innovation...cing-seat.html https://www.carid.com/nrg-innovation...36mb-s-sl.html 2. More expensive Route Sparco QRT-R (9.9lb shell probably close to 13lbs with cushions) and Sparco - L777 Steering wheel https://www.carid.com/sparco/racing-...008005rnr.html https://www.carid.com/sparco/l777-pi...ing-wheel.html Order of operations is getting ACE headers in next weekend and getting the tune dial in with Delicious. After that I will decide on which route to go with the seats. Either option with Buddy club sliders will save me 17-21lbs per seat. Should be enough to get me right at 2500lbs. Steering wheel will be last as I do like the '17 smaller wheel. If I do steering wheel I will also do the remaining airbags (roof, Passenger) total should give me another 10-15lbs MASS reduction. Have read Anthonys thread many times and its a great inspiration that small pieces can really add up in the end. However I will never go as far as stripping out the whole interior and that exhaust is ridiculously loud. Appearance wise my car will still look stockish to the naked eye and be daily driveable. I know after the seats get me to 2500lbs the next 50lbs will be difficult. I can get to 2450 by 1. Steering wheel, total airbag removal 2. Working on lighter rear brake kit similar to the wildwood one I have upfront, possibly at expense of loosing E-brake (but seen Wilwood sells a small ebrake caliper at 6lbs) 3.Going a little lighter on the exhaust. ACE headers will already give me 5 less lbs upfront compared to the gruppe-S. And my HKS legamax is only 1 lbs lighter than stock. Really considering that HKS Spec-L. I will have to see how everything sounds with the new headers. Also did more research on sway bars. Cusco Fr 16mm, Rear 14mm will be lighter just from being smaller but I Don't know how much. Tanabe will get you larger without any much weight at all. FR 22mm will gain you .5lbs , R 18mm will gain .25lbs because they are hollow. Weight source found here: https://www.moddit.com/Guide/How+to+...+Subaru+BRZ/58 https://www.moddit.com/Guide/How+to+...+Subaru+BRZ/49 Basically not much to lose here will leave stock for now. But would go Tanabe if I want to get stiffer without gaining weight Man I can spend hours talking and researching weight reduction. I was whipping the 86 to work today and the response & quickness is Amazing! Excited that I can still get another ~90lbs out of this thing and make it even better. My C5 at ~3250 lbs is starting to feel like a pig
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | new2subaru (08-20-2018), why? (07-11-2018) |
#125 |
Drives: 2013 frs red
I would love to see acceleration numbers once you put the header on it. Weight loss you're talking about is worth 20 or so hp by itself.
#126 |
Drives: '15 BRZ RA
I am with you guys, but when I posted my acceleration numbers almost everyone was saying that the sample of the test runs was not enough ( 2 before and 2 after), that the conditions were unknown and it could have wind (we rarely have wind here), that I didn't drive the same road in both directions (I checked with high precision gps its levelness) and whatever else you can imagine. So, be prepared of some nonsense and different kind of "expert" opinions.
| Understanding Fuel Trims | ShadowReaper | Software Tuning | 13 | 04-01-2018 01:34 PM |
| Understanding Compressor Maps | arthur93 | Forced Induction | 31 | 05-25-2017 10:49 AM |
| Understanding Oil | tofurun | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 06-10-2016 04:06 PM |
| BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 07:32 PM |
| Understanding/clarifying vendor qualifications | mav1178 | Site Announcements / Questions / Issues | 21 | 03-18-2014 03:25 PM |
