Old 06-28-2019, 01:12 PM   #113
pillbox
Drives: ZC6
Originally Posted by Raven86Project View Post
Thanks man! 12 psi is the lowest you can adjust it to. Other owners on Instagram have confirmed that too.
The HKS kit only replaces the header. I was told that restrictive exhaust will introduce other deficiencies/problems, so you shouldn't keep the stock front pipe.
Thanks for the advice, appreciate it
2015 Subaru ZC6 BRZ
SPC Front Camber Bolts - PMU Club Racer Advance - GT Radial Champrio SX2 215/45/17 - HKS Type-S Oil Cooler - Verus Engineering Fuel Starvation Door
pillbox is offline   Reply With Quote
The Following User Says Thank You to pillbox For This Useful Post:
Raven86Project (06-28-2019)
Old 06-28-2019, 04:27 PM   #114
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by stevo_12v View Post
So we got 429.5hp on the dyno. This is on PUMP Gas 98RON. E85 tuning will be started next week.
From the FB post:
"So we started at 98Ron today.
Ecutek Racerom tune today achieved 429hp 474mm @19PSi boost.
E85 and more boost still to come"
Built block? What compression ratio?
Old 06-28-2019, 06:21 PM   #115
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Outfront closed deck, 10.5CR JE's. This link has more verbose info
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
Irace86.2.0 (06-29-2019)
Old 06-29-2019, 01:58 AM   #116
Irace86.2.0
That explains the power on pump gas.
Old 07-01-2019, 05:02 AM   #117
stevo_12v
stevo_12v's Avatar
HKS kit is pretty good. Had final tune
From the FB Post: https://www.facebook.com/EvolutionRm...09698175722285
[CENTER]
Build thread
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
Raven86Project (07-01-2019), weederr33 (07-01-2019)
Old 07-02-2019, 02:10 AM   #118
jflogerzi
jflogerzi's Avatar
Originally Posted by pillbox View Post
Hey guys, I'm looking to get this kit installed this winter. My car is tracked frequently every summer (~10 events a season), so I'm not looking to push the limits of this kit or the drivetrain.
What's the lowest boost the standard wastegate setup can run? I don't plan to touch other parts of the drivetrain and leave the exhaust, fuel, boost controller, and possibly motor build until I'm comfortable with the car at this power level.
Right now, I just have the HKS Type-S oil cooler.
I think 12 PSI might be much on pump. What fuel do you get? Also what temps do you see during the summer where you are? Turbo's produce alot heat.
2013 Series 10 FRS #553
Old 07-02-2019, 01:57 PM   #119
pillbox
Drives: ZC6
Yeah, I usually run 10 psi max on our crappy pump fuel here. Our Chevron 94 here is equivalent to 89 just south of the border.
95 degF is usually the hottest it gets here, only for a week or two.
I have experience with turbo rotaries, there's just a lack of technical literature from HKS on this system.
2015 Subaru ZC6 BRZ
Old 12-21-2019, 05:31 PM   #120
Escalw
In Need Of Turbo
Escalw's Avatar
Drives: 92 300zx N/A
Did a dyno run today.
Just wanted to share.
Tune By Delicious
Dyno at Rad Motorsports 808
Current performance mods:
HKS turbo kit
Full HKS Exhaust (front pipe + cat back)
Deliciousl Tuning 4 Bar map sensor
Mishimoto Oil Cooler
Deatschwerks 700cc Injectors
Deatschwerks 300c Fuel Pump
Sent from my SM-G965U using Tapatalk
Escalw is offline   Reply With Quote
The Following User Says Thank You to Escalw For This Useful Post:
weederr33 (12-22-2019)
Old 12-23-2019, 06:14 AM   #121
tomm.brz
Drives: brz 2017 hksv2
Tune By Delicious
HKS turbo kit
Hi, looks good
which fuel? 93oct?
Old 12-23-2019, 06:29 AM   #122
Escalw
In Need Of Turbo
Escalw's Avatar
Thanks you!
I'm running 92, it's all we got in Hawaii. Haha.
Old 12-23-2019, 06:35 AM   #123
tomm.brz
Thanks you!
well not bad
i'm not so used to american dynos, do you know if it s supposed to be wheel hp or calculated engine hp?
Old 12-23-2019, 06:42 AM   #124
Escalw
In Need Of Turbo
Escalw's Avatar
Originally Posted by tomm.brz View Post
well not bad
This one is measure wheel horse power.
Old 12-23-2019, 06:59 AM   #125
tomm.brz
12psi was the lowest I was able to go.
does it mean the wastegate in this kit has a 12psi spring in it?
Old 12-23-2019, 08:35 AM   #126
Dom2497
Drives: Full HKS GT86
That's right
Sent from my SM-G950F using Tapatalk
Dom2497 is offline   Reply With Quote
The Following User Says Thank You to Dom2497 For This Useful Post:
tomm.brz (12-23-2019)
Never been so excited for an oil change... No Limit Motorsport Engine, Exhaust, Transmission 20 09-28-2012 12:59 AM
Beyond excited!! debs0712 Scion FR-S / Toyota 86 GT86 General Forum 12 06-27-2012 10:03 PM
Excited!!!!!! Filipino Royale BRZ First-Gen (2012+) — General Topics 2 06-13-2012 11:14 PM
So excited to be here!!!! staycrushing Scion FR-S / Toyota 86 GT86 General Forum 8 05-31-2012 08:05 PM
Brisbane get excited! spr1nter AUSTRALIA 29 05-14-2012 08:07 PM
