Old 01-18-2019, 02:03 PM   #113
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Originally Posted by 5H1F7Y View Post
yea, tried the cable. radio signal i think might be something with the signal amplifier. Im using the carbon wiring harness, so ill have to check the pins on that to make sure its getting power. The spotify issue could be a software version as well. im hoping to try some legacy versions at some point. Bluetooth works for now
I have the carbon harness as well, but my issue was with the backup cam. They were adamant the 6v/12v converter was not required but my camera did not work until I got a local shop to inspect the harness and add a converter.
I would not be surprised if the issue is with your harness.
Carbon has stopped shipping these altogether to NA from what I know and their customer service went silent on me after just a couple of emails.
Best of luck
wolffbite is offline   Reply With Quote
Old 01-18-2019, 05:04 PM   #114
gpvecchi
gpvecchi's Avatar
My Android Auto is fine, and reception too. The only issue I get is Spotify that plays music, but not controls the app. ANd Miracast not working, but it should be a phone issue.
gpvecchi is offline   Reply With Quote
Old 02-04-2019, 03:56 PM   #115
gpvecchi
gpvecchi's Avatar
Investigating further on steering wheels remote, revealed that the P/N I posted is not the most complete version; this is the 2018 version, that misses the mute button in center of the volume control. The most complete version is the 2017 one, but I can't find the number. I would be glad if someone could PM me the VIN number of ths particular version.
Canadian versions miss one button, as they have the voice control in place of the mute button, all the other versions have the voice command button on right switches.
Old 10-08-2019, 04:15 AM   #116
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
For those struggling with the backup camera when using the Carbon Car Systems harness, you may find my fix for DDX918WS on '17 BRZ useful:
https://www.ft86club.com/forums/showpost.php?p=3264936
timurrrr is offline   Reply With Quote
Old 11-25-2019, 07:14 PM   #117
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Resurrecting this thread since I just got the DDX919WS and the plug-n-play Carbon Car Systems harness for my '18 BRZ and having issues with the rear view camera.
The CCS harness already came with the PAC Volt-39 unit already attached and taped in the loom.
Everything works perfectly with the exception of the rear view camera. It works in ACC on mode but not when the engine is running.
Since everything is Tesa taped together, I can't see if the Volt-39 wires are attached as they should be (like in your photo above.)
Any ideas?
BA9092 is offline   Reply With Quote
Old 11-25-2019, 08:11 PM   #118
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Great to hear that they've updated the harness already!
Any ideas?
Contact CCS for help or undo the tape and check yourself.
Also check which voltage the Volt-39 is set to.
Old 11-25-2019, 08:28 PM   #119
BA9092
Captain Slow
BA9092's Avatar
Thanks!
Yeah, I've been messaging Daniel at CCS. Still no solution though. I'm wondering if the Volt-39 was installed differently than your setup in the harness he provided.
However, if it doesn't work, I may just get an aftermarket rear view (12v) camera and install it directly to the (12v) head unit.
Edit: I did install a front view camera to utilize the additional camera input for the HU and it works perfectly. Just a $40 camera from Amazon. Go figure. I think it's the damn 6v from the OEM unit that's giving me all the trouble.
Old 11-25-2019, 09:24 PM   #120
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks!
As long as you already have Volt-39 there and I presume it was added specifically to handle the OEM backup camera, it seems 10x simpler to figure out why it doesn't do what it was designed to do, than trying to change the camera.
Old 11-26-2019, 03:08 AM   #121
gpvecchi
gpvecchi's Avatar
Do you know which wire is the mute one on this radio?
Old 11-26-2019, 01:34 PM   #122
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You mean between the steering wheel and the head unit? When using the harness, there's a single headphone jack looking connector between the steering wheel and the head unit. I presume all buttons share the same couple of wires and use something like different capacity for the HU to determine which one is pressed.
Old 11-27-2019, 06:04 AM   #123
gpvecchi
gpvecchi's Avatar
No, I mean for an external device. My aftermarket parking sensor have mute wire.
Old 12-01-2019, 10:25 PM   #124
BA9092
Captain Slow
BA9092's Avatar
Well, I got both cameras working.
However, they're both producing this weird static. The front camera is scrolling a ghost image of the front and vice versa.
I checked all my connections and tried a couple of different grounding points.
Would a relay/filter/capacitor fix this issue?
Old 01-11-2020, 01:13 AM   #125
durtdonthurt
Drives: White series.blue / CWP tS
Does FM radio work on these head units as they imports? Debating doing this to my 18' or if I should wait to see if they have a new 2020 model that comes out here in the states.
Thanks!
durtdonthurt is offline   Reply With Quote
Old 01-11-2020, 04:27 AM   #126
gpvecchi
gpvecchi's Avatar
FM frequency for these models is 87.5-108 MHz with 0.05 Mhz steps.
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 10:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 05:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
