Old 01-28-2017, 09:58 PM   #113
Originally Posted by Overdrive View Post
True, too.
I really don't think 50 lbs or less is going to upset the car that much (it's basically like carrying your kid in the back seat), but I do get your point, TCoat. There's a limit to everything.
No it would be like carrying your kid in the trunk. The effect of the extra weigh gets amplified as you move further back. Especially if it is behind the wheels.
Old 01-28-2017, 10:04 PM   #114
While that's actually pretty great, this is pretty much begging for an obligatory YMMV. For every one of you, there's another dozen people who find a way to get stuck.
Oh of course! I stopped and helped push two AWDs out of my way just a couple of weeks ago. I am just saying that these things are a tank in the snow. Odds are if you are going to get stuck having that extra weight in the back isn't going to prevent it anyway so why risk the balance on the wet, icy, slippery roads for a marginal improvement in traction in the deep snow? Which conditions do most drive in the majority of the winter anyway?
why? (01-30-2017)
Old 01-28-2017, 10:20 PM   #115
phrosty
Was not recommending adding weight, just carrying a shovel. I bring a foldable e-tool with me just in case. So far in the ~4.5yr of owning the car I've not been stuck either. Only used the shovel once to help dig out an SUV who's AWD all-seasons didn't save him
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following 3 Users Say Thank You to phrosty For This Useful Post:
Overdrive (01-28-2017), Tcoat (01-28-2017), why? (01-30-2017)
Old 01-28-2017, 10:28 PM   #116
I know you weren't! The weight part was form the prior comments. I have a shovel as well but it is still in it's wrapper.
Old 01-28-2017, 11:44 PM   #117
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
The weight movement is only the thickness of the back seat cushion if you place it as far forward in the trunk as it can go. Again, ain't much.
Or drop the seats and lay it on that.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-28-2017, 11:52 PM   #118
Or simply don't carry weight around for a minuscule improvement in traction for the 5% of driving time it is needed.
Although 50 pounds isn't likely to throw the balance off by much more either really.
Not a big fan of the idea of large unsecured objects sitting behind me at any point really.
why? (01-30-2017)
Old 01-29-2017, 12:35 AM   #119
Overdrive
Sittin' Sideways
Overdrive's Avatar
Agreed. Hence, trunk lol. It's by no means a requirement, as we know the car can crawl along just fine with just snow tires, but I don't think it's something someone can't do for fear of some wild pendulous effect like having a few hundred pounds of engine behind your axle (a la 911) would get you.
-O/D
2016 FR-S, Hot Lava
Old 01-29-2017, 12:41 AM   #120
Listening to some of the guys talk about driving in the snow on here I think they need to maintain as much control as they can get.
why? (01-30-2017)
Old 01-29-2017, 04:40 AM   #121
flyboy
New here!
flyboy's Avatar
Drives: 2013 FRS 10 Series
My reason for keeping the wheels in the car is because, I do not have a corner (space) to store the tires. Maybe I can store two tires, but will have to check. I don't live in the same city as my car, that why. But was no reason to add weight. I think car is pretty well balanced, wouldn't need weight specially if you have dedicated winter tires. But as you all mentioned a fold-able shovel wouldn't be a bad idea. I guess I will find a spot to keep the tires for the time being. Thanks for the feedback
flyboy is offline   Reply With Quote
Old 01-29-2017, 09:46 AM   #122
rkaywhodat
Drives: 2017 Toyota 86 Halo
I personally would just pay the $50 or whatever dollars to the dealership or any place that stores winter tires. Having my car not smell like rubber to me alone is worth the small expense and the safety and convenience of having more room is even more of a reason to do it.
Sent from my Nexus 6P using Tapatalk
rkaywhodat is offline   Reply With Quote
The Following User Says Thank You to rkaywhodat For This Useful Post:
Tcoat (01-29-2017)
Old 01-29-2017, 01:22 PM   #123
Overdrive
Sittin' Sideways
Overdrive's Avatar
Why not rent a small storage unit, bring a few cardboard boxes with you, and place the tires on top of those so they're off the ground? It should be pretty inexpensive.
Also, unless you really don't have any space at all for storage, you could look into one of those wall mounted tire racks from....Tire Rack
-O/D
2016 FR-S, Hot Lava
Old 01-29-2017, 03:43 PM   #124
flyboy
New here!
flyboy's Avatar
Ill look into it. Thanks overdrive.
Old 01-29-2017, 06:29 PM   #125
Overdrive
Sittin' Sideways
Overdrive's Avatar
Here's my stock wheels and tires in my basement. I'm sure if you had even something as small as a 3x5 storage space, you'll have plenty of room to store the wheels in two stacks.
-O/D
2016 FR-S, Hot Lava
Old 01-30-2017, 07:13 AM   #126
flyboy
New here!
flyboy's Avatar
Thanks overdrive, I did find a small storage space in the place where I stay for few days when I am in the city. I will be moving the tires there and as you showed in the pictures, I had the same idea, wrap it up in trash bags (the tire shop wrapped it up good in strong plastic too).
I guess the box is to keep the moisture away between ground and tires. Thanks for sharing.
The Following User Says Thank You to flyboy For This Useful Post:
Tcoat (01-30-2017)
Another newbie, another mod list (Suggestions wanted!) MitchEv Engine, Exhaust, Transmission 6 04-29-2016 10:58 PM
Newbie needs... Salemate Canada Classifieds 10 12-23-2015 04:07 PM
snow....starting to like snow! brzr CANADA 19 01-23-2014 01:10 PM
Newbie Toyota 20v AFRICA 6 01-18-2014 05:32 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 02:12 PM
