Old 02-05-2018, 03:30 PM   #113
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Originally Posted by pgranberg11 View Post
release date and pricing? ready to spend my tax return...
Same 😁
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 02-06-2018, 10:17 PM   #114
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by TommyW View Post
Awesome info very informative. Yes sounds like a good compromise from the over sized wings most of these guys get that IMO do more harm than good most of the time. Now go make some front aero that balances out the rear wing and that would be a great combo.
We have *a lot* of front aero options to tailor your car to various rear wing configurations. Running only the rear wing with no front aero would result in an unbalanced car at high speeds.
Originally Posted by Kestrel View Post
Same 😁
We're hoping for around April. We have not finalized pricing just yet but it will be somewhere in the teens. We are trying to keep it under 16-1700.
We decided against printing out the upright in black, so here is the purple beauty in all her glory. We have finalized a shape for the upright we thoroughly like as do others that care about the visuals; we're getting those cut shortly out of 6061.
0 degrees AOA
13 degrees AOA
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 6 Users Say Thank You to VerusEric For This Useful Post:
andy0323 (02-14-2018), cbryant514 (02-09-2018), DAEMANO (02-08-2018), Hyper4mance2k (02-23-2018), Racecomp Engineering (02-07-2018), Takumi788 (02-07-2018)
Old 02-06-2018, 11:15 PM   #115
Pat
Pat's Avatar
Drives: 2023 BRZ
I love it. You guys do great stuff.
Old 02-07-2018, 12:11 PM   #116
plucas
plucas's Avatar
Drives: Subaru
The wing was developed in CFD on and off the car to make sure we hit maxiumum efficiency. That is how we were able to have a wing that will produce 11.5 lbs of downforce for every 1 lb of drag.
The picture below is part of that CFD. This is an on car wing analysis that was done for optimization of the height of the wing from the trunk lid. The height is critical to verify clean air is interacting with the wing. Too low and we are not getting proper airflow and lose efficiency. Too high and we are getting unnecessary drag and a larger moment to change the aero balance of the car.
plucas is offline   Reply With Quote
The Following 5 Users Say Thank You to plucas For This Useful Post:
pgranberg11 (02-07-2018), Spuds (02-23-2018), Takumi788 (02-07-2018), Tristor (03-21-2018), VerusEric (02-07-2018)
Old 02-07-2018, 12:45 PM   #117
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Hi, I'm not looking to buy a wing, but it occur to me, instead of reprinting in black, why not just give it a shot of black paint with a spray can?
Great design by the way.
nico_rsx is offline   Reply With Quote
Old 02-07-2018, 01:17 PM   #118
Ashikabi
Ashikabi's Avatar
You should all be ashamed of yourselves. And probably hire Nico to clean up your operation
The Following User Says Thank You to Ashikabi For This Useful Post:
nico_rsx (02-08-2018)
Old 02-08-2018, 01:08 AM   #119
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Can this be had in gold just like you LCA?
If yes, list me up!
andrewFT86 is offline   Reply With Quote
Old 02-08-2018, 05:59 PM   #120
Tiz
Drives: Subaru BRZ
I am a bit shocked how the wing looks on the car. But performance matters and therefore I am in.
Tiz is offline   Reply With Quote
Old 02-11-2018, 09:28 PM   #121
VerusEric
VerusEric's Avatar
Originally Posted by andrewFT86 View Post
[img]
If yes, list me up!
We could probably do that. It would come at an additional cost though and a lead time, as we are not going to make gold standard. A UV resistant black anodize will be the standard.
With the aluminum uprights we prototyped (months ago), we tested some weight on the wing on the car. This is 160 pounds, which isn't a ton but enough to test how the uprights, mounts, and wing handle that weight at this point. So far so good.
Thanks,
Eric
The Following 5 Users Say Thank You to VerusEric For This Useful Post:
andrewFT86 (02-13-2018), cbryant514 (02-13-2018), DAEMANO (02-12-2018), Hyper4mance2k (02-24-2018), RallySTI (02-13-2018)
Old 02-16-2018, 11:32 AM   #122
plucas
plucas's Avatar
Drives: Subaru
We will be going live on Facebook and Instagram today at 1 pm eastern about some of the analysis that went on developing the wing and the wing to the FRS/BRZ. We will be going over performance numbers and showing in depth the CFD analysis. It will be a great way to check out more information on the wing and ask questions live.
The Following 3 Users Say Thank You to plucas For This Useful Post:
DAEMANO (02-16-2018), pgranberg11 (02-16-2018), VerusEric (02-28-2018)
Old 02-16-2018, 02:43 PM   #123
DAEMANO
Time Traveller
With this work with aftermarket carbon fiber trunks or does the design use the OEM trunk in some special way (structural, mounting, etc.)
Old 02-28-2018, 09:22 PM   #124
VerusEric
VerusEric's Avatar
Honestly, depends on how the carbon trunk is designed/copied/built. Structurally, how we have designed it to mount, it needs a lot of what the OE trunk offers. I cannot know for sure how aftermarket companies reinforce the trunk or not, but it would need to be similar to what OE does.
I apologize it took me this long to post the pictures of the trunk opening. Here they are, pretty uneventful as it opens without an issue .
Thank you,
Eric
The Following 11 Users Say Thank You to VerusEric For This Useful Post:
Cybmx (03-01-2018), DAEMANO (03-01-2018), Hyper4mance2k (03-25-2018), johan (03-01-2018), Kestrel (02-28-2018), Lonewolf (03-03-2018), Racecomp Engineering (02-28-2018), StegaDragon (03-06-2018), Takumi788 (03-01-2018), TofuJoe (06-07-2018), Tristor (03-21-2018)
Old 03-08-2018, 01:25 PM   #125
VRaven77
Drives: 2013 FRS Raven
Might be a stupid question but are you going to cut away the thin material for the uprights leaving it looking more skeletal? Didn't know if it would be affected by crosswinds... (ventus)
VRaven77 is offline   Reply With Quote
Old 03-21-2018, 08:39 PM   #126
VerusEric
VerusEric's Avatar
Cutting out the uprights' center sections would hurt the performance of the rear wing, which is why we designed the uprights the way they are. Hope that answers your question.
Thanks,
Eric
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 12:27 PM
Street Faction Engineering Chassis Mount Wing FRS/BRZ hellokyles Exterior Parts (Aero, Lighting, Etc.) 19 08-19-2016 06:20 AM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 04:35 AM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
