Old 05-03-2016, 08:27 PM   #113
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Big D Design View Post
If you are living in an area without 93 octane and only have 91 octane......
1 Use a "Teir One" brand.
2Most boat owners with an outboard motor will tell you about how corn in the gas kills motors. Lucas booster also lubricates the top end of the motor too.
I'm not a quack.
I have tested gasolines and boosters for years on end. I have even gotten up to 30 more HP on modified cars.
Any proof of this?
The manual recommends using 93, yes, but somehow, I'm doubtful that simply using 93 from 91 will increase horsepower, let alone as dramatically as you describe it.
Originally Posted by mdm View Post
The fact that you got the name wrong (it's "Top Tier", or "Top Tier Detergent gasoline") somehow makes me question your HP increase claims.
Any of those mentioned in bold to be a big turn off to listening to this guy
1) modern outboards have no detriment to running 10% ethanol, and the myth that it will void their warranties and that tanks they use will get damaged is a falsehood
2)Putting a smiley face on every part of his comment to gain trust of a false belief?
3)"I'm not a quack, I gained 30 hp on my vehicles..." Do you have dynamometer proof?
4) "Lubricate top end with lucas oil octane booster" What? How? How the hell does the octane booster reach the valve-train to help lubrication? Fuel dilution? Not only is that bad for the oil life it could be dangerous.
He preaches the same exact stuff about lucas oil octane booster all over the forum without anecdotal proof of an increase in performance:
http://www.ft86club.com/forums/showp...7&postcount=19
http://www.ft86club.com/forums/showp...4&postcount=26
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
mdm (05-03-2016)
Old 05-03-2016, 10:02 PM   #114
humfrz
humfrz
Old 05-04-2016, 01:28 AM   #115
Big D Design
Drives: FRS RED - 12 Roush RS3 - 92 Maxima
I Take that old man..
I don't post much. I live with myself knowing that research blows away just reading and word of mouth. Corn in motors is bad. Eat some corn just like I did yesterday. Don't put it in your boat motor without Lucas fuel stabilizer. Give Lucas a call...... I spent 50 years at the drag strip. Lucas knows more than you.
Big D Design is offline   Reply With Quote
Old 05-04-2016, 01:41 AM   #116
FRSBRZGT86FAN
Lucas like every other additive company in the market want you to use there products, obviously they will talk them up, I'd like an MSDS of that additive to see what's inside it. Modern outboards are literally tuned for E10 now in fuels. The only issue with them is preventing long term moisture build up.
There are plenty of articles debunking your loss of power belief:
http://www.westmarine.com/WestAdviso...nol-Fuel-Myths
http://yamahaoutboards.com/owner-res...-ethanol-fuels
http://www.boatus.com/magazine/2011/...er/ethanol.asp
http://gas2.org/2011/07/02/5-common-...posed-as-crap/
http://www.permaculture.com/node/490
On older engines yes this is an issue, even on lawn mowers with carbs that don't use ethanol resistant diaphragms and seats but on modern stuff not so much. Also again read the manual it is perfectly safe on stock tune to run 91 on our cars there should be no reason for adding octane booster to that.
mdm (05-04-2016)
Old 05-04-2016, 01:51 AM   #117
Big D Design
Tier 1
Gas is rated as tier 1 being the best. There is no top their. Who are you? Just go to the auto parts store and buy a bottle of Lucas. Try it and make sure you do some redline. I can't believe you people haven't tried to raise your octane in Cali. I lived there for 8 years and the fuel needs help. Period.
Old 05-04-2016, 01:53 AM   #118
Big D Design
Yes newer outboards......
You're right. Newer motors are made to handle corn. I still think corn is the bad fuel.
Old 05-04-2016, 01:58 AM   #119
Big D Design
Why would I want more....
I ask you...... If I noticed better acceleration and better MPG.... Isn't that cool?
Intake and exhaust is a waste to upgrade. The octane boost works. Try it or quiet.
Old 05-04-2016, 02:09 AM   #120
FRSBRZGT86FAN
Show me hard anecdotal proof that you gained better MPG and acceleration. Not some subjective number without a dyno test or seat of the pants feel.
Intake and exhaust is a waste to upgrade? The header and tune on my car yield 20-30 hp in the torque dip region, your octane booster can't do that. The FR-S OEM ecu tune is so consistent it will not go past 200 hp at the crank even if you go past 93 octane, the only difference is you'll lose likelihood it will knock if at all.
Do you know how to quote people? because making 3 separate posts in a row to one thread not directed to anyone isn't very helpful.
What are you even attempting to say here?
I have a tune and run 93 octane and have datalogs proving that's more than enough, even 91 if I flash to that tune but you lose a minuscule amount of power. On the OEM tune there is no difference.
As for California as to whether or not it "needs help" show me again, some proof, that shows its not good enough for our cars on OEM tune.
The problem really is you're making false accusations and pushing some product saying it'll work, I'm not sure if you're intentionally spamming "Lucas octane booster" but you've made some pretty hefty claims without any evidence. You even went as far as saying it'll increase top end lubrication.
mdm (05-04-2016)
Old 05-04-2016, 01:28 PM   #121
Big D Design
Just called Lucas Oil
I'm right. Just talked to the technician at Lucas and he states that the Fuel Stabilizer and Upper Lubricant is still in their Octane Booster. All you have to do is touch the stuff and feel the lube in it. Anyway, he states that Cali 91 turns into 94 octane using a half bottle at fill-up. I'm just trying to help here. I use the NOS Racing Formula with my JDM Motor '92 Maxima for 4 years. I also used the Lucas Oil as well. The NOS is very expensive. $13.99 per 20 gallon bottle and contains Nitro Methane along with MMT. If you live in an area where there is only 91 octane gas..... just try it. What do you have to lose other than a funnel and $9.
Nissan uses 0ctane Boost when testing the GTR in Cali. hmmm
Old 05-04-2016, 01:29 PM   #122
Big D Design
http://lucasoil.com/products/fuel-tr...fuel-treatment
this is what is in the boost also
Old 05-04-2016, 01:41 PM   #123
I am curious how any octane booster adds more power, much less 30HP as previously stated. (Legit question not a flame)
mdm (05-04-2016)
Old 05-04-2016, 01:47 PM   #124
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Don't know about the '92 Maxima, but it may worth noting that:
Also, I am curious what parts is the Upper Lubricant supposed to lubricate?
mdm is offline   Reply With Quote
The Following 2 Users Say Thank You to mdm For This Useful Post:
FRSBRZGT86FAN (05-04-2016), Tcoat (05-04-2016)
Old 05-04-2016, 01:54 PM   #125
Well since they shouted "DOES NOT" I think they are pretty concerned about it!
mdm (05-04-2016)
Old 05-04-2016, 02:39 PM   #126
darthpnoy1984
Drives: 15 ZN6 Asphalt
I usually trust mainly Shell or Chevron for my Premium gas on the car, I tend to get max MPG or to what MFG advertised it as.
2015 ZN6 DD AT
darthpnoy1984 is offline   Reply With Quote
Gas Premium or regular? Dragon86 Scion FR-S / Toyota 86 GT86 General Forum 315 06-20-2017 11:14 PM
Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure keioffice Miscellaneous 0 03-14-2014 09:10 AM
Shell URT Advanced / / Sonoco 260GTX // Race Fuels BC-Boy Engine, Exhaust, Transmission 2 03-11-2014 11:12 AM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
use regular gas? Sirnice Scion FR-S / Toyota 86 GT86 General Forum 85 09-29-2012 09:25 AM
