#113 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
Challenge accepted.
#114 |
Contract? /人◕ ‿‿ ◕人\
Once again, night shift made me miss the cool threads.
#115 | |
not a twin owner
Drives: 2016 Veloster Turbo DCT
Because we are trained to brake with the right foot, and we do it for years, it takes quite a lot of training to learn left-foot-braking (in the sense I am using it in the thread, not the performance technique). Initially one tends to slam on the brake far too hard, this is my experience and the experience of others who tried just a few times (see comments under the Jalopnik text I linked above). This is because we learned use the left foot to control the clutch which does not require precisely controlled engage, only precisely controlled release. Maybe also because we have to learn how to control the positive feedback due to body inertia. This is why I think that with my 50k I have much better understanding of advantages, disadvantages and limitations of LFB than people who never tried it, or tried it a few times, or just imagined how it would be to use their left foot for the purpose. |
#116 |
Drives: 2017 BRZ - Dark Grey Metallic
#117 | |
Do you rest both feet on both pedals?
#118 |
This thread is going to get locked soon
mdm has created a troll post and if he really does do this technique when he crashes next and hopefully survives he'll say he survived because of using two feet to drive an auto....
#119 | |
not a twin owner
"SST helps reduce engine power when both the brake and gas pedals are pressed at the same time under certain conditions. In normal driving conditions, you won't notice SST, as it is imperceptible. The feature doesn't engage if the brake pedal is depressed before the accelerator pedal. This allows time for the driver to move from brake to acceleration." So rev matching should be fine as you press the brake first. Trying to accelerate while still left-foot-braking should be fine too. The system should kick in if I start braking (with my left foot) when the accelarator is (still) depressed. Which is good imo, it helps if switch from gas to brake in emergency is mistimed (if there is overlap) or if the driver panics and presses the brake while not releasing the accelerator at all. But I was not concerned too much about the SST, I was concerned about Brake Assists, which increases braking force when it "thinks" that this is an emergency stop. The question if what criteria are used to detect an emergency stop. If time from gas to brake is one of them, then the system could potentially kick in when the time is short not because of emergency, but because left-foot braking was used, and change intended gentle braking into a panic stop. |
#120 |
not a twin owner
#121 | |
Drives: anything you let me
Honestly, in 15k with the car, a significant amount of that being performance driving with and without LFB, I have never once noticed or even knew about SST yet have had all the other nannies engage at one point or another. Unless there's some major difference between the MT/AT, it should be a non-issue. Most likely, SST parameters only trip in a foot-through-the-firewall pucker moment or at least so far into the pedals you'll hopefully never see it on the street. Either way, the car has never applied more brakes than I wanted. Even coming into a braking zone WAY hot, the braking feel was very linear and intuitive with relation to pedal position/effort, never 10%-20%-30%-100%. In the end, you may have to see if someone local with an AT will let you try it and see how you like it or if it drives as expected. |
#122 | |
not a twin owner
Ha ha, judging from the responses in the thread, no one would ever allow me near their cars. Anyway, if it ever comes to seriously considering the purchase, I'll obviously take it for a thorough test drive. Hope the dealership guy won't kick me out of the car for LFB ;-). Last edited by mdm; 01-19-2016 at 08:25 PM. Reason: added the MY question |
#123 |
Because compromise ®
Drives: Red Herring
Many opinions, no hard data.
#124 |
#125 |
Drives: Red Herring
Why is it dumb?
#126 | |
You'll be fine, just don't... Unless that's your commute. In which case I want your job.
| That left-side vertical streak of residue left by windshield wipers | tzhu07 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 07-15-2015 12:23 AM |
| Foot pain while braking hard? | daiheadjai | Other Vehicles & General Automotive Discussions | 19 | 04-05-2015 08:46 PM |
| WTB: OEM Control Arms: Front Left & Back Left | norcalpb | Want-To-Buy Requests | 0 | 02-26-2015 08:55 PM |
| WTB Red Bumper, Left Fender, Left head light, Clear side markers | carlossanchez89 | Want-To-Buy Requests | 0 | 09-01-2014 03:43 PM |
| How much do you like heel-toeing or left foot braking? | USMCMike | Other Vehicles & General Automotive Discussions | 20 | 01-15-2010 04:20 PM |
