08-31-2013, 09:22 PM | #113 | |
Drives: WRB BRZ
The Following User Says Thank You to blubrz For This Useful Post: | v1ru5 (09-23-2013) |
09-23-2013, 03:20 PM | #114 |
Drives: BRZ D4S 6MT L Vortech
I just broke a second belt. I ordered the Gates metal idler, blue racing belt, and the updated vortech pipe with the dimple. If that doesn't fix it i dunno what i'm going to do
09-23-2013, 03:34 PM | #115 | |
Thupercharged
I have 7K+ on the belt supplied with the vortech kit, and it shows no signs of slipping/cracking or even much wear
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
09-23-2013, 03:38 PM | #116 |
This last belt only managed under 2k miles before breaking a rib. Specifically I was hard launching the car while fueled up on e-85 putting out who knows how much torque at the crank (220~ at the wheels), bounced the rear a bit because my 225 tires are too small/ i'm a bad driver, and it snapped a few miles down the road.
09-23-2013, 03:44 PM | #117 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
09-23-2013, 03:49 PM | #118 |
Perrin engine mounts, perrin transmission back+whiteline transmission mount, I forget the brand but i have a rear diff support bracket, driveshaft shop carbon fiber drive shaft. Hell my drivetrain is so stiff I sometimes have trouble putting it in gear at a stop.
09-23-2013, 04:03 PM | #119 |
NASA SpecE30 Racer
Does the Vortech use the OEM tensioner still? Perhaps it has gone bad. There has to be something wrong other than the belt to cause these failures.
- King Tut
09-23-2013, 04:12 PM | #120 |
At that point man I would have Vortech resend you some of the spacer and mounting bracket parts, remove and re-install the blower. Something must be out of alignment.
Tensioner is also a good idea as you can tell there is a lot of movement on the stock unit.
09-23-2013, 04:21 PM | #121 | |
What should I be looking for in a failed tensioner? |
09-23-2013, 04:37 PM | #122 |
Failed tensioner would allow too much free play or forward aft wobble. Shaking or movement of the arm to a certain degree is normal. Definitely check the belt tension as well per the service manual and see how much belt deflection is allowed and measure that. Maybe Vortech also has their own belt tension allowance measurement. This is definitely something to contact them on.
09-23-2013, 09:32 PM | #123 | |
Drives: WRB BRZ
I was thrashing on the car this weekend and the non-race belt is still on with the metal idler and I've had 0 issues. |
09-30-2013, 04:32 PM | #124 |
Thupercharged
I just experienced near failure of the pulley (grease had run out and it started to squeal/squeak) and here are my thoughts on the easiest way to remove/replace the pulley, as well as a trick where you can use your OEM pulley removed during the install of the vortech kit.
Hopefully it may get someone out of a tight spot Easy ziptie tensioner pulley replacement http://www.ft86club.com/forums/showp...&postcount=917 Reusing your OEM pulley in place of plastic pulley (removed during kit install, everyone should still have theirs) Short term fix until proven long term reliability http://www.ft86club.com/forums/showp...&postcount=920
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF Last edited by DJCarbine; 09-30-2013 at 04:50 PM. |
10-31-2013, 09:34 PM | #125 |
Drives: Scion FS-R
Another belt broke today. I was doing some spirited driving with the defrost on because of heating issues. I forgot the defrost activates the ac compressor causing more resistance on the belt. Going to try a gatorback belt this time.
10-31-2013, 10:01 PM | #126 |
Thupercharged
Have you tried the gates blue racing belt?
2013 FRS
Similar Threads | ||||
Kartboy Crank Pulleys 95.00 | tom@kartboy | Engine, Exhaust, Bolt-Ons | 16 | 06-11-2013 01:06 PM |
Crank,Alternator,Waterpump Pulleys etc..? | fareastbrz | Engine, Exhaust, Transmission | 6 | 05-28-2013 08:46 PM |
Titan Performance second batch of pulleys | Amalgamo | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-30-2012 09:57 PM |
