Forced Induction Turbo, Supercharger, Methanol, Nitrous |
07-16-2016, 02:10 PM | #113 | |
Drives: RX-7 / BRZ
Stage 1 http://fullblownmotorsports.com/full...-1-short-block Stage 2 http://fullblownmotorsports.com/full...-2-short-block Stage 3 http://fullblownmotorsports.com/full...ort-block-1414
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
08-06-2016, 02:02 AM | #114 |
Takes abuse is right. Mine is still going strong and it's the first one they ever built so that says something.
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | GhostOp86 (11-26-2016) |
08-06-2016, 09:49 AM | #115 |
Drives: Late 2014 Subaru BRZ
What exactly is coated in the stage 1 block? Piston skirt? Piston Top? bearings?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
03-22-2019, 05:11 PM | #116 |
Drives: 2016 Red GT86
Do i need a new ECU (ie Motec) when getting a Short Block for my 86?
03-22-2019, 07:29 PM | #117 |
Drives: RX-7 / BRZ
No, you will need turning however if you are changing piston size or compression ratio outside of the stock specs.
Similar Threads | ||||
Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
Full Blown 521hp Stock Motor @ 20psi | FullBlown | Forced Induction | 276 | 08-31-2016 02:05 AM |
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! | Pure Automotive | Forced Induction | 181 | 03-12-2013 02:11 PM |
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive | Pure Automotive | Mid-Atlantic | 22 | 02-12-2013 10:13 AM |
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm | TyperRspec789 | Mid-Atlantic | 66 | 02-02-2013 02:25 PM |
