#1233 | |
DO NOT use WD40. Use assembly grease. There should be zero contact between anything and the pulley. CSG is available by appointment only; please call ahead to make sure we have an opening available for you. We will most likely not have the time to diagnose/inspect your car without an appointment. Is the vendor you purchased from unable to offer tech support or assist with your install? |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Xuningshen (12-09-2014) |
#1234 |
Per the instructions:
70. Install the 1.0”ID x 3” bypass hose (02411-25000) onto the spigot that is part of the compressor exit tubing. Secure with a 20-32 hose clamp (95105-20032) provided. Technical Support tech@jacksonracing.com 714-921-4500 24 71. Install the bypass valve (04000-25000) into the 1.0”ID x 3” bypass hose. Install the valve so the 1.0”OD vacant fitting of the bypass valve faces across towards the passenger side fender and the vacuum fitting on the top of the bypass valve faces the driver side fender. Secure with a 20-32 hose clamp provided. 72. Install the 1.0”ID x 90º formed hose (02411-25404) onto the 1.0”OD vacant fitting on the bypass valve. Install it with the short side of the hose on the bypass valve and the long side facing up towards the hood, vertically. Loosely secure this hose with a 20-32 hose clamp. 73. Install the 3.0”ID x 90º silicone hose (02103-76190) onto the compressor inlet using a 70-90 hose clamp provided. 74. Insert the 3.0” SC intake tube with the 1” spigot and valve cover vent grommet (4151-07- J01) into the previously installed 3.0”ID x 90º silicone hose. Install it so that the 1” bypass spigot is facing down towards the 1.0”ID x 90º formed bypass hose and the ½” rubber valve cover vent fitting grommet is facing back towards the engine. Install the bypass hose onto this tube and rotate it so that the tube/hose has a natural alignment and tighten the bypass hose clamps at this time. Loosely secure this tube with a 70-90 hose clamp provided. |
#1235 |
Drives: Subaru BRZ
sheesh, completely missed that part on the bypass valve. anyways... ended up orientating it the right way anyway haha.
The instructions say penetrating oil spray, which I just googled and apparently wd-40 is classified as it. (I sprayed a little bit on a paper towel, then whiped part of the pipes, didn't douse them with it.) anyways, i was going to call you guys today to make an appointment.
2014 WRB BRZ
#1236 | |
Drives: 2014 Scion FR-S|Whiteout
I used spit... even let it dry over night
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#1237 |
Drives: Subaru BRZ
lol part of me thinks you're actually serious.... We should meet up sometime. maybe you can spit on my pipes
![]() wait... that sounds weird.
2014 WRB BRZ
#1238 | |
Yeah... that sounds weird... LOL!
| The Following User Says Thank You to *LongFella For This Useful Post: | Bramick (12-10-2014) |
#1239 |
Drives: WRB JR BRZED
Someone buy the high boost pulley and post a dyno already! ;-)
#1240 |
#1241 |
#1242 |
#1243 |
Drives: 2013 Black FR-S
Drooooool
#1244 |
#1245 |
#1246 |
Stig's dark passenger
Is that the 80?
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
