Old 02-24-2014, 03:10 PM   #1233
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Tiremonkey0824 View Post
When i first loaded my stage 2 e85 tune my AFR was reading 14.7 while cruising and on idle. As of yesterday i had to re-write the tune and its been 14.3 while cruising and idle and 11.8-12.3 during WOT. Is this something i should worry about?
Nope. Normal
Old 02-24-2014, 03:15 PM   #1234
Tiremonkey0824
Drives: 2013 Argento 6mt
Originally Posted by shiv@vishnu View Post
Nope. Normal
awesome thanks bud
Tiremonkey0824 is offline   Reply With Quote
Old 02-25-2014, 04:08 PM   #1235
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
how can I run the software on my mac?
xclusive_brett is offline   Reply With Quote
Old 02-25-2014, 04:11 PM   #1236
Shiv@Openflash
Drives: 2013 FRS
I use a mac myself. Love it. You'll need to run Windows which you can do through Parallels or Bootcamp.
Old 02-25-2014, 04:29 PM   #1237
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Or VMWare Fusion!
- AdrianG
AdrianG is offline   Reply With Quote
The Following 2 Users Say Thank You to AdrianG For This Useful Post:
Shiv@Openflash (02-25-2014), wparsons (03-01-2014)
Old 02-26-2014, 07:46 PM   #1238
Mixlplix
Shiv,
Can you respond to my concern about using the OFT with my TRD intake. Will your stage one map work fine with it? If not, what do I do?
Mixlplix is offline   Reply With Quote
Old 02-26-2014, 07:51 PM   #1239
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Mixlplix View Post
Shiv,
The TRD intake will work fine. I tuned a car with one not too long ago and it didn't seem to have any effect on MAF calibration. It's good!
Old 02-26-2014, 08:08 PM   #1240
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
If I had to guess, the TRD intake is not much more than for looks. The factory knows that the stock intake is good (heck, Grimspeed and "ideal" intake can only squeeze about 3.5whp more over the factory intake from a restriction standpoint). Knowing this, they don't have to really change anything and that keeps MAF scaling from being thrown off.
Luckrider is offline   Reply With Quote
Old 02-27-2014, 12:27 AM   #1241
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Hey shiv, have you ever considered making a 7" in dash touch screen for the oft? Sure would be nice to replace my stero with a giant oft screen that display live readout. If your willing to make one I'll be the first to cough up the cash.
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 02-27-2014, 12:32 AM   #1242
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Or you could utilize a device that has millions of dollars behind it called a nexus 7 and then utilize one of the many programs that can do that.
Installed Mods:
Old 02-27-2014, 12:37 AM   #1243
HSayaovong
HSayaovong's Avatar
would the nexus 7 tablet be able to run the oft tuning software? if it was as simple as extending the oft display onto the nexus 7 tablet that idea might just work. just gotta make some kind of mounting bracket that would fit into the stereo mounts.
Old 02-27-2014, 12:41 AM   #1244
Sojhinn
Sojhinn's Avatar
As for extending the display I'm sure if you are willing to crack open the oft there would be a way. But I was talking about the fact you could use the torque app. Also if you are interested in the nexus 7 install.... Here's my write up:
http://www.ft86club.com/forums/showthread.php?t=50922
Installed Mods:
Old 02-27-2014, 12:46 AM   #1245
HSayaovong
HSayaovong's Avatar
looks interesting, only if i was good at these diy projects.. -_-...
to bad there isn't a pre made item that I could just buy.
Old 02-28-2014, 03:01 PM   #1246
frsqc
Drives: raven FRS
does the OFT tunes fix the idle dip issue if i have the old ecu from 2012?
its getting annoying...
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
