Old 11-02-2014, 09:31 AM   #1233
protpibe
protpibe's Avatar
Subaru super blue is premixed. Can you even buy unmixed coolant anymore ?
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Astroboy (11-02-2014), Sportsguy83 (11-02-2014)
Old 11-02-2014, 02:03 PM   #1234
Astroboy
Astroboy's Avatar
Drives: None
Glad to hear you're doing it right...I can't count how many times I've seen people slap forced induction onto factory n/a cars without gauges, cooling mods, or a good tune...and then proceed to redline the car and something goes pop...
-__- guilty... except nothing went pop, thankfully
Astroboy is offline   Reply With Quote
The Following 3 Users Say Thank You to Astroboy For This Useful Post:
@Art_Mighty (11-02-2014), Lonewolf (11-02-2014), rs999 (11-02-2014)
Old 11-02-2014, 03:17 PM   #1235
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
The bmw blue coolant isn't a premix which is what i based my assumption on
Digitalanalog is offline   Reply With Quote
Old 11-02-2014, 11:02 PM   #1236
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by Fizz View Post
Does the turbo kit affect low rpm response? Like stop-go traffic conditions? I ask because someone told me that since installing the kit he noticed its become 'unresponsive' until boost comes on.
Now that of had a day and a half with the car I've noticed the problem your friend is talking about. Starting the car "easy" from a stop it's a lot harder to do smoothly. I'm also using this with an automatic transmission so I don't have clutch I can modulate.
The other thing that I've noticed over the past couple days is that I hear the sound of the exhaust rattling against the subframe. I believe I need to explore upgraded motor mounts. Straight-line driving or making left hand turns under hard acceleration and I can feel the exhaust vibrating against the subframe. What are turn right the sound/sensation goes away.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following User Says Thank You to @Art_Mighty For This Useful Post:
Fizz (11-02-2014)
Old 11-02-2014, 11:07 PM   #1237
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Originally Posted by Digitalanalog View Post
the coolant lines at the TB keep the TB from freezing up. Look at the coolant jugs you bought. i dont believe its a 50/50 from subaru ,you were suppose to add water. running only coolant and theres a good chance you'll overheat.
Thanks for clearing up the mystery of the cooling line on the throttle body. As for the jug of Subaru super coolant I purchased at the dealer; yes, it is a 50-50 mix.
Old 11-02-2014, 11:53 PM   #1238
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Do you think the initial "lag" is something that can be tuned out? Or is it an inherent quirk of running a turbo?
Is it the overpipe that is touching the subframe? What size OP are you using?
Fizz is offline   Reply With Quote
Old 11-03-2014, 07:17 AM   #1239
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
I'm not sure of the root cause. I need to start logging and then send the logs to @sales@delicioustuning.com to get their opinion.
Probably, I haven't been under the car yet to confirm. I'm using the Milltek 2.5inch overpipe
Old 11-03-2014, 09:37 AM   #1240
protpibe
protpibe's Avatar
A 2.5" overpipe shouldn't rattle if it's installed correctly. Unfortunately, you did what I did and installed everything at once (exhaust, turbo kit, etc) so it's hard to troubleshoot individual issues.
I would also take a look at your catback to make sure that it's not hitting the diff.
The Following User Says Thank You to protpibe For This Useful Post:
@Art_Mighty (11-04-2014)
Old 11-04-2014, 01:04 PM   #1241
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
We were very careful when we installed everything so I would hope it wasn't a mistake. Simply put it's an exhaust and it's hard to screw that up. This may be a fitment issue between AVO and Milltek components. I did install everything at once and I do think I'm clearing the diff in back.
Not exactly sure how to fix this without taking the turbo off and mounting the stock header to see if the problem is the exhaust or not. Any suggestions would be welcome.
One thing I noticed was how much larger the turbo's down pipe was from the Milltek exhaust (3" vs 2.5"). There's
Old 11-04-2014, 03:35 PM   #1242
protpibe
protpibe's Avatar
You have the 3" downpipe from AVO?
Old 11-04-2014, 08:46 PM   #1243
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
It seemed like it. it was bigger then the 2.5" (63.5mm) of the milltek system. The AVO downpipe had slot shaped holes so the smaller exhaust fit onto the smaller downpipe and the gasket sealed but man that was difficult. I split my knuckle open tightening those bolts.
Old 11-04-2014, 09:04 PM   #1244
protpibe
protpibe's Avatar
If you have a 3" downpipe then no other overpipe except AVO's will work. They change the routing with the 3" setup and sell the Downpipe/Overpipe/Frontpipe as a combo.
I think the stock 2.5" is just a slotted flange, and I agree that it was a giant pain in the ass.
Old 11-04-2014, 09:47 PM   #1245
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Do you mean all their kits (whether 2.5" or 3" dump pipe) come with slotted flanges as well?
Old 11-04-2014, 09:52 PM   #1246
protpibe
protpibe's Avatar
Here's a shot of my 3" setup
The downpipe is a 90 degree turn and straight, whereas the 2.5" one has a bit of a wiggle to it
Comparison:
@Art_Mighty (11-04-2014), Astroboy (11-05-2014)
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
