Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 07-30-2013, 10:49 PM   #1233
NIKDENG
Drives: RED BRZ
Originally Posted by rockers_kitoy View Post
hahay.... kinda disappointed for my 1st mags&tire change.
i didn't recognize that the size of the 'holes' will be taken into consideration (114 for my mags vs. 108 for our t86) and after fitting in, it didn't fit. tsk
and so, where can you suggest a good or better place for find mags (17-inch)?
thanks in advance.
@rockers_kitoy,
The bolt pattern and PCD of our cars are 5 x 100 and not 5 x 108. You also have to consider the offset and width of the mag wheels you are choosing. For offset, the safe values are from +35 to +48. The lower the offset the more it will stick out from the fender. The higher the offset the more it is tucked into the fender. In terms of width, the safe values are from 7.0 to 9.5 inches. For reference our stock mags are 5x100 bolt pattern, 17 inches in diameter, 7.0 inches in width, offset +48.
For mags (17 to 19 inches) that would fit your 86 you can source them from:
Originals:
AUTOPLUS SPORTZENTRIUM, AUTOLINE MOTORSPORT and TYRE RACK
ROTA and LINEA CORSE mags:
STIVO CONCEPTS
Original and Replica mags:
AUTOKOZMETIX, BANAWE CAR CARE CENTER, BENS OK, BLUELINE CAR ACCESSORIES, CONCEPT ONE WHEELS, GARAGE ONE, GOMAGS, KO HIGH OCTANE MARKETING and almost any mags shop in Banawe.
You will have more options in terms of design if you went with 18 inch mags.
You can make arrangement with them to ship to Koronadal if your car is not in Metro Manila.
Hope this helps.
NIKDENG is offline   Reply With Quote
Old 07-30-2013, 11:18 PM   #1234
rockers_kitoy
rockers_kitoy's Avatar
Drives: Toyota T86
big thanks NIKDENG!
rockers_kitoy is offline   Reply With Quote
Old 07-31-2013, 10:55 AM   #1235
dagame
dagame's Avatar
Drives: Subaru BRZ ZC6 Lightning Red
Originally Posted by dhoeze View Post
Mga sirs,
hopefully we can have a get together so I can more ideas for our ride.
some members here meetup on a regular basis. check out the fb group, they post it there
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson, Top Gear S19E3
dagame is offline   Reply With Quote
Old 07-31-2013, 09:01 PM   #1236
dhoeze
Drives: Toyota 86
was invited by Booch before for the friday eb at GH, problem is medyo toxic and alipin mode at work so nahihirapan akong maka attend... sana merong Saturday Eb para rest day. thanks sir.
PM me sir if meron get together again... will check updates as well sa FB group.
Godspeed
dhoeze is offline   Reply With Quote
Old 07-31-2013, 11:22 PM   #1237
dagame
dagame's Avatar
Godspeed
the only ones i know are the friday nights at GH and sometimes wed nights at cellar bar, ortigas home depot. this sat meron din at BRC for circuit showdown if you're interested
Old 08-01-2013, 12:02 AM   #1238
w3bhead
Drives: A Car
TRD Sound Changer
Hi guys! First time to post here. Anyway, I accidentally bought 2 sets of the TRD sound changer so I'm selling the extra set. The item is brand new. I just got it today, fresh from Japan. If anyone is interested, send me a message. Thanks!
w3bhead is offline   Reply With Quote
Old 08-01-2013, 03:08 AM   #1239
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by NIKDENG View Post
@rockers_kitoy,
Originals:
STIVO CONCEPTS
Hope this helps.
Good info. Also, I strongly recommend getting hub centric rings if you guys are going to install aftermarket wheels. The hub bore of our cars is 56.1mm. Plastic should be okay for street-driven cars, but aluminum rings are a must if the car will see track action
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
rockers_kitoy (08-02-2013)
Old 08-01-2013, 11:36 AM   #1240
Choyhernandez
Drives: Gt86
Hi sir di ko po mahanap ung fb group, can you send me the link? Thanks
Choyhernandez is offline   Reply With Quote
Old 08-02-2013, 12:28 AM   #1241
dagame
dagame's Avatar
check PM
Old 08-02-2013, 12:46 AM   #1242
Choyhernandez
Drives: Gt86
check PM
Thanks sir
Old 08-04-2013, 12:49 PM   #1243
victorb
Drives: Black 86
if you guys need tires for 18's and 19's I have Achilles Tires for you guys at very reasonable prices 0917-8838471
victorb is offline   Reply With Quote
Old 08-04-2013, 08:26 PM   #1244
dhoeze
Drives: Toyota 86
@dagame.. missed this invites, sayang. We did went there at BRC the next day. hope to see you guys soon to get pointers...
Old 08-04-2013, 08:30 PM   #1245
dhoeze
Drives: Toyota 86
@dhoeze,
Nice choice. Gives you that retro modern look. The 5x100's Rota RKR 18X8.5 offset 44 Front and 18x9.5 offset 44 Rear where specifically designed for the 86/BRZ's. As such you won't have any clearance problems at all even when lowered. No need to widen or fold the fenders. I had these on my car with 235/40 tires all around lowered 1 inch with no problems at all.
Since your car is a pearl white 86 it would look like this (pictures taken from rota wheeldudes site)
Hope this helps you out.
Now confused sir. hehehe... for the rear.. i've seen offset 38.. and the above suggestion is an offset of 44.... what would look better... hehehhee
Old 08-04-2013, 10:55 PM   #1246
NIKDENG
Drives: RED BRZ
@dhoeze,
For 18x9.5 wheels at the rear, the higher offset 44 tucks the wheels in by 13.5 mm so you can lower your car even with wide tires (series 245 and above) without any rubbing issues. Go with this set-up if you track your car. Will give you the slammed look when lowered.
The lower offset 38 at the rear makes the wheels almost flush with the rear fender with just a 4.5 mm clearance. You can still lower it but are limited to series 235 wide tires and below without having to tinker around with suspension geometry and fender rolling. Will give you the stanced / flush look when lowered.
The Following User Says Thank You to NIKDENG For This Useful Post:
melon (08-06-2013)
