Old 03-29-2014, 01:48 PM   #1205
Raven604
Originally Posted by OjiGeorge View Post
Thank you Shift Autosport in Vancouver BC! Can't wait for Monday to pick her up. And thank you LJ at FullBlown for your incredible customer service in getting this kit installed and running properly!
Come out to Ridge and take me for a rip bud
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 03-29-2014, 05:08 PM   #1206
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I'll be out your way on April 26th for Velocity Auto-x. It's over at 4, could meet up after. Add me on fb, I'm the only George in the ft86club Vancouver group.
OjiGeorge is offline   Reply With Quote
Old 03-30-2014, 03:47 PM   #1207
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Water/meth installed. Here we go.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-31-2014, 01:16 AM   #1208
OjiGeorge
OjiGeorge's Avatar
Epic, in for results.
Old 03-31-2014, 10:08 AM   #1209
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Added @blackfireball5 who puchased @Nothing 's car.
Old 03-31-2014, 12:35 PM   #1210
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Going back to the track this sunday with slicks
I love boost!!!!!!
Old 04-01-2014, 12:31 AM   #1211
jflogerzi
jflogerzi's Avatar
Originally Posted by OICU812 View Post
Did they do all the tuning as well? What fuel did you tune it to? I'll be curious on your final #s
glad you settled on a kit, and a good one to look forward to your impressions and thoughts as time goes on!!
Man that Engine bay is so clean! Gotta start saving my pennies for a FBM Stage 1 kit.
Old 04-01-2014, 03:06 AM   #1212
Sterz
Great White
Drives: 2013 Whiteout FRS
Hey guys, got the whole oil cooler mess figured out. LJ @FullBlown has been nothing short of incredible in helping me with the issues ive had since installing the turbo kit. As some of you may know, I installed Gen's old turbo kit. Ever since the install something has felt off. When I left the shop who originally installed my turbo kit, it definitely didn't feel right. The car was hesitating to boost, once it did reach boost it felt like it was lagging and revving up slowly. I got an engine code P0107 and I cleared it thinking the ecu was adjusting.
When I purchased the kit from the previous owner I was told it had an upgraded map sensor with it and to use the @DeliciousTuning tune that the previous owner had dyno tuned for his car. When I got the CEL and I knew the car wasn't acting right I decided to throw on the basemap to see if maybe there was a mix up with the map sensors. The car ran so much better on the basemap, the idle was dipping slightly but it felt much better than the original SD tune, but the car was only boosting to 3 psi. After calling the previous owner and the shop I found out that the map sensor installed was an OEM Honda 1.5 bar map sensor that Bill supplies. After receiving that information I switched back to the SD tune and it ran amazingly...So much better than when I left the shop. I was making target boost and it felt great.
Fast forward to a few days ago...The car threw that code again. Still everything was running well so I cleared it again. I am planning on getting tuned later this week so I thought we would work out the issue.
Fast forward again to today. Car threw the code again. This time with all of the symptoms of when I left the shop. The turbo was hesitating horribly. When I did get into boost it seems to rev slow so I would back off as soon as I felt it struggling. I got home and cleared the code, I had to leave later for work. It had the same issues, but when I drove home from work it was absolutely normal and felt great again. I had a boost/vacuum test done, and they found nothing.
I just installed my FX350 clutch, and tomorrow my 1000cc injectors will be installed by Evasive Motorsports. After that I am ready to tune with some e85 action! But I just want to make sure that this is not a mechanical issue before I get tuned later this week. Also, I am not very familiar with the OEM Honda 1.5 Bar. Does anyone know its limitations? Should I upgrade it anyway if I am going e85?
Sorry in advance for the novel.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 04-01-2014, 10:56 AM   #1213
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Added @mashal to the owner's list, as I finally convinced him FBM was the way to go and he made the call to LJ @FullBlown.
Old 04-01-2014, 10:59 AM   #1214
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If the only code you are thowing is P0107, then I wouldn't worry about anything being mechanically wrong. Personally I would get an OMNI 3 or 4 bar MAP sensor and make sure that whoever is doing the tuning has the proper MAP sensor scaling in your tune file. If it is truly only a 1.5 bar sensor in there and 1 bar is atmospheric pressure than it will only read up to 7 psi and the scaling might be off still in your ROM.
Old 04-01-2014, 11:03 AM   #1215
sw20kosh
Drives: 2013 Black FR-S
The honda map sensor that bill uses and supplies is a 11psi one.
Old 04-01-2014, 12:46 PM   #1216
Sterz
Great White
Ahh thank you! So I will need a new one anyway for e85? Time to call LJ
Will post results within the next couple days.
Old 04-01-2014, 12:49 PM   #1217
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Tuning at evasive ?
Sent from my IBrick
Old 04-01-2014, 12:53 PM   #1218
Sterz
Great White
Originally Posted by SmsAlSuwaidi View Post
Tuning at evasive ?
Sent from my IBrick
I was planning on using Bill but damn that busy man is hard to get a hold of.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
