Old 02-09-2012, 08:57 AM   #1205
Maxim
Drives: 2010 GTI 2dr Tornado Red
Originally Posted by SUB-FT86 View Post
I have been on GenCoupe.com since 08 and I haven't seen a owner said anything about 3,500+ lbs. Is there a link?
I know that Car and Driver and Motortrend have both tested 3500 versions.
Motortrend had an article up about the 2.0T and it was sitting near 3400. The 2.0T R-spec is mid 3300's according to Motortrend.
http://www.caranddriver.com/reviews/...take-road-test
Some of the published weights I've seen are as low as mid 3200's for the 2.0T, but others are much higher.
And here's a 3480 curb weight for the base 3.8
http://www.caranddriver.com/reviews/...ritical-page-2
Base versions of the V8 stang weigh in the high 3500's, while loaded versions are about 50lbs heavier.
So yeah, between top-end versions of the car, there's about a 100-130lb difference
Admittedly, Hyundai did a hell of a lot better job getting weight out of their sedan platform than Chevrolet did with the Camaro. It's still within spitting distance of the Mustang though. Within around 3% in comparable trims.
Maxim is offline   Reply With Quote
Old 02-09-2012, 09:36 AM   #1206
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
here is a stock mustang at Mosport International Raceway (buddy of mine)
Old 02-09-2012, 11:33 AM   #1207
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Maxim that car that you posted as BASE isn't a BASE. LOOK at the article again. It's a Lime Rock Green 3.8 TRACK model. That is the heaviest GC model. I really don't think you guys on this site have a clue about the GC other than the GC followers like me and a couple other guys here.
2.0t starts at 3,294 lbs. Base
2.0t automatic is 3,362 lbs Base
3.8 V6 manual is 3,389 lbs Base
3.8 V6 auto is 3,397 lbs Base
Adding the Sports pkg(R-Spec) adds 40 lbs
Adding the Premium pkg with Nav adds 40 lbs
So basically a 3.8 track(R-Spec+Premium combine) adds 80 lbs to the base curb weight.
Again I have been following this car since it was under wraps just like the FR-S. Anything you guys don't know I am all ears.
SUB-FT86 is offline   Reply With Quote
Old 02-09-2012, 11:56 AM   #1208
Dark
Elite Padawan
Dark's Avatar
Don't know which gen coupe you guys were talking about, but...
@SUB: those numbers are from old models. You don't have to follow gc forum to get it, just get it at hyundai.com.
New GC official numbers at Hyundai.com
MT 2.0T 3362-3492lb
AT 2.0T 3424-3554lb
MT 3.8 3433-3563lb
AT 3.8 3483-3613lb
http://www.hyundaiusa.com/vehicles/f...fications.aspx
Dark
Dark is offline   Reply With Quote
Old 02-09-2012, 12:00 PM   #1209
SUB-FT86
86 Member
MT 2.0T 3362-3492lb
AT 2.0T 3424-3554lb
MT 3.8 3433-3563lb
AT 3.8 3483-3613lb
We were talking about the 2010-2012 models.
If you noticed none of the cars we were quoting was a 2013 model because it hasn't dropped yet.
But on another note the new model weights sucks. Thank god I only like the 2010-2012 models. Hyundai is fucking up the car with more weight.
Old 02-09-2012, 12:07 PM   #1210
Dark
Elite Padawan
Dark's Avatar
At this point, we should only compare 2012 model, since 2013 Mustang numbers are not up yet.
Note, Hyundai really screwed the new model by adding up more weight, but hp crowd will be pleased with the numbers.
Dark
Old 02-09-2012, 12:20 PM   #1211
SUB-FT86
86 Member
Yeah we were comparing 2010 GC vs 2011 Stang. I'm glad I no longer like the GC after the 2012 models. Hyundai drop the ball with stupid 8 speed transmissions and a retarded front end.
Old 02-09-2012, 01:13 PM   #1212
Dark
Elite Padawan
Dark's Avatar
I see.
Hyundai is trying to achieve high mpg by adding 8spd, but it's annoying for a car with that much power. Even the one in IS-F is kinda a bit annoying too.
Dark
Old 02-09-2012, 01:19 PM   #1213
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Some dealers still dishonor warranty when you mod your car, no?
Not at all, typically what we do is we just exclude what you came in for if we notice signs of tampering in general. It doesn't have to be modded but if it is modded or simply aftermarket it isn't expected to be covered under warranty. At the same rate, we don't void the entire warranty, we just don't warranty that specific job.
Example:
Right front door speaker connector and wiring are damaged/burned. Warranty job
Right front door speaker connector and wiring are damaged/burned. There are signs of tampering or it's an aftermarket speaker.
Cash job
SVTSHC is offline   Reply With Quote
Old 02-09-2012, 02:23 PM   #1214
Dark
Elite Padawan
Dark's Avatar
Example:
Cash job
I'm well aware of that, but weren't we talking about powertrain warranty? If I reflash/ecu tune my car, I void warranty. no?
Dark
Old 02-09-2012, 02:54 PM   #1215
cassidy0998
cassidy0998's Avatar
Drives: '99 Ranger / '94 APU Supra / Ninja!
You have to keep in mind that the majority of people that buy automobiles don't modify them.
Hyundai has the better warranty.
cassidy0998 is offline   Reply With Quote
Old 02-09-2012, 02:57 PM   #1216
Dark
Elite Padawan
Dark's Avatar
To me, warranty is nothing. I keep my car unmod for 3 or 4 years at best. Satisfied?
Dark
Old 02-09-2012, 06:17 PM   #1217
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Well seeing as the genesis has a locked ECU and you have to piggyback it then no. But if the tune ends up ruining other components like getting your valves, plugs and such covered in carbon then getting that carbon cleaned / plugs cleaned or replaced won't be covered.
Simple solution, pull the piggyback before you take it in. That's what I did with my SVT. What they don't know won't hurt em.
Old 02-09-2012, 06:24 PM   #1218
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
yea thats what my friends dad does with his gt500
remove piggyback system get repairs done throw back on piggyback system
ford dealership is none the wiser
Out of the FRS game
Mr.Jay is offline   Reply With Quote
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
FR-S/Subie Coupe fantasy Maxim Scion FR-S / Toyota 86 GT86 General Forum 23 06-10-2011 01:25 PM
new Kia coupe Ground N Pound Other Vehicles & General Automotive Discussions 22 12-29-2009 02:04 PM
