Old 10-28-2015, 03:54 AM   #1205
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Originally Posted by Irace86 View Post
So I figured how it could be done:
Presently the Delrin cover is threaded onto the steel core (left). In the below cut-away diagram (right) I show how the Delrin could be wrapped in leather then the leather ends could be tucked in the center of the Delrin in a recession. The Delrin could then be press-secured by the two-piece core which screws together. This design should allow someone to interchange covers. Covers could come in a variety of leather types (perforated, non-perforated, Alcantara, etc) and maybe leather colors, or perhaps even contrasting colors for the leather and Delrin. For example, a black perforated leather with a red Delrin base that may show through the perforated holes.
Just an idea you can run with if you have hit a brick wall. IMO, something leather that has weight and quality hasn't been done, so this would be a home run if you can pull it off. My Momo shift knob, for instance, feels nice to the touch with the patinated perf leather, and it looks nice, but once in action it is sloppy, not notchy, and the aluminum hollow core makes the knob feel light and, because of that, cheap. I'm rooting for you guys.
This and one in alcantara please!
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 10-28-2015, 10:06 AM   #1206
Irace86
Drives: BRZ + Ducati M796
Thanks for the vote of confidence. The other hurdle is feasibility. For one thing, just screwing on a top and bottom piece could twist the leather. Two, I dont know how the core looks on the inside; there could be a large hollow section for the shift rod and adapters that would make this impossible. Hopefully not.
Irace86 is offline   Reply With Quote
Old 10-28-2015, 01:07 PM   #1207
calmtigers
I think if the leather was put on like the TRD knobs it might work fairly well. Similarly it'd probably have to be wrapped like a sleeve around the cover but just to the tops and could have a plate on top to cover the extra left over inside. (almost exactly like the trd one)
Old 10-28-2015, 08:46 PM   #1208
Cartman
Cartman's Avatar
Drives: GT86
Originally Posted by ShaneLindley View Post
The ball is under flash, but it's the same color as the car. Quite a bit higher than I like, but had to buy it.....
I bought mine with the Mustang/fiesta lockout hole, sits lower than the OEM knob... The lockout hole is big, but my blox lockout cover filled the inside a bit.
Cartman is offline   Reply With Quote
Old 10-31-2015, 06:19 PM   #1209
stevesnj
stevesnj's Avatar
I put on a MOMO Shadow Carbon, Not too flashy which I like...not as tall as it looks but more leverage for sure
My 2016 Build thread
Old 11-01-2015, 01:29 AM   #1210
Irace86
Besides the light weight, the only thing I don't like about my Momo knob on my Lancer is the fact that it doesn't sit low, so the shift shaft is visible like on yours; it isn't recessed. I made a spacer out of tube aluminum to seat against the shifter better, but it really seems like they should have handled that. Moreover, it isn't perfect because of the covers on the bottom of the knobs, and just how it all works.
Old 11-01-2015, 02:22 AM   #1211
Geez do I have to do everything around here?
Here is @Ultramaroon 's
Old 11-01-2015, 02:36 AM   #1212
Ultramaroon
not playing cards
Ultramaroon's Avatar
Shit! I forgot about this thread. Thanks, man!
Old 11-01-2015, 02:47 AM   #1213
Old 11-03-2015, 01:40 AM   #1214
tracerit
Drives: '13 SSM BRZ Limited 6MT
Originally Posted by Raceseng View Post
I'll post an update when I have one. We are still working on it although it is proving to be difficult!
Are you only working on covers for the Ology and Tur cores? or are you also considering just a simple non-changeable stand alone knob?
tracerit is offline   Reply With Quote
Old 11-09-2015, 05:20 PM   #1215
Raceseng
Raceseng's Avatar
The idea was to try and wrap a cover that would screw onto our existing cores BUT I just realized it is not feasible to have the stitching time out correctly with the shift gate pattern.
The other problem we are running into is getting the leather to wrap over the top opening in the cover. All the other leather shift knobs have a top cap for this exact reason.
The next idea is exactly what you have drawn up on the right. It needs to be a 2 piece core with a bottom and screw or bolt on top.
Back into Solidworks to figure it out!
Raceseng is offline   Reply With Quote
Old 11-09-2015, 07:07 PM   #1216
Irace86
Looking forward to your progress!
Old 11-09-2015, 09:56 PM   #1217
Raceseng
Raceseng's Avatar
I'm also working on stand alone shift knobs that are stainless steel and wrapped with leather or alcantara.
Old 11-09-2015, 10:08 PM   #1218
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Now that would be great! Model it after the TRD knob, please!!!
MS, CSCS, TSAC-F, CPT
knobs
Shift Knob Jwong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 12-12-2014 01:33 AM
Kartboy Shift knob Spartan65 Interior Parts (Incl. Lighting) 8 10-03-2012 06:18 PM
any other shift knob? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2012 01:38 AM
TRd Shift Knob GaN-MaN Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 01:57 PM
