View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 12-30-2012, 01:10 PM   #1191
axelo
Drives: Whiteout frs
I agree with xdbuix .... mine a do every 3 complete fills... you fill also improvement of throttle .... I dont mine the "chirping" because in mine even people that dont know about cars saw it as part of what the engine is like...something normal...
Thanks
axelo is offline   Reply With Quote
Old 12-31-2012, 11:55 AM   #1192
PabloN
PabloN's Avatar
Drives: 2013 Scion FR-S, M/T argento
Subaru TSB on chirping
Originally Posted by Weeber View Post
Hmm after reading the threads on these forums is it safe to say that this is a mechanical/design problem?
The attached TSB (from the TSB sticky) describes an aeration problem with certain pumps & fuels (sorry if this has already been mentioned--I haven't read all the pages on this post). Is there another chirping problem besides this?
PabloN is offline   Reply With Quote
Old 12-31-2012, 04:33 PM   #1193
whtchocla7e
Drives: 2013 FR-S Hot Lava
I brought my car in to the dealer to reflash the ECM/ECU and had them check out the chirping. They ordered the HPFP for me. They said there's over 140 of these pumps already on backorder so it may be a while. You guys sure are keeping Toyo on their toes.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 01-01-2013, 03:08 PM   #1194
RavenFR-S
The reason for the chirping, as I was told by Scion HQ, is that the material used to make the pump did not meet specifications. Under heat, the material expands too much which causes the chirping. I assume this is from a decrease in pressure or air getting into the pump.
They stated the back order I experienced was because new materials were being put into the new pumps by the supplier who makes the pumps. If you recently ordered one it will come in around mid-January - February.
RavenFR-S is offline   Reply With Quote
The Following User Says Thank You to RavenFR-S For This Useful Post:
Marrk (01-01-2013)
Old 01-02-2013, 02:40 AM   #1195
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Do newer versions of the car have this? I bought mine right before the New Years and it was only sitting on the lot for a few days. I'm almost 500 miles in and couldnt find the chirping sound.
l0aded is offline   Reply With Quote
Old 01-02-2013, 10:13 AM   #1196
Mattitude
Drives: 2013 Raven FR-S
2k miles, I've had chirp probably since 2-300 miles, or at least that's when I noticed it. Once the car is warmed up. It's not right having a brand new car sound like it has a bad timing belt everytime I pull up to a McDonalds for a coffee.
I guess it's time to take it by and see if the TSB fixes it. Doubtful, though.
Mattitude is offline   Reply With Quote
Old 01-02-2013, 02:48 PM   #1197
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
I heard the chirping around 320~ miles and i thought it was from trying to be cool and turn hard once, but im like "isnt the car designed to be handled like that anyway?"
But then i run into all these posts about 300mile range engine chirp.
The next day i check for chirps and it was gone, should i take it back to dealer still?
Today will check again after work..
Marcoscrdo is offline   Reply With Quote
Old 01-02-2013, 05:04 PM   #1198
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
I wouldn't waste your time until it shows up consistently so they are sure to reproduce it.
Personally I'm not bothering until some people report back that their chirps are still gone after they've had a new pump for several hundred miles.
enigmaaron is offline   Reply With Quote
Old 01-02-2013, 08:25 PM   #1199
RavenFR-S
If you want to, you can. The TSB is out there; therefore, Toyota/Scion is aware of the issue. You can say it is an intermediate problem and you have experienced it.
Old 01-02-2013, 10:22 PM   #1200
StOpNG0x
StOpNG0x's Avatar
Drives: Firestorm MT FR-S
Two questions:
Is it a good idea to print out the TSB that shows a summary of the problem and bring it into the dealer so I don't get looked at like I have 20 heads?
Also, is the TSB for all FR-S's? Or is it only for a certain VIN range? I looked and couldn't find any certain VIN range.
I have the chirp and it's annoying as hell when im idle at a stop light or parked. I have about 1700 miles and it started around 800. Mine was manufactured 9/12.
StOpNG0x is offline   Reply With Quote
Old 01-02-2013, 10:28 PM   #1201
smokeyFRS
smokeyFRS's Avatar
Drives: 2013 Scion FRS MT / Argento
Originally Posted by StOpNG0x View Post
Two questions:
I would bring it in with a printout. See attached TSB, just in case.
smokeyFRS is offline   Reply With Quote
The Following User Says Thank You to smokeyFRS For This Useful Post:
StOpNG0x (01-02-2013)
Old 01-03-2013, 12:13 PM   #1202
Marcoscrdo
Marcoscrdo's Avatar
Sorry if i was in the wrong thread, but is there anyone that can post the BRZ version?
Old 01-03-2013, 12:34 PM   #1203
RavenFR-S
Please refer to the thread below. Under the first post, it is the third BRZ service bulletin.
http://www.ft86club.com/forums/showthread.php?t=21868
Old 01-03-2013, 12:57 PM   #1204
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
My chirping didn't start until ~1500 miles or so on my BRZ.
I am in the same boat as others on this forum, until the issue is truly resolved I am not going into the dealer for a replacement fuel pump. I will let them know of the issue at the next service visit.
The issue is not a big one for me.
n8dog11914 is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
