Old 09-04-2018, 06:41 AM   #1191
Seba
Drives: BRZ Cosworth SC MY16
How much cooolant should be in the IC tank when cold?
Seba is offline   Reply With Quote
Old 09-04-2018, 06:43 AM   #1192
Seba
Originally Posted by sly View Post
Just took the car for it's first real road trip. 6 hours one way and it was flawless. Interstate and back roads. Averaged 31mpg.
22mpg
Old 09-04-2018, 01:43 PM   #1193
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
I finally drove the car for 500km after the SC is installed.
Before the car is in operation temperature (90 – 100c Oil Temp), car still have idle dip and automatically rev up to 2k RPM at a complete stop. After the car is in operation temperature, no idle dip. Is this normal?
When I rev up the car at around 4500 rpm, it feels like the car has an extra punch (way more obvious than without the SC).
I still haven’t had a chance to datalog the car and send it to Matt.
botbs is offline   Reply With Quote
Old 09-04-2018, 04:00 PM   #1194
sroby
Drives: 2015 Firestorm 08/05/15
Get the tune checked. Should not have idle drop. Possible vacuum leak.
sroby is offline   Reply With Quote
Old 09-05-2018, 01:54 AM   #1195
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
send me the data log chap and I'll take a look at it
Matt@Cosworth is offline   Reply With Quote
Old 09-05-2018, 01:55 AM   #1196
Matt@Cosworth
level is about 1" from the top or thereabouts, you will lose a tiny amount over time as vapour as the cap isn't sealed
Old 09-05-2018, 05:15 AM   #1197
ajc209
Drives: GT86 Cosworth
The idle dip is hit and miss how quick it learns. Sometime after loading and map it learns really fast other it take ages. Same map.
There is a fair surge after going past 4k ish
As the torque picks up a bit.
Sent from my SM-G935F using Tapatalk
ajc209 is offline   Reply With Quote
Old 09-05-2018, 08:28 AM   #1198
Seba
Thanks, I will have to add some distilled water.
Old 09-07-2018, 01:51 AM   #1199
enigma
Drives: Asphalt 86
Oops. Just ordered a smaller pulley.
I hate when accidents happen...
enigma is offline   Reply With Quote
Old 09-07-2018, 05:08 PM   #1200
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
We have a few more pulleys in stock!
https://www.rallysportdirect.com/par...-pulley-63-5mm
- Pumpkyn
RallySport Direct is offline   Reply With Quote
Old 09-07-2018, 08:21 PM   #1201
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
- Pumpkyn
The item "Cosworth FA20 Undersized Supercharger Pulley (63.5mm)" is invalid and has been removed from your cart.
Looks like the online ordering for this part is still not working. I had to have mine manually added to my order. The system still thinks it's part of a bundle.
sly is offline   Reply With Quote
Old 09-07-2018, 08:37 PM   #1202
sly
sly's Avatar
It took hundreds of miles and over a week but I got one more CEL. P0456 - EVAP Control System Leak Detected Very Small Leak
I'm going to go back over the system and replace the hose clamps with worm gear clamps to ensure everything is tight. No drivability issues at all. Car still runs great and is getting good mileage. I haven't gotten any other codes since Matt deleted my previous EVAP code from the ECU. I'm not sure if I have an actual EVAP purge line leak or if this ECU is just extra finicky.
Old 09-14-2018, 12:20 PM   #1203
Greacemonkey
Drives: dark grey Scion frs 2013
Running the kit for 400km now and everything run well so far. So happy with it! Do you find that cold start are a bit less aggressive than before the mods?
I also thinks that a reason why I don't feel much of a difference in some of the power band too is because the car was already modified before I put the SC (el Header, full straight exhaust and OFT), so hp increase was a bit less of a shock.
A thing I like too is the tune, my car do less random backfires than with the OFT (better AFR or timing maybe).
I have a concern about the coolant concentration, 25% of glycol is good for summer but what about winter? is there a reason why the ration is so low, is it just performance wise or 50/50 concentration would be hard on the hardware? I live in one of the coldest city in Canada during winter (outdoor temp can hit -40 to -50 degrees Celsius) and the car will be park outside. I would prefer to drain the system instead of putting coolant that would ware it.
Greacemonkey is offline   Reply With Quote
Old 09-14-2018, 01:56 PM   #1204
gtengr
Drives: 2017 BRZ
Do any front strut bars fit? Anyone looked into fabbing a curved one?
gtengr is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
