Old 01-27-2014, 07:43 PM   #1191
jamesm
Originally Posted by lexusb3 View Post
Heard he happy too lol better make it down to south Florida I told him we can trade cars to see how it rides lol
we're getting it dialed in pretty good.. not as good as i'd like, but it's coming along. they're never as good as i'd like lol.
Old 01-27-2014, 08:57 PM   #1192
lexusb3
Drives: FRS
Nothing's every perfect lol
lexusb3 is offline   Reply With Quote
Old 01-28-2014, 12:10 PM   #1193
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
I thought your car was
Ny Brz is offline   Reply With Quote
Old 01-28-2014, 02:12 PM   #1194
lexusb3
Drives: FRS
Old 01-28-2014, 02:57 PM   #1195
Mild2Wild
Drives: Firestorm FR-S
Hey guys thought I'd share that after many trips to buy parts missing from my kit and modifications to what was sent, my 60trim kit is installed and working pretty well. Running a basemap for 7psi at the moment. Only problem seen so far is check engine light comes on for a variety of dtcs.
Mild2Wild is offline   Reply With Quote
The Following User Says Thank You to Mild2Wild For This Useful Post:
pixel67 (01-28-2014)
Old 01-29-2014, 07:54 AM   #1196
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Never had any DTC from the base map I used. What are the DTCs?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-29-2014, 08:15 AM   #1197
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Speaking of which, my new results.
I really enjoy how this system makes power. There isn't instantaneous throw a rod through the block torque. The boost builds smoothly and consistently to the redline, which will preserve the motor. After running at these levels, I dialed the boost back from 8.8psi to 7.8-8.
2 flaws with this system:
1) MAF Placement
The MAF flange is directly after a bend. There isn't a problem with WOT but during partial throttle cruising, with a 3" charge pipe, air may not move through the MAF but instead around it and could lead to some skewed fuel trims. It'll take time to get the MAF scaling right and trims dialed in properly with this design.
I'm working with Toni to implement a running design change for the MAF flange to be placed on a straight section and not immediately after a bend.
2) Secondary O2 Placement
Toni has already implemented a change for this issue but it was rolled out after I got my system in August.
If the secondary O2 sensor needs to be changed, it's location will require a lot of work to do so. The sensor's harness is a few MMs from the bottom of the engine block. To change it you'll have to unbolt the downpipe from the over pipe, loosen the v-band for the header to the secondary pipe and v-band for the downpipe to the turbo. It won't be fun or quick.
The newer kits, especially those with the hi-flow cat, will have their sensor lower on the downpipe so nothing obstructs access to it.
The Following 2 Users Say Thank You to ecko04 For This Useful Post:
EAGLE5 (01-29-2014), jamesm (01-29-2014)
Old 01-29-2014, 08:37 AM   #1198
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by PineappleFriedRice View Post
So I decided I want to go WMI with my set up. I have a nozzle and I'm thinking about mounting it on the coupler between the map sensor and the throttle body. Anyone know the size of that coupler? I think its a 2.5 but im not sure.
*MAF sensor and the throttle body?
That's a 3" coupler since the charge pipe itself is 3" coming off the throttle body then tapers to 2.75" or 2.5" pipe going to the intercooler.
The Following User Says Thank You to ecko04 For This Useful Post:
PineappleFriedRice (01-29-2014)
Old 01-29-2014, 08:38 AM   #1199
FA20Club.com
Drives: 2013 White Out FR-S
feel free to send the list of dtc you have so i can look over your base map. you honestly shouldnt have any codes to speak of normally.
FA20Club.com is offline   Reply With Quote
Old 01-29-2014, 08:45 AM   #1200
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Yes MAF is what I meant, thanks!
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 01-29-2014, 04:56 PM   #1201
Mild2Wild
Initially I had a p0068 and c1201 and briefly a p0302. After clearing them yesterday they have not returned. It's been very cold here, around 5 degrees and lower, I think that may have had something to do with the c1201. The p0302 was probably caused by my EBC duty cycle being set too low, interfering with the requested peak boost of the tune; if the engine was getting enough fuel for 10psi but only receiving the volume afforded by 7psi it my have caused the misfire.
Old 02-02-2014, 02:08 PM   #1202
tg_1981
http://instagram.com/win_2135
Check out the vid Toni adds another car to the 400+ mustang dyno club
tg_1981 is offline   Reply With Quote
Old 02-02-2014, 03:05 PM   #1203
lexusb3
Drives: FRS
hey ill upload that video from my camera as well and send it to you sometime today! i missed the pizza
Old 02-02-2014, 09:46 PM   #1204
tg_1981
thanks again for the e-55...LOL i got back to orlando first station i hit brought the content up to 78!!!! I want to dyno the car again when we have a cold front in Florida. Making power in this heat ain't easy.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
