#1191 |
Drives: tezla
#1192 |
Drives: 2013 Rally Blue Subaru BRZ Limited
Sorry for the late post when I installed strut bar I used cheap torque wrench which was set to 12 ftlbs but bolts were over torqued and even though the bolts did not totally snap the were damaged. After applying alot of hard time on the car bolts gave way and totally snapped thats why they were still in the holes and easy to find. I cant say this enough buy quality tools! Since the incident ive drilled out old studs and replaaced the studs with better materials. Sorry Grimmspeed
#1193 | |
Drives: Skoda Yeti DSG diesel 4x4
Also, to make sure none of the load from the movement of the towers is taken as shear loading by the studs, I think the brace should be centred over those studs. Making sure there is an even clearance around them all before carefully fitting the nuts and making sure it doesn't move as it's nipped into place before torqueing it up. That might being going over the top but it wont do any harm. Just cleaned up the logo on mine with a file, wet and dry and some polish. Looks good. |
#1194 |
The Mechanic
Drives: Civic Turbo,FR-S
sooo how about a solid rear strut bar?
#1195 |
#1196 | |
Because compromise ®
Drives: Red Herring
#1197 |
The Mechanic
thanks. didnt see that
hm true, but they can still flex as well as carrying 49% of the weight. acceling out of turns applies even more pressure
#1198 | |
modern cars are built so much better than when strut tower bars were helpful. so i dont think these strut bars do much in terms of performance. i can see maybe getting a little more responsiveness but thats because the fronts are steering. i dont think there would even be a subjective improvement with a rear shock brace. |
#1199 | |
The Mechanic
#1200 |
Drives: 2015 WRX
Just installed mine and I was pleasantly surprised at how easy it was. I can tell this bar had a lot of thought put into it and the quality is amazing. After a quick test drive I can say that I can definitely feel the difference. Thanks Grimmspeed for making a great product!
#1201 |
Potato Farmer
Drives: #SLOBRZ
So has there been any word on some triangulation bars to match?
Something something butter..
www.vic86brzclub.com |
#1202 |
Drives: '13 BRZ Ltd WRB
I thought they decided against it because there was no noticeable gain from upgrading those.
#1203 | |
Potato Farmer
Drives: #SLOBRZ
Maybe ill make some or send the stock ones off to be powdercoated.. :\
#1204 |
Drives: 2013 FRS, 2008 R32
Love my GS bar.
| Anyone using the STi Flexible Strut Tower Brace? | ngabdala | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 08-15-2019 01:59 AM |
| F/S Beatrush Strut Tower Brace Type-2 $175 | Dan-in-Japan | Brakes, Suspension, Chassis | 2 | 02-24-2013 01:38 PM |
| FT-86 SpeedFactory Strut Tower Brace Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-07-2013 04:31 AM |
| DIY - Strut Tower Brace - FT-86 SpeedFactory | F1point4 | DIY (Do-It-Yourself) Guides | 4 | 10-28-2012 04:30 PM |
