#1191 |
Drives: AP2 S2000, S14 240sx
Sweet baby jesus... http://www.ft86club.com/forums/showt...09#post1728609
#1192 |
Site Moderator
Drives: Supra
I like doing these photo comparisons.
The Following 4 Users Say Thank You to vh_supra26 For This Useful Post: |
#1193 |
Off Topic
I was next to one on the road, and my first thought was that the S2K is a much smaller car. Now that I'm going back to look at the actual dimensions, it's really not. The S2K is about 4.5 inches shorter front to back, with a 7 inch shorter wheelbase, but it's about the same height and width. The front track is 2 inches narrower and the rear track is 1 inch narrower. So it's a little smaller, but not nearly as much as my initial impression made me think.
It's also about 800 lbs heavier, according to Motortrend. Interesting. |
#1194 | |
Site Moderator
Drives: Stuff
Uhmm unless the frs/brz are really 2050lbs or so... No. The brz limited is just under 100lbs lighter than a ap2, about the same weight as an ap1.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#1195 | |
Off Topic
Edit- ok, I'm a dumbass who can't math. One too many zeros there. |
#1196 |
the only point im making is that you cant just look at a car and figure out the aerodynamics. the xb is a more aerodynamic shape than the veyron. whether or not the xb is bigger shouldnt change that point.
#1197 | |
Using just the Cd to say a car is aerodynamic, is like judging an engine by it's torque output. |
#1198 |
Uh...Cd is "coefficient of drag", which means it's just a number or factor you use to the overall equation. You still need to figure out the area to find out the force of drag applied to the vehicle itself...
#1199 | |
also, would the size of a car alter the cd? |
#1200 |
Drives: small
Frontal surface (rough brick estimate) to drag area:
FRS - 24.56 sq ft x 0.28 = 6.88 sq ft Veyron - 25.19 sq ft x 0.35 = 8.82 sq ft xB - 30.95 sq ft x 0.31 = 9.60 sq ft S2000 - 24.21 sq ft x 0.33 = 7.99 sq ft Lol, actually mixed up the xB and xA in my head. Forgot about the toaster... Last edited by Boxer486; 05-11-2014 at 02:32 PM. |
#1201 | |
CdA doesn't change with speed; Cd and A are both constants, as long as nothing is changing (active/passive aero). |
#1202 |
i would say your assumption about the veyron and xb thing was kind of off but im kinda over that topic. we can have different viewpoints but i still appreciate all your knowledge. i know cd and a are fixed. my question was probably less than clear. if you changed the scale of a car would it change the cd? like if you had a 4/5 scale frs would it have the same cd as our cars?
#1203 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | fatoni (05-11-2014) |
#1204 |
Drives: small
Yeah Cd has nothing to do with size. Behold one of the best Cd found in the animal kingdom 0.06.
http://www.the-scientist.com/?articl...d-the-boxfish/ ![]() |
The Following User Says Thank You to Boxer486 For This Useful Post: | CSG Mike (05-11-2014) |
FR-S vs S2000 | vang | FR-S / BRZ vs.... | 436 | 09-19-2012 04:52 PM |
E36 M3 vs FR-S vs S2000 (for me) | RearDrive | FR-S / BRZ vs.... | 48 | 07-02-2012 10:46 PM |
S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
