08-08-2019, 12:52 AM | #1191 | |
Drives: Red FRS
The Full Blown stg3 http://fullblownmotorsports.com/full...ort-block-1465 and MAP https://www.maperformance.com/produc...a20-ft86mss-s3 Dsport https://clubdsport.com/fa20/ There is IAG and Crawford as well. I dunno The advantage to Full blown is they are local and I could have them do the install Last edited by Conman; 08-08-2019 at 01:20 AM. |
08-14-2019, 03:17 PM | #1192 |
Drives: Red FRS
My engine shop recommended this engine. Any thoughts? https://www.rallysportdirect.com/par...ru-short-block
08-14-2019, 05:08 PM | #1193 | |
Driving Coach
Unless you are stuck with 91 octane fuel and you have no access to anything higher octane, I recommend a 12.5:1 block. |
The Following User Says Thank You to ATL BRZ For This Useful Post: | Conman (08-14-2019) |
08-14-2019, 05:14 PM | #1194 | |
Drives: Red FRS
08-14-2019, 05:20 PM | #1195 |
Driving Coach
Yes.
Big red flags. You should stick with HRI Tuning if possible. I would check and see if that shop would allow an experienced EcuTek tuner to tune your car with EcuTek on their dyno (HRI has done this before). If they don't, then seek an experienced EcuTek tuner elsewhere. |
08-14-2019, 05:29 PM | #1196 | |
Drives: Red FRS
08-14-2019, 05:38 PM | #1197 | |
Driving Coach
They have cars shipped to them from all over the country. Here's a BRZ build they completed recently. https://nationalspeedinc.com/2013-su...rz-shortblock/ |
08-15-2019, 09:29 AM | #1198 | |
Drives: Black BRZ
08-15-2019, 09:42 AM | #1199 |
Driving Coach
My bad. I responded in my build thread.
08-15-2019, 11:04 AM | #1200 | |
Drives: Q5 + BRZ + M796
I think a tuner could do boost by gear and progressive boost to reduce the risk of knock and preignition. They could also reduce the effective compression ratio below the static compression ratio with cam timing like the WRX does, but it might just be easier and safer to just use a lower compression motor. The detriments might not be that bad like the guy mentioned in the link. Like you said, if all he had was 91 and modest power goals like lower than 300whp then definitely he shouldn't lower compression. With E85, the risk diminishes, and he could hit his 400whp goals, but a lower compression motor would have more potential for more power later on, so I would advise reducing compression to at least 11:1, but closer to 10:1 would be ideal. The lower the compression ratio the more power potential the engine will have, but there obviously can be more lag. Porsche 718 Cayman uses 9.5:1, the BMW S55 uses 10.2:1, the B58 uses 11:1, the Mercedes engine below uses 9:1, but because it does, the torque comes on higher in the rpms, but as you can see, they are running 30psi on pump gas, so the motor hits over 400hp. An Evo's compression ratio was 9:1 and most would agree that 500hp was closer to the limit on that motor before piston/rods were needed, but I don't know how the stock piston/rods compare to the FA20. Just something to think about. https://carbuzz.com/news/mercedes-am...-making-416-hp https://www.motortrend.com/news/amg-...r-engine-specs
08-15-2019, 08:15 PM | #1201 |
Drives: JDL Turbo BRZ
Does anybody have a link/part number for the oil restrictor in the V2 kit for a GTX2860R Gen 2?
08-26-2019, 09:46 PM | #1202 |
Drives: 86
Is it possible for GTX2860 to make 300-350hp with 10:1 CR on 93 octane?
08-27-2019, 09:36 AM | #1203 |
Drives: 2014 BRZ
Yes
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
08-27-2019, 09:36 AM | #1204 |
Drives: 2014 BRZ
Although lowering the compression ratio to stay at that power level would be retarded.
Similar Threads | ||||
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
