Old 06-06-2017, 07:50 PM   #1177
86Tony
Drives: 2015 AOZORA EDITION
Originally Posted by rb6freak View Post
I'm not sure which off-the-shelf air oil cooler kit works with this kit. I'm using a Setrab series 9 15row sandwiched between the intercooler and AC condenser, but it is bolted to the bottom plastic tray with a home brewed bracket further securing it to the AC condenser. I believe the JR oil cooler bolts to the bottom of the crash beam right? I'm not entirely sure that would work. The intercooler bolts to the crash beam and hangs underneath it. You could relocate it to the same location I have here.
See my oil cooler here in front of the condenser.
Injectors are highly recommended. A friend of mine tuned with pump gas on stock injectors and was at about 85% duty cycle on the port injectors and the tuner didn't want to take it any further because of this. So he ended up getting new injectors. I'd recommend that too.
Pump not needed until you're going far beyond 350whp.
Thanks alot, your post was very helpful and gave me a good idea on how to setup the cooler, also which cc injectors do you recommend? 850cc or 1000
86Tony is offline   Reply With Quote
Old 06-06-2017, 11:46 PM   #1178
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
That depends on your power have goals. I have 770cc and I don't believe I've ever passed 50 percent duty cycle on the port injectors. Basically; 770cc is way more than I need for my setup, even when I run higher boost on 101 octane.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
Hicklinc (01-29-2018)
Old 06-07-2017, 12:17 AM   #1179
86Tony
Power goals are low 300 for now, mid 300 or so later down the road
Old 06-07-2017, 04:11 PM   #1180
ptuning
ptuning's Avatar
Drives: White FR-S
Which oil cooler will fit with this kit ? I currently have the jackson racing oil cooler will that still work?? Also do you need injectors and pump for 94 gas???
Hello Tony,
We have only confirmed fitment of our oil cooler kit on our turbo setup.
Here is the link to the PTUNING oil cooler kit:
http://www.ptuning.com/subdir/itemde...&ModelDesc=FRS
Thanks,
Mike @ PTUNING
ptuning is offline   Reply With Quote
Old 08-13-2017, 12:38 AM   #1181
NLS8520
Drives: N/A
@ptuning, what is the recommended weight ( and/or brand) motor oil for one of your turbo kits? (GTX2867R)
NLS8520 is offline   Reply With Quote
The Following User Says Thank You to NLS8520 For This Useful Post:
BlaqkHavok (08-18-2017)
Old 08-15-2017, 12:42 PM   #1182
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I would run whatever oil you use for your car NA, as long as you use an oil cooler and maintain your temperatures. I used 0w20 for most of the year and I'll switch to 5w30 for the 100 degree summer track days.
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-29-2018), NLS8520 (08-15-2017)
Old 08-15-2017, 01:07 PM   #1183
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
I would recommend 5w30 synthetic oil, Amsoil or Motul.
Freddy@PTUNING is offline   Reply With Quote
The Following 5 Users Say Thank You to Freddy@PTUNING For This Useful Post:
BlaqkHavok (08-18-2017), BRZ_Willy (08-23-2017), CxG (05-09-2018), Hicklinc (01-29-2018), NLS8520 (08-15-2017)
Old 09-29-2017, 05:01 PM   #1184
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Joined the PTuning FI club officially today. Installed and tuned on-site at PTuning on their Dyno Dynamics with Toan.
- 337hp / 265trq on 93 Pump gas (May have been like E14 with what was in the tank)
- 426hp / 337trq on E85 Flex (E73 on this pull I think)
Holy. Crap. I cannot wait to drive this thing. Need to let PTuning road test before the keys are turned over.
Any suggestions for maintenance changes? I'm assuming more frequent oil changes and spark plugs - lol. How is everyone else holding up?
SpectreRT is offline   Reply With Quote
The Following 3 Users Say Thank You to SpectreRT For This Useful Post:
Hicklinc (01-29-2018), Lonewolf (09-29-2017), rb6freak (09-30-2017)
Old 09-30-2017, 03:56 AM   #1185
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Welcome to the club, it never gets old hitting boost on the PTuning setup. Yes I'd recommend more frequent oil changes along with regular oil level checks. I change my oil every 3,000 miles myself for various reasons - primarily due to aftermarket setup and tune. Spark plugs I've changed once, didn't really need to by the looks of them. Just need to keep a closer eye on everything now and take care of the way you drive it.
I'm about 36K miles in on my turbo kit, everything's running just fine.
Old 10-08-2017, 09:34 AM   #1186
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
You're not kidding. Hearing this thing spool is a treat. The 2867R is so noisy - in the best of possible ways.
Going to put a blanket on it; even though this is mounted low - I can tell a major heat difference. Hood is vented; but it didnt help enough. Also with the turbo being next to the trans... I'd rather have some heat protection.
Anyone else go this route?
Old 10-08-2017, 01:48 PM   #1187
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Honestly you're fine. No need for a blanket. Me and a couple other Cali guys have already tracked this car and turbo setup - we've found any and all issues that have been addressed with the PTuning V2 and track add-on options such as sway bar shield. Just make sure you have an oil cooler that fits your needs and you're good to go.
Old 10-09-2017, 09:53 AM   #1188
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I went with the laminova oil cooler, as temps do not get quite as brutal over here as CA for example. I'll still be keeping a very close eye on it.
Old 10-09-2017, 11:13 AM   #1189
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Like Mike had stated. We do not recommend a heat blanket for the turbo due to it's location which gets plenty of airflow from under the vehicle. The heat you're seeing under the hood is due to the airflow extracting heat from the intercooler. Now you know why we don't want the turbo sitting right in front of the engine giving off additional radiant heat and contributing to even higher under hood temps. In addition, there's a heat shield between the turbine housing and transmission to shield some of the radiant heat away from the tranny.
MrC
Mrc@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
Hicklinc (01-29-2018), rb6freak (10-09-2017)
Old 10-10-2017, 10:02 AM   #1190
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
MrC
Ahh, understood. I'll have to let the guys at the shop know.
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
