Old 11-11-2017, 12:38 PM   #1163
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
So my activation issues were related to the two-year-old dump batteries. The voltage on one was below 12.5V. I replaced the ETX16Ls with two Odessey PC 680s and it feels like normal again. Still need to get some data just to confirm, but it definitely feels like it’s at full boost now. Still need to find out if I have the odor after full activation now that I have the check valve in the PCV line.
For those that are interested, here is the confirmatory data log.
https://datazap.me/u/vfrqqq/log-1510...=0&data=1-9-11
vfrqqq is offline   Reply With Quote
Old 12-10-2017, 04:05 AM   #1164
BuffDriver
Drives: 2016 Subaru BRZ
Update: Installed Sojhinn's kit and have been etuning with Shiv...
I LOVE THIS ESC! ! !
THANK YOU again for letting me buy it, Sojhinn.
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
Old 12-10-2017, 02:32 PM   #1165
R2
My kit is still for sale, now with an updated price!
http://www.ft86club.com/forums/showthread.php?t=122395
R2 is offline   Reply With Quote
Old 02-02-2018, 11:44 AM   #1166
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
my battery is dead completely due to not driving for while.
is it ok to jump from other car?
Old 02-02-2018, 12:52 PM   #1167
R2
http://www.ft86club.com/forums/showp...9&postcount=11
The Following User Says Thank You to R2 For This Useful Post:
zc06_kisstherain (02-02-2018)
Old 02-06-2018, 03:58 PM   #1168
tzbang
Drives: 2013 GT86
So I've recently installed one of these kits. Mine needed to be modified a bit for RHD, so extended (fatter) cables etc.
Anyway - everything seemed to go good for the first few weeks, probably taken the car out a handful of times. But this morning it wouldn't start. The small battery which runs the car didn't have enough charge to turn the car over. I tried jumping the battery from a spare and although I eventually got it running.. it was running rough and hardly at all. I assume there still wasn't enough charge for the ECU.
A few days ago I did mess around with the pedal switch placement.. and I did notice that for some reason when I turned the ignition on the ESC started whirring away.. which was odd. I switched it off using the little volt switch. Then it seemed fine. I put the car back in the shed and that was a few days ago.. now it won't start.
I figure messing with the pedal switch etc is irrelevant as that is on the other battery system. So maybe it's just because I started the car up a couple of times without driving? It's not going to be a very reliable system if I can't turn the car on and off a couple of times.
All the batteries were bought new.. but I have to admit.. they sat on the bench unused (on a trickle charge) for over a year before I installed them.
tzbang is offline   Reply With Quote
Old 02-06-2018, 04:32 PM   #1169
DAEMANO
Time Traveller
Battery condition is key with these kits and with a compact starter you won't have nearly the reserve that you had with a full size OEM battery.
I would recommend that you get a new starter battery.
I consider the dump pack and starter battery as wear items. The starter battery about 2 years unless it is jump started several times. The dumps should last 1.5 years till they start to degrade, and should be replaced by 2 years.
Old 02-06-2018, 06:23 PM   #1170
tzbang
Drives: 2013 GT86
The battery was brand new.. but I guess leaving it on a trickle charger for 15months might not have been great for it. But still.. I'm surprised it only lasted 2 weeks of use. There must have been some kind of draw on it for the last 3 days while it was not being used.. Is it a known issue that the car electrical system drains the compact starter battery quickly?
Old 02-07-2018, 12:05 AM   #1171
Gums
Drives: SWP BRZ
Had similar issue with the ESC running (sometimes) with ignition on. Solved by installing a seperate switch for the ESC/Procede.
Car has an anti rust unit, starter battery will only last a week without C-Tec charger. Basically plug charger in every time I get home. Expecting battery to fail at some stage as it's over 3 years old.
Gums is offline   Reply With Quote
Old 02-07-2018, 08:07 PM   #1172
tzbang
Drives: 2013 GT86
Well I solved this one I think.. and it's a bit embarrassing. The battery was flat.. this much is true. I found out that my boot was left open for 3 days sitting in the shed. So I'm guessing that was enough to flatten my battery. But it didn't explain why when I jumped it - she ran so terribly rough.. spluttering.. dying. I thought the battery was full stuffed and wasn't taking a charge. But it seemed odd..
It was like.. like it wasn't getting any air in. Suffocating. Then I wondered.. if I'd removed the tape I'd put over the air-filer intake as I made a small cut so I could mount the ESC straighter. The answer was no I hadn't.
The Following User Says Thank You to tzbang For This Useful Post:
DAEMANO (02-13-2018)
Old 02-13-2018, 02:42 PM   #1173
zc06_kisstherain
Drives: SWP BRZ
remember you jumped a car so ECU needs time to re-learn.
drive for few days then push it.
BTW, how hard did you tighten your clamp?
Old 02-13-2018, 07:12 PM   #1174
DAEMANO
Time Traveller
Haha, so how does it feel now?
Old 12-10-2018, 12:27 PM   #1175
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
In case anyone is interested, I'm selling my PROcede controller.
http://www.ft86club.com/forums/showthread.php?t=131826
Old 12-17-2018, 10:30 AM   #1176
BlOody_BoOger
BlOody_BoOger's Avatar
Anyone ever tried openning apart the snail to change out the propeller for a lighter one?
Sent from my SM-G935T using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
