Old 03-20-2017, 03:50 PM   #1163
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Originally Posted by nos145 View Post
*whiny voice* any luck w that automatic setup?
i love my auto but I am having an existential crisis because no ptuning turbo for it Q.Q
Originally Posted by Silent_Dan View Post
As an automatic owner also I wish to have a p-tuning turbo on my car also but I don't see it happening though .
Please reconsider making a kit for the auto owners.
We've had a handful of inquiries over the past few years for an automatic version. But due to the larger size of the A/T vs the M/T, It would require re-engineering a completely different overpipe, turbo placement, downpipe and all the other hotside components and brackets. At this time there's just not a real demand, as in 25+ kits, to justify the R&D on an A/T version.
Mrc@ptuning is offline   Reply With Quote
Old 03-21-2017, 11:53 AM   #1164
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Going to dyno tonight on both 91/101 octane tunes. Can't wait to see what kind of power I'm putting down at 14.5 PSI (101) on the 2867!
rb6freak is offline   Reply With Quote
The Following 3 Users Say Thank You to rb6freak For This Useful Post:
JBezugs (04-15-2017), kanundrum (03-21-2017), Mrc@ptuning (03-21-2017)
Old 03-21-2017, 11:19 PM   #1165
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
274/217 at 12.7 PSI on Evasive Motorsports Mustang Dyno
The Following 6 Users Say Thank You to rb6freak For This Useful Post:
CxG (03-30-2017), Hicklinc (01-29-2018), Joe's86 (03-23-2017), kanundrum (03-22-2017), mkivsoopra (03-22-2017), Mrc@ptuning (03-22-2017)
Old 03-22-2017, 03:42 PM   #1166
Silent_Dan
Drives: 2013 Scion FRS
So that is what it will take for you to consider making one?
I'm sure we can get that easy.
Silent_Dan is offline   Reply With Quote
The Following User Says Thank You to Silent_Dan For This Useful Post:
nos145 (03-27-2017)
Old 03-27-2017, 12:33 AM   #1167
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
I co-own a mechanical engineering company.
I would be willing to put an engineer on the project if you are interested in partnership. I am talking flow analysis and all the bells and whistles.
Send me a DM with contact info for further discussion please.
nos145 is offline   Reply With Quote
Old 04-08-2017, 12:21 AM   #1168
Joe's86
Drives: 99 eclipse RS
was that dyno pull with 91 or 101?
and are you running the gt or the gtx 2867r?
Joe's86 is offline   Reply With Quote
Old 04-08-2017, 09:56 AM   #1169
BRZ_Willy
BRZ_Willy's Avatar
Drives: 2016 WRB Subaru BRZ
His build thread says Garrett GTX2867R. Not sure of fuel though.
BRZ_Willy is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ_Willy For This Useful Post:
Joe's86 (04-10-2017), rb6freak (04-08-2017)
Old 04-08-2017, 03:47 PM   #1170
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
That pull was with 101 octane in the tank, running about 1 and 2/3rds degrees more timing over my 91 octane tune. I could have run another couple PSI to squeeze more power which the 101 tune was setup for, but I only got 3 pulls total at Evasive so I didn't get to do all that I wanted.
GTX2867R with 7lbs waste gate spring and 70 % duty cycle on the boost solenoid on that dyno pull.
Old 04-08-2017, 03:53 PM   #1171
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Here is the 91/101 tune and pull overlay. I instructed the tech to do lower boost on the 91, but according to the chart he did the higher boost setting. I don't know though, I think maybe they mixed up the 3 charts. It's possible, but hard to believe 1.66 degrees more timing added that much power. The 91 octane tune is set to about 9psi where as the 101 I can do upwards of 14 (was 12.7 in the pulls on the dyno).
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-29-2018), Joe's86 (04-10-2017)
Old 04-13-2017, 04:55 PM   #1172
Joe's86
are you still happy with the switch from the 3076 to 2867?
Old 04-13-2017, 06:47 PM   #1173
Xevuhtess7
Why does it take all the way til 6400rpm to build peak boost?....
Xevuhtess7 is offline   Reply With Quote
Old 04-13-2017, 08:39 PM   #1174
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Yes, very. More so with all of the V2 upgrades and the fact that its easier for installation/maintenance with the smaller turbo.
My boost solenoid is very basic (AEM Tru Boost), at 1PSI its set to ramp up spool until 6PSI (my WasteGate configuration), and then maintains 70% duty cycle. My tuner said he could run circles around this setup if I plugged in the solenoid 5V/ground to the ECU so he could control it, but I already have my gauge cluster setup and I kind of like having the flexibility to adjust.
If I set the solenoid to a higher WG spring number or use stronger spring in my wastegate, I could achieve peak boost much sooner, but I like it this way. Also note this is a 4th gear pull on a dyno starting the pull at 3K.
The Following User Says Thank You to rb6freak For This Useful Post:
Joe's86 (04-15-2017)
Old 06-06-2017, 11:21 AM   #1175
86Tony
Drives: 2015 AOZORA EDITION
Which oil cooler will fit with this kit ? I currently have the jackson racing oil cooler will that still work?? Also do you need injectors and pump for 94 gas???
86Tony is offline   Reply With Quote
Old 06-06-2017, 12:51 PM   #1176
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I'm not sure which off-the-shelf air oil cooler kit works with this kit. I'm using a Setrab series 9 15row sandwiched between the intercooler and AC condenser, but it is bolted to the bottom plastic tray with a home brewed bracket further securing it to the AC condenser. I believe the JR oil cooler bolts to the bottom of the crash beam right? I'm not entirely sure that would work. The intercooler bolts to the crash beam and hangs underneath it. You could relocate it to the same location I have here.
See my oil cooler here in front of the condenser.
Injectors are highly recommended. A friend of mine tuned with pump gas on stock injectors and was at about 85% duty cycle on the port injectors and the tuner didn't want to take it any further because of this. So he ended up getting new injectors. I'd recommend that too.
Pump not needed until you're going far beyond 350whp.
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
