Old 05-18-2015, 12:18 PM   #11733
Pkush
Originally Posted by DGMlJDlBRZ View Post
lol thanks. people driving behind me tend to get a kick out of it.
and yes, I had to tap into the blinker wire on the headlight harness.
fteightysix has a video on youtube on how to install these sidemarkers. first half of the video is for the frs, second half of the video is for the brz.
Where can I get the sticker?
I'll need some protective gear along with it when my lady sees it
Pkush is offline   Reply With Quote
Old 05-18-2015, 01:44 PM   #11734
DGMlJDlBRZ
DGMlJDlBRZ's Avatar
Drives: 2014 DGM BRZ
Lol, i got it off ebay from seller streetfxx. Not sure if he still has them up for sale.
DGMlJDlBRZ is offline   Reply With Quote
Old 05-18-2015, 02:13 PM   #11735
hello86
Changed the transmission fluid to Motul 300. Held up well at the track. I have to say after some track events and 16,000 miles of driving, the fluid didn't seem too bad, and the dragnet didn't have too much debris on it, but I'm not too experienced.
I also installed SPC Camber bolts. I could only get -1 out of the right wheel and -1.5 out of the left. I bought a 5 year alignment from a certain franchise. A small Italian mechanic and I basically aligned the car together. He went in the back and got two smaller diameter bolts to put through the top holes and got it to -2.5 in the front. I'm maxed at -1 in the rear. The turn in is drastically improved and the car seems a tad looser now on corner exit. Tire wear is also better.
hello86 is offline   Reply With Quote
Old 05-18-2015, 02:39 PM   #11736
Pkush
They don't, just looked through their inventory.
I have no idea how to google search for that sticker...like how do you describe it? lol
Old 05-18-2015, 03:05 PM   #11737
Porcupint
Drives: 13 GBS BRZ
You do your fair share of SEO and you learn how to search for anything. "two loves brz decal" is what I googled.
http://www.ebay.com/itm/STICKER-LOVE...-/170880350955
And also here http://www.ft86club.com/forums/showthread.php?t=11791
Porcupint is offline   Reply With Quote
Old 05-18-2015, 03:10 PM   #11738
Pkush
Well, Search Engine optimization would teach you to use google like a pro. I'm no pro and thank you for finding that for me!
Old 05-18-2015, 03:28 PM   #11739
ARTBRZ
Aloha!
ARTBRZ's Avatar
Recently installed dual color led sidemarkers from fteightysix. White LED is hooked up to the parking lights, while the amber LEDs are hooked up to the turn signals.
Also installed some RokBlokz short version mudflaps. Was tired of finding rock chips on the edge of my fenders and lower corner/edge of the rocker panel
So shiny!
Is that a Bayson R side skirt? If so, have you noticed any warping because of the material?
ARTBRZ is offline   Reply With Quote
Old 05-18-2015, 04:40 PM   #11740
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
Originally Posted by miosaki View Post
Started to work on the front bumper lip and rear spats this weekend.
Applied primer, black paint coat, and matte clear coat. Sandpaper in-between for the bumps and uneven parts.
Leaving them to dry for a couple of days before install.
Attachment 109925
Lots of time to kill while waiting for the coats to dry. Playing around with the spray paint.
Attachment 109924
What kind of lip and spats did you get? I'm tryna get some for mine too lol
scottxnizzle is offline   Reply With Quote
Old 05-18-2015, 04:48 PM   #11741
uEih
Drives: CBS Subaru BRZ Limited
Attachment 109925
Attachment 109924
Would love to see the finished product, painted my lip about a year ago with flat black and some sanding but no primer or clear coat so it seems like it's not withstanding and fading a bit. Planning to redo it this summer this time the proper way so it'll last more than just a year.
uEih is offline   Reply With Quote
Old 05-18-2015, 05:28 PM   #11742
rlpaul
Drives: point A to point C. Screw point B!
Installed TOM's taillights.
rlpaul is offline   Reply With Quote
Old 05-18-2015, 06:03 PM   #11743
DGMlJDlBRZ
DGMlJDlBRZ's Avatar
Originally Posted by ARTBRZ View Post
So shiny!
Yes it is. I do notice some warping, mostly where the screws/bolts were installed onto the car. It almost looks ike the material bulges out where the hardware is. In person I cant tell, but in pics you notice the warping.
Old 05-18-2015, 09:10 PM   #11744
immortal_suby
Drives: 2015 BRZ Limited 6MT
Originally Posted by Kiske View Post
Acoording to DSOmegaX in another thread (subaru ts parts) The Ts axles are a larger diameter and weight is the same as the stock parts. He also said the larger diameter of the axles allow more torque to transfer per rotation due to the larger size.
Wow.
Blatant disregard for the truth.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Old 05-18-2015, 09:22 PM   #11745
cjd
cjd's Avatar
Drives: 2017 BRZ
Today, I splattered a large portion of the front of my BRZ with bug innards. I think they work like golf ball dimples, lowering drag coefficient... From the far northern tip of lower MI back to Chicago.
Will have to try to give the car a bath before I go racing Sunday (and probably splatter the front with bugs all over again...)
Old 05-18-2015, 09:28 PM   #11746
austinbrz
austinbrz's Avatar
Drives: 2015 BRZ Limited (Crystal Black)
High Mount Brake Light Install
Starship Enterprise deleted and High Mount Brake Light installed.
austinbrz is offline   Reply With Quote
