04-26-2015, 10:04 AM | #11495 | |
Go Big Red!!
Drives: 2013 SSM BRZ Limited
I removed the top half of the third brake light since the bottom half comes out with the rear deck. The only reason I haven't removed the rear deck to totally get rid of the housing is time/help to do it without bending it. As far as the holes, the intec light comes with pieces to cover the holes once you remove the stock light. |
The Following User Says Thank You to Husker BRZ For This Useful Post: | brz604 (04-27-2015) |
04-26-2015, 05:20 PM | #11496 | |
Drives: SWP BRZ Limited Manual. 2014
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
04-26-2015, 05:35 PM | #11497 |
Drives: Toyota GT86
View out of the back is so much better with the stock light removed.
http://i58.tinypic.com/sd3ear.jpg |
The Following 4 Users Say Thank You to GT86-Ian For This Useful Post: |
04-26-2015, 05:45 PM | #11498 | |
Drives: CWP series blue brz
Sent from brick |
04-26-2015, 07:15 PM | #11499 |
Drives: 2013 Subaru BRZ
Led Foglights. 6K on the right. 3K Yellow on the left. Choices!
The Following User Says Thank You to Euro7R For This Useful Post: | Choco (04-27-2015) |
04-26-2015, 08:42 PM | #11500 |
Drives: Subaru BRZ Limited
Painted STi style fromt lip and rear spats matte black and put them, I'm liking the look but will probably get them color matched
The Following User Says Thank You to JDsThatGuy For This Useful Post: | Choco (04-27-2015) |
04-26-2015, 09:15 PM | #11501 |
Drives: 2015 BRZ Limited
Little bit of this:
And a little bit of that: But mostly just a lot of this:
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS |
The Following User Says Thank You to dar3d3vil For This Useful Post: | Choco (04-27-2015) |
04-26-2015, 09:52 PM | #11502 |
They didn't give me laffy taffys with my yellows! I love laffy taffys
Drop several gears and become slightly further away
The Following User Says Thank You to TilesMeague For This Useful Post: | Choco (04-27-2015) |
04-26-2015, 10:02 PM | #11503 | |
F Z1LLA
Drives: Lexus IS-F Series 2
How was install ? Thinking of doing mine soon
2URGSE |
04-26-2015, 10:33 PM | #11504 |
Drives: 2013 BRZ SWP
Finally got a chance to put on the CS front, sides and rear spats with rear oe diffuser Had time after so put the Diode Dynamics turn tails on too.
04-26-2015, 11:06 PM | #11505 | |
Go Big Red!!
Install is fairly simple. To install I only removed the cover on the passenger side C pillar to route the wire to the trunk, there is a hole just big enough to get the connector thru to the trunk without taking everything apart. Let me know if you want pics of how I routed the wire and I can take some and post it! If you go the INTEC route, I would recommend getting some black double sided tape and putting some on each side edge as well as the front edge. I should have taken pictures but I forgot. When I initially installed the light the front edge that sits by the window wasn't completely flush so I took the light down and put the tape all the way around. If you're interested I could send you a link to the tape I used, I just have to find it again lol. It's supposed to be strong enough to withstand constant heat from window but not leave residue or ruin tint. |
The Following User Says Thank You to Husker BRZ For This Useful Post: | JPxM0Dz (04-26-2015) |
04-26-2015, 11:22 PM | #11506 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
Just installed an Openflash Header to complete my exhaust. I've been in love with the Subaru rumble since I was young and finally I've got it. Current setup is 2.5 Perrin resonated with Perrin Catted Front Pipe and Perrin Overpipe. The sound is fantastic. There is no rasp, there is no drone. You barely notice it unless you put the engine under load. I was preparing to have to settle for some rasp from all the samples I've heard, but there is none. It's a solid deep rumble. Could not be happier! Now I'm letting the car learn the new OFT tune that I loaded up.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
04-26-2015, 11:56 PM | #11507 |
Drives: 2010 MS3
Tsudo CBE out. Borla in.
Stock fluid from transmission and differential out. Motul 300 in. Had so much gunk in the fluid. The shifting feels much smoother. It feels sorta healthier too, probably in head. haha |
04-27-2015, 12:01 AM | #11508 | |
Drives: 2019 BMW ///M4
I like What does the back of your car look like now? And is this Dog Haus in Alhambra?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
