04-15-2018, 09:36 PM | #1135 | |
As for the 2017+ cars, they dyno'd at more like 10-15whp over stock 2013-2016 cars. Realistically the early cars were more like 190hp, and the 2017+ are a more accurate 205hp.
The Following User Says Thank You to wparsons For This Useful Post: | nikitopo (04-16-2018) |
04-16-2018, 02:05 AM | #1136 | |
Drives: '15 BRZ RA
04-16-2018, 09:49 AM | #1137 | ||||
Only happy when it rains.
Drives: series.blue
04-16-2018, 10:15 AM | #1138 | |
Do you have better tires? Wouldn't that account for a lot of the acceleration differences you are talking about? |
04-16-2018, 10:42 AM | #1139 | |
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
04-16-2018, 11:21 AM | #1140 | |
Drives: '15 BRZ RA
I didn't measure all the before and after changes, so I cannot tell which one gave the most. My last change was a lightweight flywheel change which gave a 6% gain in a 2nd gear pull. Details here: http://www.ft86club.com/forums/showp...7&postcount=74 |
The Following User Says Thank You to nikitopo For This Useful Post: | Yoshoobaroo (04-16-2018) |
04-16-2018, 12:21 PM | #1141 |
Drives: '23 BRZ
But even +15hp for '17+ seems very optimistic to me. Mag tests showed about a tenth of a second improvement in 0-16 and 1/4-mile which could be attributed to diff ratio change from 4.1 to 4.3. 1/4-mile trap speed unchanged, which suggests no additional power. Or only enough to offset a slight weight gain.
The Following User Says Thank You to ZDan For This Useful Post: | funwheeldrive (04-16-2018) |
04-16-2018, 12:37 PM | #1142 | |
Drives: '15 BRZ RA
In other regions same trim levels were ~20kg lighter. And a 4.3 fd doesn't mean that will make you EVERYWHERE faster. In certain tests it can give worse results comparing to a 4.1 fd. It depends the test. |
04-16-2018, 01:03 PM | #1143 | |
Drives: '23 BRZ
Yeah, about 50 lb. But it's not enough to allow for '17+ cars having +15 more hp, more like the advertised +5hp
Power/weight with driver: pre-'17 (2770 lb. + 170 lb.)/200hp = 14.7 lb/hp '17+ PP (2820 lb. + 170 lb.)/205hp = 14.6 lb/hp Quote:
0-57mph, 4.1 would have a HUGE advantage, on the order of 1/2 a second, due to no 2-3 upshift. But that's not the case here. |
04-16-2018, 01:26 PM | #1144 | |
Drives: '12 C63 P31, '23 GRC
If you want to cry about exhaust emissions, point your ire towards the soot emitted by direct injection gasoline engines. Which is considerably worse for the environment, and yet also legal.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
04-16-2018, 02:30 PM | #1145 | |
Drives: 2005 Toyota Camry
A catalytic converter is still vital to reduce CO and NOx emissions. There's no other solution out there that is as simple and as cost effective. |
The Following User Says Thank You to mav1178 For This Useful Post: | nikitopo (04-16-2018) |
04-16-2018, 02:37 PM | #1146 | |
Drives: '15 BRZ RA
You are correct. It depends also WHEN the tests were performed. Check a dyno test of a stock '17 BRZ here: http://www.ft86club.com/forums/showp...28&postcount=1 On first run the AFR is similar to an aftermarket tune. On second run it starts adding fuel, the AFR is getting similar with pre-'17 cars and it loses power. This is also the reason why we never agreed in the forum if the actual gain was +5hp or +15hp. I mean apart from catalog numbers. Last edited by nikitopo; 04-16-2018 at 02:56 PM. |
04-16-2018, 02:57 PM | #1147 | |
Drives: '23 BRZ
Fact is, 2017+ cars are testing at the same 1/4-mile trap speeds vs the previous cars, and lo the weight difference between non-PP Limiteds isn't all that much after all, 2764 lb. for 2013 and 2777 lb. for 2017: https://www.caranddriver.com/reviews...ed-test-review https://www.caranddriver.com/reviews...al-test-review 1 tenth quicker, 0mph faster in the 1/4 at the same weight. I don't think the 17+ are making much if any more real-world usable power. |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | DarkSunrise (04-16-2018), Tcoat (04-16-2018) |
04-16-2018, 03:11 PM | #1148 | |
pessimistic skeptic
The Following 3 Users Say Thank You to mrg666 For This Useful Post: |
Similar Threads | ||||
WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission | SteelReign | Cars for Sale/Trade | 5 | 06-22-2015 02:01 PM |
2016 mazda miata (MX5) reveal 9 PM EST | Ernie L | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-03-2014 08:41 PM |
FS: Supercharged 1992 Mazda Miata *$4000 OBO* | BRZZZZZZZZZZ | Canada Classifieds | 5 | 08-18-2014 04:44 PM |
The Mazda 2 trully the FWD Miata NA! | Tbomb 25 | Other Vehicles & General Automotive Discussions | 24 | 01-14-2013 09:30 AM |
