Old 03-31-2014, 03:17 PM   #1135
wparsons
wparsons's Avatar
Originally Posted by 7thgear View Post
this will not affect geometry though
True, SIA would be the same, but the strut would be more upright
flickr
Old 03-31-2014, 03:55 PM   #1136
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Tire pressure is perfect on all four corners. I think it could be that I haven't had a chance to fully adjust the ride height equally, one side is slightly lower than the other.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 03-31-2014, 03:57 PM   #1137
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you'll need to re-do your alignment if you re-adjust your heights...
did your alignment shop give you a printout? Did they do the alignment with you in the car?
Old 03-31-2014, 03:58 PM   #1138
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
It should be on file. I'll have to adjust the height and get the control arms for the rear and re align it
Old 03-31-2014, 04:01 PM   #1139
Ben_G
Drives: Blue BRZ
Ok...maybe this isn't the right thread to ask, but I guess it's suspension related. I've always wondered about upgrading things like control arms and links that are attached to chassis pick up points. Let's say you upgrade these parts for whatever reason (adjustability, rice factor, lighter, etc) and they are stronger and stiffer than OEM stamped steel pieces, could the higher strength of these pieces end up causing even problem by messing up the pick up points on the chassis in an accident? In other words, are 'weaker' OEM pieces better designed for street driving incidents? (if you are racecar, then I would assume that you can fix any chassis issues)
Ben_G is offline   Reply With Quote
Old 03-31-2014, 05:02 PM   #1140
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Depends on the specific part, but for example an Aluminum control arm will bend the subframe instead of a steel control arm if you hit a rock. If thats what you mean...
Kostamojen is offline   Reply With Quote
Old 03-31-2014, 05:14 PM   #1141
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
What about 9k all round? Or, 10k all around? -DII street tires
1k staggered with stiffer rear vs 2k staggered stiffer rear
Wouldn't 2k stiffer more in rear be too much? (ie: 10k 12k) ...but I notice a few people sometimes recommending a 2k stagger. I am sure 1kg stagger would be fine...not sure about 2kg stagger tho...sounds like a big difference (I'm prolly wrong tho)
fooddude is offline   Reply With Quote
Old 03-31-2014, 08:06 PM   #1142
Ben_G
Drives: Blue BRZ
yes, that's pretty much what I mean.
Old 03-31-2014, 11:04 PM   #1143
Turdinator
Señor Member
Turdinator's Avatar
You might want to provide some more info about your cars intended use and what coilovers you will be looking to run those rates on. They seem very high for a street car.
1974 TA22 Celica
2013 86 GT
Old 04-01-2014, 12:00 AM   #1144
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by CSG David View Post
Yup. A lot of guys who simply just street keep talking about control arm rigidity as if they are the suspension gurus. The arms bend because they are designed to bend during an impact. Obviously if you want to extract the very most out of your suspension, these control arms will be replaced by some nice pieces, but you're also trading it off for potential deflection in the chassis. The energy has to go somewhere.
Everything's a compromise.
Old 04-01-2014, 11:33 AM   #1145
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Ok well here's another question. I have the HKS GT coils. Not that bad for spirited driving but I want something more for track use. Want to swap out the springs for some swifts. It's got 6k front and 4.5k rear I believe. I was thinking 7k front and 6k rear.but want some input. I love the coils right now for daily and comfortable for my 6 month son but I want something competetive
Old 04-01-2014, 12:30 PM   #1146
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
[ame="https://www.youtube.com/watch?v=xOtFJ-NcsHQ"]FCM Suspension Truth v2.3 - How Shocks Work - Rally setups - YouTube[/ame]
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
Dimman (04-05-2014), RJasonKlein (09-27-2015)
Old 04-01-2014, 01:13 PM   #1147
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i want my FRS to be able to do this, lol, this is ridiculous!
[ame="https://www.youtube.com/watch?v=Np_DIJNpS_E"]Meanwhile in Norway Kenneth Moen Rally stage Drift - YouTube[/ame]
Old 04-01-2014, 05:56 PM   #1148
FRSKEV
Drives: FRS
Question regarding RCE yellows and rear camber adjustment.
Why would I want the whiteline adjustable upper control arm bushings over the whiteline lower control arm adjustable bushing? It's 2 less bushings to install, easier to adjust and has more range.
This is from what I understand, I might be wrong.
FRSKEV is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
