Old 03-17-2014, 02:11 PM   #1135
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Twin disc!
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-17-2014, 02:33 PM   #1136
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Sterz View Post
I was taking to Clutchmasters the other day and I wanted to clear up the difference between the FX300 and the FX350 for our cars. I guess that the FX300 contains a kevlar disk. Has anyone had experience with the FX350s? That is the kit that they were suggesting to me.
They said that the FX300 uses a segmented kevlar material on the disk while there, FX350 uses a tested fiber material. The FX350 is slightly more aggressive than the FX300 while the lifespan is supposed to be longer. I am ordering the FX350 specifically so I can write a review on it just to clear up the mysticism haha.
Tell them to sponsor me too then, save your breath and here is the review... LOL
I have had both the 350 and the 400.
Both are similarly hard to launch properly, but for different reasons.
The FX350 can be slipped into a good start. Problem is, if you are in stop and go traffic and slip it a few times, ti gets hot and slipping it will result in feeling the whole motor and tranny jumping up and down in your dash. Press clutch, and try again.
The FX400 is extremely nice when cold. I say even nicer than the FX350. Problem is it doesn't take long to get hot after a few starts and once its warmed up oh boy...
There's almost no way to come off the line nice. It's very on off. You get used to it and do pretty decent, but its a constant battle to get it "acceptable".
Old 03-17-2014, 03:30 PM   #1137
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I think once you pass the 3xxwhp mark and whatever trq you have to give some certain luxuries away. Car will be a bit louder, wont drive perfect and you will always have a chance of being stranded on the side of the road cause something went wrong
Old 03-17-2014, 04:09 PM   #1138
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
What are the details of the build? What turbo did you go with?
gtx2867r
Fbm rad
550 injectors
Fuel pump
Aem wideband fail safe
Perrin OP
Act street clutch
Planned: Oil cooler- will probably put my own together and fab a bracket and ducting
Planned: Fbm fan shroud
Hope to avoid a vented hood because in Vancouver it rains constantly
Car will be running 94oct, so not going for outrageous numbers. Hopefully make around the 300 mark. Going to try to stay with the Ark Grip 2.5" if it produces decent numbers. I have a Tomei 80, but after having ridden in a turbo car with one I definitely prefer the quieter steel exhaust, even if I have to sacrifice ~20hp or so and a bit of response. Will very likely go 3" in future, but if I do it'll be a proper turbo back. No point in half-assing it.
OjiGeorge is offline   Reply With Quote
Old 03-17-2014, 04:10 PM   #1139
pmccut
Drives: Blue Subarus
Originally Posted by OjiGeorge View Post
gtx2867r
Fbm rad
550 injectors
Fuel pump
Perrin OP
Act street clutch
Tuner?
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 03-17-2014, 07:53 PM   #1140
OjiGeorge
OjiGeorge's Avatar
Drift Office. It's their first fbm kit. It will be great because we can have some more objective dyno comparisons. Ftw!
Sent from my SGH-I747M using Tapatalk
Old 03-18-2014, 09:57 AM   #1141
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
gtx2867r
Fbm rad
550 injectors
Fuel pump
Perrin OP
Act street clutch
Looks good. With a decent tune you will meet your goals no problem.
Old 03-19-2014, 09:36 PM   #1142
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Size:  64.7 KB gtx2867r. maxed the fuel system. Stock engine. LOTS of torque.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 03-19-2014, 09:40 PM   #1143
Reaper
Reaper's Avatar
Drives: violent
Old 03-19-2014, 10:05 PM   #1144
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
What fuel? Elevation? Weather readings? SAE corrections? Good numbers (seems to spool slowly like it does not even start until 3200 and you run out of fueling around 6500). 3port of WG spring pressure? Amount of boost? How does it drive?
Sorry for all the questions. Helps with comparisons to cars on my dyno.
Infamous Performance is offline   Reply With Quote
Old 03-19-2014, 10:06 PM   #1145
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Solid numbers
FullBlown is offline   Reply With Quote
Old 03-19-2014, 10:14 PM   #1146
Reaper
Reaper's Avatar
Drives: violent
E85, elevation is under 500feet asl, humidity was 40%. 17 psi on the 452whp pull, we ran out of fueling on the 461 pull i dont remember the psi, fbm manual boost controller. Car spins wildly above 4500rpm with 245 ventus v12s on the highway.
Old 03-20-2014, 12:18 AM   #1147
Sterz
Great White
Drives: 2013 Whiteout FRS
Okay guys, I have a little update. Infamous Performance I DO NOT recommend that you install the lines that you installed on my car for any other car. Oil was literally seeping out of the entire line length. It looked as though the lines were sweating oil. I'm going with stainless steel like I should have from the beginning. Not only that but there is a giant gash in the back of the oil cooler that is leaking oil that must have happened before it got bolted down because the cooler was bolted down tightly and there is no way that it could have moved and hit anything behind it. I now need a new oil cooler core. I am waiting for Bill @DeliciousTuning to get back to me with a basemap for 1000cc injectors, and the 1.5 bar map sensor for e85 that will allow me to move my car from the shop to the tune.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 03-20-2014, 12:21 AM   #1148
OrbitalEllipses
Drives: Attitude
@Reaper goddamn, let me know when you grenade the tranny/axles/rear end.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
