Old 04-16-2015, 10:02 PM   #11355
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Originally Posted by kch View Post
Yep. Still have to find exhaust leaks (weekend project), but cold start is MUCH more reasonable now.
What catback that you are running? I am going to run exactly the same setup but with ARK grip catback. The only thing that I am worrying about is whether it is going to be too loud, hah.
Sounds like your previous tune was not correct.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 04-16-2015, 10:15 PM   #11356
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I parked mine outside a Pho restaurant.
Walked in, and two of the waiters were up front looking out the window.
"Nah man, that's a BRZ - it has the fender vent"
Turns out, one of them had an Impreza and the other a prev-gen WRX.
Ended up chatting with them - on the way out, revved the engine a bit because they wanted to hear what the intake and exhaust sounded like.
Subros.
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
chanomatik (04-17-2015)
Old 04-16-2015, 11:47 PM   #11357
cjd
cjd's Avatar
Drives: 2017 BRZ
Final torque check after installing bushings (rear subframe and diff inserts, shifter) and took it off the jack stands and out for a spin... (I get to work on the car 30 minutes at a time some evenings, so I leave it up for a few days...)
Nice loud whine now, I assume from the rear end. Not sure about this yet. Waiting till I get the header and exhaust update in, which may simply raise the base level anyway... I have sound system updates in mind anyway...
Old 04-17-2015, 12:11 AM   #11358
kch
Senior Misanthrope
kch's Avatar
Stock catback for now. I don't think it's too loud at all. Don't know about the ark grip, though.
Tune was ok in that it was the correct tune. It just didn't address the cold start, so I fixed it.
The Following User Says Thank You to kch For This Useful Post:
Figo (04-17-2015)
Old 04-17-2015, 01:09 AM   #11359
Poodles
Drives: 2015 Series.Blue
Originally Posted by Pkush View Post
yes there is. lock it manually on the door handle.
then to unlock it you use the physical key that's inside the fob.
If the alarm is armed on the car, will the alarm go off if the car is still running? Only reason I haven't tried it cause I know it usually goes off if the key is used since I have mine on.
Old 04-17-2015, 10:02 AM   #11360
Figo
Figo's Avatar
I see, thank you!
ARK grip is not loud at all, so I think I should be good.
I have already ordered the front pipe and going to order header & overpipe soon.
Old 04-17-2015, 10:24 AM   #11361
MikeM7
Drives: 2013 BRZ Limited White
Edited my OFT OTS UEL E85 tune to eliminate the crazy loud cold start. I feel SO much better about my headers now.
My OFH/Perrin catback are making my house shake for the first 50 seconds the car is running.. I'd like to do this fix but I read there's a functional reason that it starts up the way it does, and it's best not to tamper with it.
What are your thoughts on that? Is there any potential harm that can be done with improper warm up?
MikeM7 is offline   Reply With Quote
Old 04-17-2015, 12:10 PM   #11362
Porcupint
Drives: 13 GBS BRZ
After reading through the threads here and here as long as you only remove the valve overlap, you should be ok with no negative effects in my opinion. I'll probably try it when I do get headers.
Porcupint is offline   Reply With Quote
Old 04-17-2015, 01:33 PM   #11363
kch
Senior Misanthrope
kch's Avatar
Disclaimer: I'm no expert. However, everything I've read indicates that the cold start is purely to warm up the cats. You're really not going to gain much temp in the fluids in one minute of warmup anyways. The only change I made was preventing the car from retarding ignition during warmup.
I'm totally happy I did it. The cold start is still loud-ish, but MUCH more reasonable (and doesn't sound quite as crappy). Haven't noticed any effect on normal driving.
Old 04-17-2015, 01:45 PM   #11364
MikeM7
Thanks for the info, I think I'm going to give it a try. The idle is quiet as a mouse after the rpm's drop, but that first 50 seconds is LOUD.
Old 04-17-2015, 02:18 PM   #11365
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Diffuser, Lip, Fogs
BRZZZZZZZZZZ is offline   Reply With Quote
The Following 7 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
chanomatik (04-17-2015), Choco (04-17-2015), daiheadjai (04-17-2015), DocWalt (04-17-2015), DuMa (04-17-2015), sprintertrueno86 (04-19-2015), wtrxprs007 (04-19-2015)
Old 04-17-2015, 02:27 PM   #11366
Cuchullain
Cuchullain's Avatar
Drives: 2013 GBS Subaru BRZ Limited
Paid it off.
Cuchullain is offline   Reply With Quote
The Following 7 Users Say Thank You to Cuchullain For This Useful Post:
AznKirby (04-17-2015), chanomatik (04-17-2015), Choco (04-17-2015), JDsThatGuy (04-17-2015), kch (04-17-2015), wtrxprs007 (04-19-2015), x1UP (04-17-2015)
Old 04-17-2015, 02:42 PM   #11367
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Originally Posted by Cuchullain View Post
Paid it off.
That's my dream right there. The only time I've ever paid off a car... is when I sold it. I'm determined to keep this one until it's at least paid off though. Good job!
The Following 2 Users Say Thank You to chanomatik For This Useful Post:
BRZZZZZZZZZZ (04-17-2015), Cuchullain (04-18-2015)
Old 04-17-2015, 04:32 PM   #11368
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
2URGSE
JPxM0Dz is offline   Reply With Quote
