Old 04-13-2018, 06:34 PM   #1107
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by nikitopo View Post
Toyota/Subaru had a re-designed engine from the beginning, Mazda didn't have it. You cannot have it more simple.
You're absolutely right! Actually it's not even a redesign, the FA20 was a ground-up design! No wonder they're not jumping to replace it!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
rcm47 (04-13-2018)
Old 04-13-2018, 07:22 PM   #1108
funwheeldrive
Originally Posted by daiheadjai View Post
Now I'm not one of the "OMG 86 is underpowered" crowd....
But seriously, Mazda's done in a couple model years, what Toyota/Subaru have steadfastly refused to do in 6?
I almost feel like Mazda was forced to add more power in an attempt to generate more sales. Correct me if I'm wrong, but the ND hasnt been a sales success so far right? I know that it's a niche car, but even then it seems like kind of a flop compared to the previous generations.
Originally Posted by Yoshoobaroo View Post
Don't forget the ND was a significant DROP in power from the NC, and even at 181HP, the ND still doesn't quite match the power to weight ratio of the twins (0.0738 hp/lb vs 0.0745 hp/lb), and that's assuming it doesn't gain any weight.
I find this math very hard to believe considering the ND is already faster than the 86 in a straight line.
Old 04-13-2018, 08:06 PM   #1109
Yoshoobaroo
TRACKBREAD
Leaked documents confirm big changes for the 2019 Miata
That's all due to tires from a dig. Rolling start the 86 is faster.
It's not a hard calculation, you can verify it yourself lol.
Old 04-13-2018, 09:52 PM   #1110
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Don't forget the shorter gearing.
Sent from my SM-G930W8 using Tapatalk
daiheadjai is offline   Reply With Quote
The Following 2 Users Say Thank You to daiheadjai For This Useful Post:
Rampage (04-14-2018), Yoshoobaroo (04-13-2018)
Old 04-13-2018, 09:54 PM   #1111
daiheadjai
daiheadjai's Avatar
I can't help but wonder if putting the tS development or tooling money towards a new header to get rid of the dip would have been a better use of resources.
Old 04-13-2018, 10:06 PM   #1112
Yoshoobaroo
TRACKBREAD
The dip is not an engineering flaw. It's their solution to meet fuel consumption and emissions targets. It's pretty much the only way to make an NA high compression engine pass emissions these days. That or stupid long gearing like the Corvette.
The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post:
DAEMANO (04-14-2018), daiheadjai (04-14-2018), nikitopo (04-14-2018), Spuds (04-15-2018), why? (04-15-2018)
Old 04-14-2018, 12:04 AM   #1113
funwheeldrive
You're using crank power and not wheel horsepower? I came up with different numbers. I feel like with 25 more hp the ND would have the better power/weight ratio.
Old 04-14-2018, 01:52 AM   #1114
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They put already resources and money on a new header. It is the one that comes with the '+17 MT cars, but their purpose wasn't really to fix the torque dip. They wanted mainly to give more power on the higher end range.
For reasons that I cannot install a catless header in Germany, I ordered and installed their new header. I was testing lately acceleration numbers and comparing them with a stock first generation car. Overall, together with other changes and weight reduction the times is like having now a 240hp NA car (*).
So, don't underestimate what they did with the new header. People saying that the new header is giving maximum 2-3hp, they don't know what they are talking about or cannot afford it and they are just jealous.
(*) I even made the assumption that the first cars were actually 190hp cars and not really 200hp cars. Catalog power was a bit overestimated.
The Following User Says Thank You to nikitopo For This Useful Post:
Old 04-14-2018, 07:40 AM   #1115
unhappymeal
Drives: 2018 Miata RF, 2017 Golf R
Sales aren't as hot as the halycon NA/NB days, but the ND is crushing the NC.
http://www.goodcarbadcar.net/2011/01...sales-figures/
unhappymeal is offline   Reply With Quote
The Following 2 Users Say Thank You to unhappymeal For This Useful Post:
funwheeldrive (04-14-2018), Rampage (04-14-2018)
Old 04-14-2018, 08:23 AM   #1116
Yoshoobaroo
TRACKBREAD
WHP calcs:
I used the same source for dyno numbers to reduce variables. Curb weights from Google.
MX-5 GT vs BRZ limited
Current Miata HP/weight:
135/2485 = 0.054
Estimated facelift whp
(181/155)*135 = 157.6
Facelift Miata Power/weight
157.6/2485 = 0.0634
BRZ estimated facelift whp
(172/200)*205
Facelift BRZ Power/weight
176.3/2776 = 0.0635
They pretty much become an even match with the 181 HP Miata.
Keep in mind the Miata still has a gearing advantage down low and comes with Max performance Summers.
Dyno sources:
http://dsportmag.com/the-tech/intake...16-mazda-mx-5/
http://dsportmag.com/the-tech/scion-...programed-ecu/
Old 04-14-2018, 11:28 AM   #1117
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
But you can't talk sense about fuel consumption and emissions targets to a bunch of enthusiasts that take out the cat, make more power, and don't want to deal with stupid things like smog checks and federal emissions laws!
So of course it's an engineering flaw! Why else would that stupid thing be there for no reason!
The Following 5 Users Say Thank You to mav1178 For This Useful Post:
finch1750 (04-19-2018), Rampage (04-14-2018), strat61caster (04-15-2018), Tcoat (04-14-2018), Yoshoobaroo (04-14-2018)
Old 04-14-2018, 07:09 PM   #1118
funwheeldrive
WHP calcs:
135/2485 = 0.054
157.6/2485 = 0.0634
(172/200)*205
176.3/2776 = 0.0635
Dyno sources:
But the weight for the ND miata is 2335lbs, not 24XX. And most dynos I see the Miata currently makes 143hp to the wheels. Also, the facelifted BRZ doesn't weigh 2775lbs, but closer to 2830lbs IIRC.
A revised Miata that is 2350lbs and 25 more crank horsepower would have the better ratio right?
Old 04-14-2018, 07:44 PM   #1119
Yoshoobaroo
TRACKBREAD
Right.
I fixed variables for a fair comparison. Both metal roof versions, both top trim pre-facelift weight numbers, since we don't know the weight of the new Miata. And the dyno numbers are both from the same indoor dyno, the best comparison you're going to get.
Old 04-14-2018, 11:52 PM   #1120
daiheadjai
daiheadjai's Avatar
Actually I'd be curious to see the effect of aftermarket headers people run on emissions and fuel consumption.
WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission SteelReign Cars for Sale/Trade 5 06-22-2015 03:01 PM
2016 mazda miata (MX5) reveal 9 PM EST Ernie L Off-Topic Lounge [WARNING: NO POLITICS] 1 09-03-2014 09:41 PM
FS: Supercharged 1992 Mazda Miata *$4000 OBO* BRZZZZZZZZZZ Canada Classifieds 5 08-18-2014 05:44 PM
The Mazda 2 trully the FWD Miata NA! Tbomb 25 Other Vehicles & General Automotive Discussions 24 01-14-2013 10:30 AM
