Old 02-05-2012, 04:07 PM   #1107
ZDan
ZDan's Avatar
Drives: '23 BRZ
I don't expect the FR-S to be more "fun" than an NA Miata. I do want a fixed roof and +2 seating, though.
Every car is a compromise, no car is ideal. And of course it's not strictly about weight or feeling lightweight even for me, which is why I got an S2000 rather than a Miata despite the rather huge weight difference. If it was *only* about mass, I'd have been in an NA Miata for years now, and would probably be swapping to an Elise about now.
Old 02-05-2012, 04:18 PM   #1108
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
has anyone compared mpg?
quik1987 is offline   Reply With Quote
Old 02-05-2012, 04:50 PM   #1109
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
We haven't heard the official mpg for the BRZ/FRS yet. The GC is:
• 3.8-liter V6 engine (rating with premium fuel)
• 18 city/28 highway – 8-speed A/T
• 18 city/27 highway – 6-speed M/T
• 2.0-liter 4-cylinder turbocharged engine (rating with premium fuel)
• 20 city/31 highway – 8-speed A/T
• 21 city/30 highway – 6-speed M/T
Also remember the GC is able to run on regular fuel. I think the 2.0T on regular drops down to 260hp/260tq from 274hp/275tq.
tranzformer is offline   Reply With Quote
Old 02-05-2012, 05:22 PM   #1110
serialk11r
Drives: '06 AM V8V Coupe
8 speed A/T, sounds like the cruising gear will be pretty good. So if the Genesis is only getting 31 EPA highway, that's actually pretty bad.
FRS should be several mpgs higher in the city due to less weight and no turbo. On the highway the advantage (if any) will be smaller, although at part load that extra bit of compression helps a lot. I'm also pretty sure the FRS can run on regular if you don't floor it, based on what I know about VVTi programming. Alternatively, if there's access to the VVTi control in the ECU, you can easily limit the torque and rpm and run regular with no efficiency penalty (actually EGR might mess some things up, but that can be dialed out sorta).
I'm predicting 23/33 AT, 24/32 MT. Good driving should get it over 30 average, highway can be over 40 if you pulse and glide.
Old 02-05-2012, 07:50 PM   #1111
vq37
Drives: Opel Kadett
Originally Posted by ZDan View Post
Light weight is a BIG FACTOR for every day usage driving fun as well, *NOT* just track usage. I DD an S2000, LOVE it even tooling around at 1-3 tenths. Lighter-weight smaller cars are just inherently more fun, ALL the time, not only when pushing the limits.
Mass FTMFL...
Light weight is nice, but the obsession about it is really getting out of hand in this place. The Nissan GTR is 3900+ lbs, the 911 turbo is 3500 lbs despite being a 2 seater. Do you really think they make boring daily drivers? Even the ZR1 is 3329 lbs, I guess the FR-S/BRZ must be much more fun than that too because weight is pretty much everything isn't it?
The GC for being a 2+2 GT car is actually fairly light compared to its competition. Most people who want a comfortable fun daily driver are gonna have to take a 3000+ lbs car or risk losing a lot of features/comforts and practicality. If having a single purpose track car is fine for you, then maybe FR-S/BRZ will work, and it might work for me too if its priced low enough.
Despite the lower weight, the FRS/BRZ will be a tough sell if its priced above 25k, most people will just see the 348 HP 3.8 (the 2.0T) R-SPEC Genesis coupe for near the same price and go with that. A lot more standard features, much nicer interior, a lot better warranty, wider tires, etc. It may seem superficial but I can assure you, that's how most people will think.
The FRS/BRZ is lighter, probably has better road feel, likely more balanced and might feel better through the corners, and while that's an important advantage, it just isn't enough unless its priced noticeable lower because the GC wins at everything else. You can't really even fix the problem of low torque and HP on the FRS/BRZ due to the high compression ratio, so I doubt it would make a good tuner/turbo car either.
vq37 is offline   Reply With Quote
Old 02-05-2012, 07:53 PM   #1112
vq37
Drives: Opel Kadett
Though the 3.8 only drops down to 344hp/292ft-lbs on regular. The turbo takes the much bigger hit on regular.
Old 02-05-2012, 08:41 PM   #1113
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Hmmm.. correct me if I am wrong. I do not think this FA20 has VVTi implemented. If that is the case, how can you be assure that this engine can run on regular. Can you elaborate on that?
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 02-05-2012, 09:29 PM   #1114
cassidy0998
cassidy0998's Avatar
Drives: '99 Ranger / '94 APU Supra / Ninja!
Agreed, I like your style.
cassidy0998 is offline   Reply With Quote
Old 02-05-2012, 09:32 PM   #1115
Dark
Elite Padawan
Dark's Avatar
I sometimes run my IS250 on regular gas( when the gas station I go in runs out of premium), and it has D4S. When you run regular, power will be downgraded.
Dark
Dark is offline   Reply With Quote
Old 02-05-2012, 09:42 PM   #1116
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Of course it has variable valve timing implemented. Dual AVCS is most likely.
However I can't go 100% on the fact that it will have ability to run on regular. I can speculate that it will have the ability (makes sense with fuel prices today) with direct injection. I certainly don't think that 200hp crank rating is on regular though...
Exage is offline   Reply With Quote
Old 02-05-2012, 09:43 PM   #1117
Sasquachulator
Pavement Grey
That raises this question.
Does this car REALLY compete with the Genesis coupe? or is it more in line with compact 2 doors like a Civic Si or a Scion tC?
As far as i can tell, the Genesis coupe, 370Z, RX8, G35, Altima coupe and maybe even the ponycars all compete against each other. They're all larger, and possibly more luxurious. No one puts a Civic SI or Scion tC against those cars because they dont compete with each other even though there imay be price overlap.
the BRZ/FRS/86 triplets seem like its a rung lower than these other luxo coupes the more i think about it. (slotted in a spot between the sport compacts and the RWD coupes)
Old 02-05-2012, 09:52 PM   #1118
tranzformer
Drives: Zoom Zoom
AutoX/tracking class is different than the average consumer who buys primarily based on price/affordability.
Old 02-05-2012, 09:55 PM   #1119
serialk11r
Yea. I don't think it will be able to run regular from the factory, it'll need a tune. However the dual VVTi makes running on regular easier, you just have to fiddle with the valves rather than mess the timing up. The way they improve volumetric efficiency at low rpm is advance the intake a lot, if you retard the cam it will lose volumetric efficiency AND reduce internal EGR, which greatly reduces the charge temperature, so 87 should be pretty safe. I think the steady torque increase from idle to 3000rpm is attributed to them running the maximum possible valve overlap and EGR.
You can put regular in without a tune and stay off the throttle but accidentally jab it too hard and the engine will knock and it'll all go downhill. An idea I was thinking of is a "foot limiter" aka plastic block behind the gas pedal that makes you keep out of it
And of course you will lose some torque throughout the rev range.
Old 02-05-2012, 10:18 PM   #1120
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by SUB-FT86 View Post
So it sounds like you might like a first generation Miata better than a FR-S? Because someone who owns one could say the very same thing that you have been saying about heavier cars than the FR-S. By your logic the Miata should be way more fun.
That wasn't directed at me, but I expect the Miata to be more fun (though not *way* more fun, as you put it). I'm getting an FT86 because I need 3 seats.
No.
To me, mass (in terms of not only total amount but also COG and yaw moment) is the most important aspect. That doesn't mean every lighter car is more fun than every heavier car. Or more succinctly:
saying weight is most important != saying weight is everything
Read this bmwblog article (originally posted in the E30 thread). Though it's obviously too soon to declare the FT86 the E30 M3's true successor and I disagree with a couple things in the article, for the most part it's spot on.
Deslock is offline   Reply With Quote
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
FR-S/Subie Coupe fantasy Maxim Scion FR-S / Toyota 86 GT86 General Forum 23 06-10-2011 01:25 PM
new Kia coupe Ground N Pound Other Vehicles & General Automotive Discussions 22 12-29-2009 02:04 PM
