Old 06-29-2012, 10:47 PM   #99
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by jedibow View Post
Correct Serial, P=nRT is your best friend!
Remember turbos do not create pressure for free, the maximum effieciency on the turbo that Don chose is 86% which is very good aslong as you are running the turbo in this effiecency island, so AT Best you will see a drop of 14% in pressure due to the increase in air temperature from created by the compression of the turbo.
This is exactly why I state earlier that a BW EFR turbo would not be a viable option in our car UNTIL you build the bottom end.
PV=nRT.
Pressure increases with temp, so you lose air density. You won't see a drop in pressure with compression. What you can affect is air density by controlling the volume/temperature.
the amount of boost you run is dependent on the size of turbo as well.
My 6262 is happy running 15-16psi on 91 octane, but a tiny T25 would melt things. It isn't as efficient. I vote for a slightly larger turbo at the expense of lag, but better high rpm efficiency. I think the GT3071r is good. the GT3076r has too large of size differential in wheels imho. But the 6 bladed wheel sounds sick.
I think the GTX3071r would be a nice option but they are really expensive for what they are.
The disco potato is probably the best overall option for most people out there. It is small, but properly sized, and very efficient. I think 7psi on this turbo will produce a nice surge of torque right at 3000rpm. And also with tune should produce over 250whp. 10psi should put it around 280-300whp, but we'll know more when we see how the head flows.
There is a lot to consider on turbo efficiencies. A lot of variables at play here.
Coheed is offline   Reply With Quote
Old 06-29-2012, 10:53 PM   #100
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Originally Posted by Don@Accelerated View Post
We'll be scavaging both front and rear. There is not a real great spot to feed oil into that will well suited gravity fed.
Can you not mount it up high kind of in place of the airbox? With the turbo mounted east-west obviously,
jet86 is offline   Reply With Quote
Old 06-29-2012, 11:01 PM   #101
Coheed
Coheed's Avatar
It is also worth noting that picking a larger turbo, even if more inefficient, will still have lower temps than a smaller turbo. It will flow more air per psi, and since you will operate at a lower pressure ratio the intake temps and reliance on the intercooler goes down.
Old 06-30-2012, 06:17 AM   #102
yuli8466
Drives: MX5
Originally Posted by serialk11r View Post
Err psi != air mass. At room temperature you can do that, but compressing the air increases its temperature.
5psi may increase 50hp?
it is not enough for adding an additional turbo kit.
yuli8466 is offline   Reply With Quote
Old 06-30-2012, 09:09 AM   #103
wcbjr
Drives: 2006 Subaru LGT
Wow people, I said best case. It's a vague answer to a vague question.
wcbjr is offline   Reply With Quote
Old 06-30-2012, 07:35 PM   #104
serialk11r
Drives: '06 AM V8V Coupe
Sorry to keep on nitpicking, but that's not best case. Best case is you get most of the way down to ambient temperature with a massive intercooler, have about neutral pumping loss, and a slight decrease in efficiency.
Old 06-30-2012, 08:07 PM   #105
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
only if the lager turbo is efficient at that pressure ratio, if it isn't then you are only pumping hot air.
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-01-2012, 03:29 AM   #106
Coheed
Coheed's Avatar
A GT3076r will have lower intake temps at 8psi than a GT2860rs will have at 10psi. The difference of 2psi of pressure has a larger impact on temperature than the adiabatic efficiency does. You have to do some math, But here's what I get:
10psi GT3076r at 75% efficiency puts delta temps around 165*F
12psi on GT2860rs at 80% efficiency is around 175*F.
The difference in pressure ratio has a larger impact on the output temps than even a large 5% deviation in adiabatic efficiency. There is slightly more power consumption with a lower efficiency compressor though, but this is remedied by reducing backpressure and increasing VE.
On top of the lower PR, you get less pumping losses and better VE. Larger turbos have their advantages. I'd take a low boost large turbo setup over a restrictive low-rpm turbo any day, especially for an engine with a high redline.
Some may argue that large turbos cannot be as responsive, but fail to consider shaft speed and spoolup. A disco potato running 250hp is over 115k rpm. But a GT3076r at 300hp would be around 80k rpm.
Only when spooling that large turbo to higher PSI will you really start to notice the difference in lag, but transient response can still be really good.
Old 07-01-2012, 04:05 AM   #107
LSV8
Drives: Very fast
not safe with stock compression..
LSV8 is offline   Reply With Quote
Old 07-01-2012, 09:18 AM   #108
Coheed
Coheed's Avatar
That's what everyone said about the 11.5:1 compression 2zz motor in the Celica. Yet there were a lot of people who turbo'd them. They made great power too.
10 years ago, if Toyota said they were bringing a 12.5:1 compression engine to market, people would say "Impossible! It won't work on 91 octane!"
13:1 is out of the question... right? Then the Prius was released. Overseas, they get 14:1 with 93 octane. Blasphemy!
Then mazda pushed 16psi boost through an engine at 9.5:1 compression in the MZD. People realized over 20psi from stock turbo with tuning, all on 91 octane.
I don't think 8psi is out of the question here.
Old 07-01-2012, 10:52 AM   #109
Don@Accelerated
Don@Accelerated's Avatar
Who wants to bet me I can't make 300hp on the factory compression w/ zero issues?
Any Takers?
Don@Accelerated is offline   Reply With Quote
Old 07-01-2012, 11:08 AM   #110
slow_frs
Drives: turbo scion tc
lol bet u already have...
slow_frs is offline   Reply With Quote
Old 07-01-2012, 11:31 AM   #111
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
X2
Lee358 is offline   Reply With Quote
Old 07-01-2012, 11:36 AM   #112
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any Takers?
I'll take that bet. If I win I get what ever turbo kit you do release for free. If I loose I pay zero dollars for the kit. :happy0180:
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
