View Poll Results: Favorite Tail Lights and Why?
Tom's 120 34.99%
Valenti 101 29.45%
Buddy Club 23 6.71%
Spyder 5 1.46%
Spec-D 15 4.37%
Winjet 1 0.29%
Oem 50 14.58%
Other 28 8.16%
Voters: 343. You may not vote on this poll
Old 06-02-2020, 12:31 PM   #99
churchx
churchx's Avatar
Drives: 2014 GT86
Nope. They only approach clients in person in dark alleys and cost of first born son also might be not within budget of most
Old 06-02-2020, 06:43 PM   #100
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by churchx View Post
Kodename47: but wouldn't suggested fixes, eg. better gasket, then also work with aftermarket ones, and thus later shouldn't be that much faulted for condensation?
Correct fitment works. The Subaru TSB is very specific, tightening order and torque. Making sure the gasket is flat and that the washers are all correct. Thicker gaskets help mask poor fitment.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-03-2020, 08:16 AM   #101
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Bingo. It does work with all lights. Correct fitment, installation, and torque is key to longevity. Doesn't matter if it's aftermarket or stock, it's equally as important.
Thing is, the factory installs your stock lights, which is why you see less issues with condensation in them. Your average person is installing aftermarket lights, which is why you see more issues. Not the light's fault, there's just a higher level of control in installation at the factory.
People are quick to blame to product when they see an issue like condensation in the lens. That's human nature to find something to blame. When you dig a little deeper, you often find signs of human error contributing to the problem. Nobody likes to admit they made a mistake.
sharpsicle is offline   Reply With Quote
Old 06-03-2020, 08:41 AM   #102
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Holy crap. Another thread said the torque spec is 3.5ftlb O.O
We should be finger tightening with blue loctite lol
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 06-03-2020, 03:39 PM   #103
Kodename47
Kodename47's Avatar
Drives: UK GT86
4.5 Nm is the spec so about 3.5lb.ft (actually 3.3)
Also the gaskets are meant to be single use only - I now recommend if anyone removes or replaces the lights to get new gaskets (or make your own like I have done)
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-04-2020, 07:20 AM   #104
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I ordered them to be on the safe side. What material would you recommend to make your own?
Old 06-04-2020, 08:43 AM   #105
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Same material as stock, neoprene rubber, ~1/4” or ~5mm thick will do.
Old 06-06-2020, 04:59 AM   #106
Kodename47
Kodename47's Avatar
Drives: UK GT86
^ This. I have made templates for OEM and VLAND (probably the same as most aftermarket) so should there be the need, I can just have a set made up in 10 mins. Just need a sharp knife.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-06-2020, 11:28 PM   #107
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Well they came with new gaskets so yay lol.
I wonder if the people suffering leaks are buying used sets and not replacing the gaskets...
Old 08-08-2020, 02:08 AM   #108
HaXx
Drives: jrsc_brz
Let's talk about Tom's tails. All reds vs clear lens black housing. What's the difference, besides the colors obviously. Which ones are the ones to get? The all reds are the jdm spec or something like that? Not the v2 hurricane reps, dont like those as much
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 08-11-2020, 08:35 AM   #109
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
If I remember it correctly when I was doing my research on these 2, both the clear & the all-red have USDM DOT-approved specs for having sidemarkers. There's a clear one being sold as well that's JDM spec wherein there's no side marker hence it is not DOT-approved. The all-red has red LED's for both brake & turn while the clear has red for brake & amber for turn.
I ended up getting the all-red because the clear one has an infamous issue of having a visible internal minute component warping when exposed to direct sunlight in the summer. The all red doesn't have this problem because of the tint
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 08-11-2020, 10:43 AM   #110
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Tom's taillights, the V1's... the best ones, there is a USDM and JDM version of both the Clear and Red lens.
Red USDM / Red JDM
Clear USDM / Clear JDM
The internal difference is the JDM does NOT have a small sidemarker bulb behind the reflector on the outer sides. And Japan requires that all turn signals be amber, because theyre smart. So the JDM Toms have Amber LEDs for turn signals.
Side note: If you find a pair of JDM taillights, you will need to switch two of the wires in the plug. Not hard at all.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 08-11-2020, 11:03 AM   #111
Westen86
Purist
Westen86's Avatar
https://imgur.com/gallery/JlFITwS
Old 08-11-2020, 02:22 PM   #112
ArrrBussiere
ArrrBussiere's Avatar
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
Also throwing in my vote for the Intec Carbon Ferrari Style
ArrrBussiere is offline   Reply With Quote
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
FS - Light tinted tail light overlays seven Exterior Parts (Aero, Lighting, Etc.) 0 01-26-2013 10:05 PM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
