Old 09-28-2015, 03:50 PM   #99
350z
Drives: 350z
This^^^. I'm just waiting on the tune to arrive so I can install the rest of the stuff (injectors, pulley, pump). Combine the before and after results against my stock 350z. My videos will be just straight line races as there are no turning tracks around where I live.
350z is offline   Reply With Quote
Old 09-28-2015, 04:18 PM   #100
Superstar
Drives: Honda
Originally Posted by Sleepless View Post
I actually don't care about "otherwise stock", what I'm interested in is the same car with standard pulley compared to same car with upgraded pulley. I assumed you would have that for your car.
Hopefully someone that does the upgrade will post lap times before and after the upgrade. I will certainly post my before and after JRSC lap times very soon, in another thread of course
I really don't understand these types of request. +50-70 whp will always be faster than what you currently have and it's quantified for you in terms of power... I'd rather see laptimes for major suspension components because otherwise there is no way to quantify how good it is...
Superstar is offline   Reply With Quote
The Following User Says Thank You to Superstar For This Useful Post:
CSG Mike (09-28-2015)
Old 09-28-2015, 05:10 PM   #101
Irace86
Drives: BRZ + Ducati M796
Just giving a qualifier, andI dont think if it applies here, but more hp doesnt always translate into better area under the curve or better lap times. For instance, adding a larger turbo might equate to more peak hp but too much lag could hurt performance. Now in this case, the idea is adding more boost, but if it wasnt added equally across the rpms, maybe progressively, then again, peak hp could be higher, but not substantially across the rpms to sometimes justify reliability or cost. Again, not saying that is the case here, but I think that is where he is coming from.
Irace86 is offline   Reply With Quote
Old 09-28-2015, 05:44 PM   #102
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
But this is a pulley driven supercharger. Everything you said doesn't apply. A HBP on the same supercharger will give you more power everywhere. It does add boost equally across the entire RPM range. Why doesn't it come like this? Because with a HBP you have to really address fueling issues with injectors, pump, and probably a flex fuel solution.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
Old 09-28-2015, 05:49 PM   #103
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
This thread is about the pulley upgrade so I think many of us would like to see some real world data just like you (and I) like to see suspension upgrade comparisons.
So, I don't understand what there is to understand or not about "these types of requests". Why is a suspension comparison a "better" request than a "power" comparison. It's fun and useful data.
Plus, I think a lot of people would be surprised how little difference more power makes as the percentage gain goes down. So, for me, real world power comparisons are very useful in determining where/when the cost benefit tapers off to the "not interested" point.
Sleepless is offline   Reply With Quote
The Following 2 Users Say Thank You to Sleepless For This Useful Post:
CSG Mike (09-28-2015), lightdir (09-28-2015)
Old 09-28-2015, 07:43 PM   #104
Irace86
Exactly, but you said 50-75whp will always be faster, and it won't. In this case, yes, it is faster, but maybe the guy didn't know why this case is different.
Old 09-28-2015, 07:53 PM   #105
DaiTT500
DaiTT500's Avatar
Drives:
Where do you live?
DaiTT500 is offline   Reply With Quote
Old 09-28-2015, 07:58 PM   #106
Originally Posted by DaiTT500 View Post
Where do you live?
Daytona is too far for him.
DaiTT500 (09-28-2015)
Old 09-28-2015, 08:04 PM   #107
Irace86
I think for many people, even car enthusiasts, they would be shocked to learn that a set of quality tires can shave seconds off lap times, or just pads and stainless lines can improve braking as much as it does. Most people don't have to be told more power means better performance, but they do for other mods like suspension.
In this case, the pulley is a no brainer. Sounds like most people would be getting double the power that the original kit adds with half to a third the cost. And at 350whp the power isn't so high that traction would be an issue. So a similar increase in performance proportional to the increases gained from the base kit is likely, unless someone couldn't use the power because of ability or because the track is a slower track (mostly twisties). Track times would be cool, but the results wouldn't be surprising is my guess.
The Following User Says Thank You to Irace86 For This Useful Post:
Old 09-28-2015, 08:18 PM   #108
DaiTT500
DaiTT500's Avatar
Drives:
Or maybe sebring or hempstead?
Old 09-29-2015, 07:26 AM   #109
350z
Drives: 350z
I live in the middle of Texas where pretty much all tracks/roads are straight, Thats most likely the only races to be had unless a parking lot thing pops up.
But I guess finding a comparable car is too hard for you CSGmike? =)
Old 09-29-2015, 08:02 AM   #110
DaiTT500
DaiTT500's Avatar
Drives:
The middle of texas like dallas or west texas?
Old 09-29-2015, 11:13 AM   #111
350z
Drives: 350z
Couple hours west of Dallas
Old 09-29-2015, 12:51 PM   #112
Too large of a challenge. Sorry.
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 07:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
