Old 09-09-2015, 07:08 PM   #99
notout86
Drives: GTS 86 auto
Oh well............ back to the drawing board. I am chuffed however that this thread stimulated so much debate.
Although I was kidding myself that I could feel a little more pep under post-heat-soak take offs, I will leave the mod on for the slight cumulative gain.
Now, what about the idea of heat-shielding the coolant bottle to reduce evaporation and the battery to prolong its life? They DO work.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
The Following User Says Thank You to notout86 For This Useful Post:
Tcoat (09-09-2015)
Old 09-09-2015, 08:12 PM   #100
stugray
Drives: 2013 GBS BRZ Limited
Well actually I dont hate all of the ideas that get proposed.
I think we should do "Thermally Isolated Air Intakes" and lightened rotating engine components, and "intake runner lengtheners" and CF hoods when done for the right reasons
And when we use reasonable assumptions to perform the cost/benefit analysis.
I build spaceflight hardware so I know the extremes that engineers will go to, to get that last .01%.
However before there is ever a penny spent on updating something that is already proven to work, there must be a cost/benefit justification and at least some engineering trade offs performed.
Even thermally isolating the air intake is a good idea (just keeping the intake air at a more consistent temp helps the ECU) but is it worth the effort?
Now if you could just plate the inside & outside of the entire intake box in polished Al, that would look nice.
The Following 3 Users Say Thank You to stugray For This Useful Post:
Captain Snooze (09-12-2015), notout86 (09-09-2015), solidONE (09-09-2015)
Old 09-09-2015, 09:44 PM   #101
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'm looking into maybe some type of spray on thermal coating. Seems to be a lot less effort than trying to tape the thing up in gold tape.. Just clean it then spray then wait till it cures to reinstall. simple, assuming the airbox plastic and the paint play well chemically. Any suggestions? I'm assuming ceramic paint (such as header paint) is probably not going to be as effective than the gold film or glass fibre tape.
Intent > Content
Old 09-12-2015, 07:10 AM   #102
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You mean because it looks good, right?
Ultramaroon (09-12-2015)
Old 09-12-2015, 08:42 AM   #103
churchx
churchx's Avatar
Drives: 2014 GT86
Ceramic paint for headers .. are you sure that it is applicable and will stick to intake plastics and that you will be able to heat up it together with plastic intake for it to stick?
I'd just add oil rad, sports thermostat and be done with it.
Old 09-12-2015, 10:08 AM   #104
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Paint would do jack sh*t for you. And yes the tape was ahell of a lot of effort on a TRD intake and it is already starting to lift in afew spots. gona come off when I wash my engine. I thinking wrapping yourheaders will yield more gains the worrying about AIT. Wrapped headers will flowthe exhaust at increased velocity’s (helps HP) and will reduce under hood temps(help AIT)
Old 09-12-2015, 11:09 AM   #105
solidONE
solidONE's Avatar
Stugray was talking about some sort of teflon coating with a glossy finish. Sounded like maybe there's a product like this. I guess not. Sounds like the reflective tape is the only effective option. I suppose a heat shield made with thin sheet aluminum attached to the airbox can be made with little effort and can be found at most hardware stores, but I'm not sure if that will work as well as the gold reflective tape being sold for this purpose.
I'll figure something out once I'm there. I got plenty of stuff on the priorities list ahead of heat shielding the intake.
Heat sheilding product w/adhesive backing: https://www.heatshieldproducts.com/hp-sticky-shield
With a little more bling: https://www.heatshieldproducts.com/lava-shield
Intent > Content
Old 09-25-2015, 08:26 PM   #106
solidONE
solidONE's Avatar
I dont think this is enough heat shielding.
Had some of this "handyman" sheet aluminum from Home Depot laying around. Maybe 14~16mil thick?
It's loosely fitted with double sided foam tape, and not completely encased. So far in 100f ambient, it doesn't seem to do much of anything for IAT's. The hottest portion of the intake seems to be the hose that connects to the TB. That's going to need a layer of shielding to see any appreciable drop in IAT, I think,
Intent > Content
Old 09-26-2015, 02:13 AM   #107
churchx
churchx's Avatar
Drives: 2014 GT86
Looks nice. Much neater then some wraps with lot of wrinkles i've seen.
Old 09-26-2015, 01:58 PM   #108
solidONE
solidONE's Avatar
Too bad it doesn't work very well.
This stuff look very snazzy: https://www.heatshieldproducts.com/lava-shield
Intent > Content
Old 09-26-2015, 05:42 PM   #109
kodyo
Drives: Scion FR-S
The difference in air density at STP between 90 & 100 deg F is ~1.6%.
But since air is only ~20% oxygen, this means you are getting .3% more oxygen.
Or about the same as getting 0.050 PSI of boost.
So driving into a headwind would make a bigger difference in HP.
Your math is flawed. All air entering the box is 20% oxygen. Therefore, a 1.6% increase in volumetric flow would also result in 1.6% increase in oxygen, not 20%*1.6%.
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
stugray (09-26-2015)
Old 09-26-2015, 05:44 PM   #110
notout86
Drives: GTS 86 auto
Hi solidONE. Attachment with double-sided tape sounds OK. I imagine just in a few spots to allow a gap for air to circulate underneath. If the tape dries out and loses adhesion ithe shield should still be attached somehow so it does not fall off . As the shield is slightly uneven, direct contact of the shield to the box will be minimal even without tape so heat CONDUCTION will also be minimal.
Old 09-26-2015, 08:22 PM   #111
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Hey guys. The gold foil tape is still holding on but I have been thinking that the intake manifold has a lot more surface area on the inside the air contacts and I feel that is where AIT go up the most? Thoughts?
Old 09-26-2015, 10:49 PM   #112
churchx
churchx's Avatar
Drives: 2014 GT86
My thoughts is that it's not worth to spend that much effort/time. At most i'd think of adding oil rad and that's it. Slight heat soak when stationary doesn't matter to me, as when car goes at reasonable speed, not much of an issue. Intake heat insulation won't do anything to hot weather/ambient temps anyway.
Engine Dress-Up, Heat Shielding & Motor Oil products @ OAKOS.com OAKOS Automotive Engine, Exhaust, Bolt-Ons 192 02-13-2015 01:38 PM
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Intake tube and heat soak mike the snake Forced Induction 17 02-05-2015 01:46 PM
DIY Gold Foil heat wrap intake box autoCAR DIY (Do-It-Yourself) Guides 35 02-20-2014 02:22 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
