#99 |
Drives: 2013 SWP BRZ
A downshifting questions for the experts:
I've had a S2000 before this and now the BRZ. I usually rev match pretty good when downshifting sequentially (6-5-4 etc...). The question I have is about downshifting non-sequentially. When I first learned how to drive a standard from my cousin he said "you don't want to downshift from 6 to 3 or skip gears.." or something along those lines. Now is that true for all the standard tranny cars these days? Can you shift from 6th gear to say 4th depending on what situation you're in (slowing traffic, approaching red light that turns green..etc).? I know rev matching is important but wanted to understand if this will damage/reduce life on the syncros or anything else. I've had plenty of situations where I am approaching a red light and I am doing 65mph in 6th gear...put it in neutral and brake to slow down but the light turns green and I look down to see that I am down to 35mph...what should be done in an instance such as that? Thanks in advance. |
#100 |
Drives: 2013 FRS-6MT Argento
I slip the clutch, slipping the clutch is part of normal wear and tear. Where you get into trouble is riding the clutch, excessive slipping, or slipping the clutch at high RPMs.
#101 | |
As far as picking gears, the easy way to look at it is take your speed, your example was 35, and just use the first digit if you want to be in the base of your powerband and go up one gear if you are just casually driving around. So for 35mph you would look at it as 3, if you want to be quick you go for 3rd, if you want a relaxed shift go for 4th. Now this is just a generic rule to help someone learning, once you are really confortable with your car you will just know what gear to be in. I hope that helps. |
#102 | |
bazinga
Drives: WRB BRZ Limited
When on track, you should not skip gears and enter corners braking in neutral On streets however, i think everyone has their theory. IMO you can skip gears when the situation calls for it. there is not enough stress to harm the tranny with street driving The only thing I would pay attention to is not to make it a habit to skip gears, especially when up shifting. |
#103 |
Drives: Toyota Tacoma
You can downshift skipping gears for passing. 5-3. Just know what the redline is for each gear so you dont blow yer engine (aka money shift). You can also skip gears upshifting revving to 5k and shifting from 2-4 if you are lazy or bored.
#104 |
Also please dont engine brake just use the brakes lol. Maybe only during aggressive driving.
#105 |
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
#106 | |
Drives: Hot Lava MT
I started shifting lower (like around 3-4k) and I seem to be able to get it smoother that way. |
#107 | |
For spirted driving, you will need some practice and maybe the help of someone local. With the engine off you can practice your 1st to 2nd shifts to make sure you are pulling straight back and not catching any of the guides. The other thing you can check to make sure you are not releasing your clutch before completing the shift (this is actually a very common issue). In a large, safe, controlled enviroment you can run up the RPMs slowly in 1st and practice your 1st to 2nd shifts, accelorating a little fast with each error free pass, until it becomes you are comfortable with it. |
#108 | |
Drives: Coming - ZC6 MT, SWP Limited
Ever wonder why those driver perspective cams in race cars shake so hard when they shift? high rpm shifts was not meant to be super smooth. |
#109 |
Drives: scion Fr-s
I was taught to not use the clutch just rev it out to 3000 or 4000 revs and disengage the gear with the clutch, then release the clutch and apply a "small" amount of pressure on the next gear gate, and around 2500 it just slides in for a very smooth transition and a lot less work on the clutch. But all the threads I have read said that ill be picking up gear teeth in no time. Is it really as bad as people say it is? and Why is so smooth?
#110 | |
Drives: na
#111 | |
Drives: na
AND in racing situations, you might think you want to shift from 6 to 3, but you might change your decision while downshifting and stay at 4. You wouldn't be able to make that adjustment smoothly if you just skipped. |
#112 | |
Drives: na
People get screwed over by the term "let it go slowly." You just have to get the clutch to touch the flywheel, hold it, then let go. It's a 2 step process, rather than a continuous 1 slow step. |
| Second Impression with a Manual Transmission | Bristecom | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-30-2012 08:21 PM |
| FT-86, manual or automatic transmission??? | luisjr | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-25-2012 03:00 AM |
| Raven manual transmission $25,364.00 | terrypm | Dealer Cars | 0 | 06-01-2012 12:49 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
| Another reason to buy a manual transmission car... | xantonin | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 08-10-2011 11:30 AM |
