Old 07-07-2012, 11:32 PM   #99
harajukukei
Drives: MB c230k
Pleasure Racing Service - PRS Suspension System
Soft 6/6
Medium 8/8
Hard 10/10
http://www.prs.jp/products/prssus.html
harajukukei is offline   Reply With Quote
Old 07-08-2012, 12:10 AM   #100
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Thanks, man... you are digging deep for this stuff!
Old 07-08-2012, 02:30 PM   #101
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
anybody bought the kw v3 yet? any feedback? thanks!
imravenit is offline   Reply With Quote
Old 07-09-2012, 03:10 AM   #102
DarrenDriven
NW Region Moderator
I have em sitting in my garage, but haven't installed them yet. I am going to install my D2's first to see if I can live with them... then either sell the KWs or sell the D2s depending on how much I like them (or not).
Old 07-09-2012, 10:08 AM   #103
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
JRZ are sold with whatever rates you request.
Most dealers offer an outline of what is recommended based on experience.
We will also have Nitron available in a few months, they will be similar: rates are selected on order but with a general outline based on experience.
Esoteric is offline   Reply With Quote
Old 07-09-2012, 11:12 AM   #104
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Thumbs up
Give us some feedbacks! Thanks
Old 07-09-2012, 12:56 PM   #105
DarrenDriven
NW Region Moderator
Added my user review of the Eibach Pro-Kit Lowering Springs:
http://www.ft86club.com/forums/showthread.php?t=11093
Old 07-10-2012, 02:14 AM   #106
Sleeperz
Drives: 1982 Toyota Corolla Coupe SR5
High Pressure monotubes would give you a bit of a lift. Probably will be available from bilstein.
Originally Posted by BlaineWasHere View Post
I don't know why'd you want to do this, stock the car has plenty of ground clearance for winter. BUT you don't need different springs to go taller, just some 1" poly spring spacers... The 4X4 world has been doing this for decades to level out vehicles and even gain some extra lift. I think you can even get spacers like this for some Subaru cars with "saggy but syndrome."
Sleeperz is offline   Reply With Quote
Old 07-10-2012, 03:43 AM   #107
DarrenDriven
NW Region Moderator
Added Suivax...
Originally Posted by BPAuto View Post
A powerhouse in the drift scene and JDM community, VERTEX, has teamed up with SUIVAX, as well as D1 Driver Takahiro Ueno to produce two coilover systems for the FRS / BRZ / 86.
The systems have been road tested and track tested for cornering ability and daily driving. It was imperative that they did not upset the natural balance of the car in stock form, yet, improved upon it.
Standard Kit info
front spring rate - 7kg
rear spring rate - 5kg
Limited "86" Edition ... limited to only 86 SETS!
front spring rate - 8kg
rear spring rate - 6kg
Old 07-11-2012, 03:06 PM   #108
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Got you some more numbers to fill in on your chart:
Tein mono-flex coils part number:
GSQ54-F1SS1
HKS coil MSRP:
$2,250.00
Cusco Street Spec A:
Front Height Adj Range -5~-35mm
Front Spring Rate 4.5k
Rear Height Adj Range -10~-50mm
Rear Spring Rate 5k
Cusco Street Zero A:
Front Height Adj Range +25~-35mm
Front Spring Rate 5k
Rear Height Adj Range +25~-50mm
Rear Spring Rate 5k
Has pillow ball F hard rubber rear
Rear Height Adj Range +10~-65mm
Rear Spring Rate 5k
Has pillow ball Front and Rear (higher price)
denkigrve is offline   Reply With Quote
Old 07-11-2012, 03:30 PM   #109
DarrenDriven
NW Region Moderator
Awesome, thanks. Updated the list.
Old 07-15-2012, 12:02 PM   #110
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
Powerhouse Amuse has opened up their parts site. They have coil-overs listed as 8k/8k. I can't read Japanese so I can't determine the drop height range.
Source: http://www.webamuse.co.jp/86/parts.html
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 07-15-2012, 07:33 PM   #111
DarrenDriven
NW Region Moderator
Nice... added the Amuse Hi-Tech coilovers to the list.
Old 07-16-2012, 11:50 AM   #112
Racecomp Engineering
We have JRZ RS1 on our Racecomp BRZ. Spring rates are customized per order.
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 04:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 11:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 09:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 01:52 PM
