Old 12-28-2015, 02:25 PM   #99
stevesnj
stevesnj's Avatar
I used this, its called Quadlock. I made a mount out of aluminum angle and it sits low and easy to see. The install is here http://www.ft86club.com/forums/showp...&postcount=186
My 2016 Build thread
Old 12-28-2015, 02:39 PM   #100
dill916
Originally Posted by FRSBRZGT86FAN View Post
I had a oneplus one now I have a one plus two and I got a koomus magnetos when I first got the OPO :
Amazon.com: Koomus Magnetos Universal CD Slot Magnetic Cradle-less Smartphone Car Mount Holder for all iPhones and Android Devices: Cell Phones & Accessories
It may seem weird to have that sticky thing on the back of the phone but it's totally worth it
the back of the OPO is curved though so im curious how well it will stay on the magnet.
dill916 is offline   Reply With Quote
Old 12-28-2015, 04:16 PM   #101
FirestormFlex
Drives: 2015 Turbo FR-S
Phone Mounts
I've got a Scosche Magic Mount too. I wish I had discovered it years ago, I've never seen a better/faster mount from any company. Even better that it's universal.
FirestormFlex is offline   Reply With Quote
Old 12-28-2015, 05:00 PM   #102
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You can remove the back and put a metal plate back there on the OPO and the OP2.
Old 12-28-2015, 05:24 PM   #103
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
No you add a sticky plate to it I had it still on there when I sold my opo and got the OPT, or if you have a case theres a plate without any of the 3m adhesive you put in the case between the OPO
Old 12-28-2015, 05:44 PM   #104
radroach
Drives: car
@PandaBRZ
pics have a pretty strong HDR effect on
Sorry to thread jack since this is a radio with a phone mount. The radio install is clean looking when you aren't scrutinizing it. It sounds good and it worked perfectly with using google voice commands (pressing the voice button or the OK button on the remote) with my Nexus 5x.
The flaws I have with it so far.
1.) If you don't have a front power button on your phone (like iPhone or Samsung) or double-tap to wake then you might have a problem. Fortunately I can just squeeze the top bracket and it will push my power button.
2.) The unit isn't super flush, you can see it poking out. This may be due to me losing the bracket that comes with it and just using the one the shop had.
3.) A lot of the functions, like pairing phones, requires the remote. You don't want to lose that.
4.) Volume buttons instead of a knob. Always a worse choice. The buttons beep, that sucks. Maybe I'll find some settings to change that.
5.) The blue LED's are awful. I'm going to have to cover them with light dimmers: http://www.lightdims.com/store.htm
Old 12-28-2015, 06:01 PM   #105
Who8myrice
Drives: Ap2
Nice timing on the clock.
Who8myrice is offline   Reply With Quote
Old 07-15-2016, 10:19 PM   #106
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
FYI: The Scosche MagicMount and Beat-Sonic QBF13 are made using the same ball-swivel joint. You can unscrew the tightening nut on the MagicMount and the QBF13, pop the ball joints apart, and swap one to the other. Relatively pain free FRS-specific magnetic mount... and the BeatSonic QBF13 fits well over JPM Coachworks upholstered panels...
sdemo is offline   Reply With Quote
Old 07-16-2016, 06:01 AM   #107
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
To the right of the radio on the dash- velcro. I have the same setup at work so I can take my phone out of my car and toss it in my truck. No muss, no fuss.
Old 07-20-2016, 04:18 AM   #108
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Love the BeatSonic mount but cant use it atm since my dash is signed. I got the imagnet setup for my OFT and tried it on my phone with no luck thanks to a thicker case and where the magnet was but it kept slipping
Old 07-20-2016, 01:27 PM   #109
sdemo
sdemo's Avatar
somebody vandalized your dashboard with a signature and you're trying to preserve it?
Old 07-20-2016, 01:50 PM   #110
extrashaky
Drives: 2014 BRZ Limited
That's like having two stickers: +50 hp.
Old 09-27-2016, 11:52 AM   #111
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
I got a cheap 3 in 1 mount from omaker on amazon and just installed. PITA so far..but I'm concerned about suction cup damage to the dash. The plastics in the 86 are very very soft and have fading/blemishes just from regular cleaning.
Also no one has had gps/navigation interference with magnetic mounts? All the research I did came to the conclusion that magnets are still harmful to electronics.
Spacemane969 is offline   Reply With Quote
Old 09-27-2016, 03:18 PM   #112
Andrew025
Andrew025's Avatar
Magnets won't damage any modern phone.
I use mine pretty often and haven't noticed any difference in GPS function.
As long as you're not mounting a spinning drive to your magnet mount, you'll be fine...
Phone holder Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 79 04-02-2016 03:28 PM
Is it possible to use a phone as a BRZ key? Killianti Electronics | Audio | NAV | Infotainment 19 08-13-2014 04:55 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
Let's talk phone mounts l0aded Electronics | Audio | NAV | Infotainment 41 06-14-2013 12:53 PM
Phone app. DanoFA20 Site Announcements / Questions / Issues 6 10-22-2012 11:55 PM
