#99 |
Drives: Attitude
You can, but what's the point in revving the piss out of it to shift into first? You have to rev-match well and it's nigh impossible to do at speed from a cold start (sometimes I roll off my driveway in neutral). You can feel the resistance at the shift gate even when warm.
#100 | |
Drives: Skoda Yeti DSG diesel 4x4
I just don't understand why you wouldn't just change into 1st at that speed or lower rather than start slipping the clutch or come to a stop, put it itno 1st and then move off again? I understand gearboxes are tight cold, that's different. I wouldn't shift into 1st on the move when it's stone cold either. |
#101 | |
Drives: Attitude
Kinda wish cars had wet clutches like bikes... |
#102 | |
Drives: '06 AM V8V Coupe
If first gear has triple cone synchros or whatever I'd guess that it would be possible to shift into it without double clutching, but I thought first gear is usually the one with the weaker synchro? With a rev match my transmission slides into 1st just fine but the margin of error is very small compared to the other gears. But I don't have one of these cars. I think going into 1st isn't really useful when coming to a stop because 2nd gear engine brakes you down to a crawl already but it's fun to rev match :P |
#103 |
Drives: Attitude
Wet clutch? Well, you can't burn 'em up like dry clutches. Half throttle half clutch? Why not! Quick way to speed up and do several specific things, according to my very basic understanding of how a wet clutch works.
#104 | |
Cones are bad
Drives: 2013 BRZ Premium
No it's not my first manual. I learned to drive in a manual and this is my 4th car (1st RWD) all of them being a manual. I also have a class A CDL and drive big rigs with manuals. Unless I screwed something up when the trans was cold, I don't think it is me. I did notice the trans is slightly louder with the Whiteline shifter bushing. maybe that and bogging the RPMs to low caused it. It's not every time just occasionally. I have a tendency to get paranoid about these things.
#105 |
Drives: 2013 Scion FR-S MT
Synchro mesh transmissions can have issues and eventually break if you shift into first while in motion.
#106 |
Drives: 2013 Firestorm Scion FRS
FYI some guy already screwed up his gears/synchros on his FRS/BRZ by skipping gears like that.
#107 |
Drives: '15 STi Ltd
I still don't understand how skipping gears is going to hurt anything... assuming you let the engine rpm drop to where it should be for that particular X gear @ Y speed. Going from 1st to 4th and engaging the clutch at say 6000 rpm, then yes, it's gonna hurt... but if you let the rpm drop to (guessing here) 2000rpm it'll be fine.
You rev match to down shift (i.e. rpm blip) so does it not stand to reason that it works the other way as well? I've been skipping gears in cars for 10 plus years: Hondas, Subarus, and a bunch of Dodge Neons (one with 100k miles... gasp IT STILL RAN) with never having any inkling of an issue. Some manufacturers even build it in: anyone remember the skip-shift on Corvette/Camaro? No, not same trans but you get my point. And on a side note, I only shift into first if I'm basically stopped... never feels right if it's moving noticeably. |
#108 | |
Something from an owners manual that states something like '1st gear must only be selected when stationary. Selecting this gear while in motion can cause damage to the gearbox.' I would suggest selecting 1st while in motion may actually improve the action by freeing it up, the same as the other gears improve from new when they're tighter. |
#109 | |
Drives: BRZ, FD3S, Holden Calibra Turbo
Pretty much all new cars have suncros on first to allow for people not knowing or caring that they weren't ment to do it. |
#110 | |
#111 |
I'm gonna open a driving school for this forum...
| The Following User Says Thank You to gmookher For This Useful Post: | PNW FRS (09-05-2013) |
#112 |
Drives: Attitude
Personally, I find 5th and 6th to be VERY notchy. 6th actually offers a lot of physical resistance that I actually need to shove it into gear especially over 3.5K RPM; I'm actually concerned.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Brzce (12-09-2012) |
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 07:07 PM |
| A problem with new rules in SCCA/NASA regarding FIA seats | CyberFormula | Other Vehicles & General Automotive Discussions | 3 | 11-09-2011 09:13 AM |
| Help me track down my braking problem :( | #87 | Other Vehicles & General Automotive Discussions | 32 | 09-26-2011 12:49 PM |
