Old 03-14-2015, 11:53 PM   #99
sam69
Drives: GT 86
Originally Posted by Dipstik-sportech View Post
Also don't forget the lack of head room with the direct on ly injection. You'll soon max out the stock injectors and then where do you go?
Couldn't the port injection be retained from the stock motor some how ?
If not I'm sure there will be upgrades coming soon as more and more new WRX's get sold and people want more from them .
sam69 is offline   Reply With Quote
Old 03-15-2015, 01:09 AM   #100
Dipstik-sportech
Dipstik-sportech's Avatar
Have you ever priced direct injectors?! If you're going to go through the trouble of swapping the engine, then swapping the injection system from the old engine you might as well build the stock block, cause it will end up being cheaper. Until the fa20dit can be found in wrecking yards for like a grand this isn't really a viable option cost wise.
Old 03-15-2015, 06:21 AM   #101
Speedhead
Drives: BRZ DIT;VX220 T;'85 Silvia S12 FJ20
Speedhead,
You said, "Plus what you shouldn´t forget, the std. FA20D can be sold also, so some $ refund possible. But let´s speak about costs later when the exact kit extent/cost is confirmed"
I'm curious. Can you give us an idea when this might be?
Cheers,
Budo
@ Budo,
target is to have the complete kit and prices setup within the next 2 months.
Also it´s not decided yet, if the kit will be sold directly, or through regional exclusive dealers, which complicates the topic a bit initially.
@ Dipstick,
Thx for the justified question!
As a Motec M142 is used here, there is already a pre-programmed secondary injection function.
The only thing you´d have to do then is to add port injectors, resulting in a superior injection combo (bigger DI system) and stronger hardware compared to the FA20D.
It can be done e.g. by simply adding port injectors "runners" instead of the OE TGV units, which the DIT engine has, so not even a new manifold would be needed!
BTW the Motec M142 will also be available for the WRX soon
Speedhead is offline   Reply With Quote
Old 03-15-2015, 06:32 AM   #102
Speedhead
Oh, and additionaly there si still the option for a higher pressure DI pump version, which is common to be done in motorsport enignes (e.g. WRC, WTCC).
The stock system finishes at 16 MPa (=160 bar) as the relief valve is opening at that pressure.
Rising the pressure to at least 20 MPa (200 bar) would give substantial benefits in flow rate AND mixture generation => better knock resistance, faster flame expansion, better charge cooling inside cylinder (more filling, less knock)
But that´s some far-uture stuff, surely nothing to happen within 2015.
Old 04-04-2015, 03:31 AM   #103
Speedhead
Hi Guys,
Now news here.
SR is crazy busy with motorsport season start, so not enough resources to take care to finish off the final kit version so it can be distributed.
Will of course keep you updated!
Car btw is running all perfect.
5000+ kms done without any troubles!
Simply works like it has come from the factory
Old 04-04-2015, 06:45 AM   #104
Speedhead
Also there´s a tinynew video from a wet track drifting session:
Old 04-05-2015, 12:53 PM   #105
Speedhead
Engine Bay teaser Pic.
Can´t show all yet guys!
Please keep in mind that this is the very first prototype, so there was no focus on fancyness with regards to polished pipes or anything else.
Also EGT and EMAP Sensors still in place
Old 04-12-2015, 11:12 AM   #106
kcam86
Drives: Asphalt FR-S MT
This is definitely unique but I hate to beat a dead horse. Assuming that you can build your engine between 3k to 6k why would anyone ever do this? I just havent seen the reasoning. Ty
kcam86 is offline   Reply With Quote
Old 04-12-2015, 01:52 PM   #107
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
FA20DIT BRZ @ STOHL RACING
^ Real Reliability unless you wanna throw up 6k+ for the Cosworth kit. Mind you Cosworth kit have less torque under curve compare to factory fa20dit.
Most kits are not developed with reliability in mind.
Old 04-12-2015, 04:38 PM   #108
Dipstik-sportech
I mean I have more miles on my car than this one does and I race mine soooooooo where's your argument now? Oh and I made more power on less boost.
Old 04-12-2015, 04:50 PM   #109
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
your car isn't carbed so, it wouldn't pass inspection in California. btw, why do you care about what others do with their cars?
SuperDave is offline   Reply With Quote
Old 04-12-2015, 04:58 PM   #110
Dipstik-sportech
Why does anyone care? If no one gave s shit this site wouldn't exist. I'm trying to show that if you're not from Cali there are better cheaper more readily available options for you that preform the same or better. Is that wrong?
Old 04-14-2015, 07:08 PM   #111
Poodles
Drives: 2015 Series.Blue
Why are you comparing to a kit that hasn't really been proven while there are kits out there that have already been proven for FAR cheaper?
Not to mention DI only engines are known for being unreliable because of buildup on the back of the valves.
Doubtful that this engine swap would pass carb at this stage as well, so what's the point?
Old 04-15-2015, 12:51 AM   #112
SuperDave
SuperDave's Avatar
actually it would pass carb if its stock,which it is. also the newer di vehicles have a natural "catch can" system built into it to defeat the carbon valve problem. i dont have a link to it but the patent was discussed on this forum.
FA20DIT vs FA20 D4-s? hmong337 Forced Induction 31 07-26-2020 02:11 AM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 02:15 PM
Convert NA FA20 to FA20DIT in the WRX SunkenFRS Forced Induction 21 03-15-2015 08:59 PM
FA20DIT parts glorydays Forced Induction 8 03-14-2014 05:03 PM
FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested kbye Other Vehicles & General Automotive Discussions 7 02-27-2014 09:40 AM
