#99 | |
Oh and FYI to you guys in the States that complain about the price of premium gas. Around where I live it costs between $5.50 and $6.50 a gallon!!!!!!! |
#100 | |
I can only turn right
Drives: 2014 Whiteout FR-S
#101 | |
Drives: N/A
#102 | |
Drives: N/A
It blows my mind how people would even consider putting regular in when on average premium costs what $3.00 - $3.50 more total on a full tank and that's here in Georgia where premium is .30 to .35 more a gallon. Back in Indiana it was in .10 cent increments so like $2.00 - $2.50 a tank So.... save $3.00 and possibly take a risk on your $25k investment..... some people thought processes ![]() ![]() You actually get better mileage with premium which would help offset the cost but you know I'm sure there will be arguments on that as well.. ![]() Have a good Labor Day weekend everyone! |
#103 |
Drives: 2014 FRS Raven. 2011 sti red (gone)
Anyone that thinks these motors with a 12.5:1 compression ratio can run right on anything less than 91 is sorely mistaken.
They already pull out timing on 91. They really need 93 |
| The Following 2 Users Say Thank You to Kuros For This Useful Post: | billwot (08-29-2014), mweidner311 (09-02-2014) |
#104 |
| The Following User Says Thank You to Tcoat For This Useful Post: | mweidner311 (09-02-2014) |
#105 |
Drives: waiting on a 2021...
And yet Mazda runs 1/2 a point higher compression in their Skyactiv motors on 87 octane. People are running boost on 93 octane. I think direct injection and variable valve timing lets you get away with a lot more in regards to cylinder pressures vs. octane ratings. Of course, tuning one of these motors for 87 octane would lose a little power, but I think it could be done easily. I wouldn't, but I don't see any technical difficulties in doing so.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#106 |
Drives: BRZ Pearl White
The fuel pump is not lubricated (gas is not a lubricant, diesel is).
Fuel cools the fuel pump. How important this is depends on the fuel pressure system fitted. Formerly, fuel pressure regulators returned excess pressure to the fuel tank, heating up the tank. I'm pretty sure all DI systems do not do this but circulate any excess pressure in a loop within the engine compartment. Fuel pump cooling isn't an issue with the systems that circulate fuel within the engine compartment as opposed to those that return excess (and very hot) fuel to the tank. Older designs would kill their in tank fuel pumps if you persisted in running the tank down low. Later designs could care less. The exact amount of fuel remaining when the fuel pump can no longer pick up enough fuel to deliver required line pressure varies from design to design. Certainly there is no fuel pump in any car that can completely empty the tank but it is feasible to get down to half a litre or so remaining which is a lot less than remains when that low fuel warning light illuminates. On cars with a range to empty display you can always drive for quite some distance with the range to empty reading zero. |
#107 | |
Drives: FR-S 6MT
The gasoline does indeed lubricate and cool the fuel pump internals. Gasoline is refined oil.. All one has to do is feel a drop of gasoline between your fingers to know its slippery oil that also lubricates.. But you go right on convincing yourself otherwise... I doubt anyone else Finds any truth or value in your imaginary musings.. |
#108 | |
The skyactive motors run MUCH less timimg. MUCH less. |
#109 |
Generally speaking, the less total ignition timing you have to run the more efficient the combustion chamber design is, and the more power you'll make. If you could come up with a way to ignite all the fuel/air mixture at once(microwaves?), you could set the timing at TDC. We'll, maybe a degree or two before TDC to keep the connecting rods loaded against the crankshaft. I seem to remember Pro Stock motors from 10 years ago were only running around 10-12 degrees BTDC, due to the combustion chamber being so well designed.
#110 | |
Shriveled Old Member
Drives: 14 Hot Lava FR-S
Then those awful lefties created CARB, the California Air Resources Board. It established restrictive, unreasonable, and unreachable goals regarding tailpipe emissions. There were two, distinctly different, responses to this: 1) Detroit bitched and moaned about unreasonable demands put in place by politicians who didn't understand the realities of how engines worked. The best they could do was to reduce compression ratios, building 350 cubic inch V8 engines that made something like 120 horsepower. They tacked on all kinds of half-assed contraptions like air injectors that would enable unburned fuel to finish burning in the exhaust manifold. They declared the Death of the Muscle Car and blamed it on California. 2) The Japanese sunk a small fortune into R&D to understand what was going on in the combustion chamber. If Detroit was building engines based in 1930s technology (two valves, push rods, combustion chamber architecture based on what was easy to manufacture), they decided to see if things couldn't be better. If engine performance was based on better breathing, why not adopt 4 valve technology that showed up in WWII vintage fighter planes and PT boats? They discovered that proper combustion chamber design gave massive dividends-- not only did it create less pollutants, it GAVE MORE HORSEPOWER. So engines could be smaller, cleaner, more fuel efficient, and more badass. Detroit struggled to make 50 horsepower per cubic inch. Japan made 100 horsepower per cubic inch the norm. I'm struggling to see the downside... The end result, obviously was that people bought literal shiploads of Japanese cars while Detroit cranked out the same old $#!+ at faster and faster rates, creating huge problems with quality and reliability. They came -this- close to shooting themselves dead before realizing that they needed to step up to late 20th century technology and stop doing the same stupid things and hoping that their customers wouldn't notice. Goodbye points ignition and carburetors and a careless approach to weight management, hello fuel efficiency and effective engine design and actual engineering. The result can be seen in your driveway. So stop looking to Rush Limbaugh for your answers, and embrace actual facts and engineering and physics. Those ignorant lefties gave you a car that's better than, say, a '63 Ford Falcon. Last edited by FlamingRectumSyndrome; 08-31-2014 at 04:25 AM. |
| The Following 3 Users Say Thank You to FlamingRectumSyndrome For This Useful Post: |
#111 |
Actually 4 valve per cylinder (SOHC & DOHC) engines have been around as long as pushrod motors have. Several European makers had DOHC 4 valve motors as far back as the early 1920's, not to mention Duesenberg & Offenhauser both used this configuration in their cars before WW II. Many of the European companies used this configuration in their cars throughout the 50's & 60's. I will say the Japanese are good at refining existing technology. Insert something about "standing on the shoulders of giants" here.
#112 | |
I have a vision of Castrol engineers rubbing gasoline between their fingers and nodding sagely among themselves: "you know, this stuff would make a great lubricant, wonder why nobody else thinks so". Don't give up your day job in hopes of getting a job as a lubricant engineer, well, automotive lubricants anyway. I can think of one line of lubricant testing where your expertise might come in handy. That rock over there is calling out your name: "come home...come home". |
| Tags |
| uberstupid, use premium!, you can't fix stupid |
| Premium gas, or? | NotlocTRD | Scion FR-S / Toyota 86 GT86 General Forum | 151 | 09-27-2017 03:56 PM |
| FRS arrival for regular customers question | NWIguy | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 05-05-2012 09:54 AM |
| Anyone have a pic of the regular seats? | DuMa | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 12-14-2011 01:29 AM |
| So is it a hatch or regular trunk? | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 12-09-2011 08:26 PM |
| Consequences to Adding Regular Gas? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 12-06-2011 01:52 AM |
