Old 08-14-2014, 05:55 PM   #99
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by yomny View Post
Can this header be installed tune only with a stock exhaust. Would the header match the stock overpipe?
Yes, our header will bolt-up directly to the two-bolt flange on the stock over-pipe.
- Toan
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
Trefoil (08-30-2014), yomny (08-15-2014)
Old 08-14-2014, 05:59 PM   #100
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Originally Posted by ptuning View Post
We're considering potentially building a 2.5-2.75 inch header/over-pipe/front-pipe combo using the v-band that we have in place with our header. We may also look into creating a competitive SCCA STX Class tuned power package with a lightweight single exhaust system too.
- Toan
yes please?!
G-Man is offline   Reply With Quote
Old 08-14-2014, 06:01 PM   #101
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by Alita View Post
i really want to know what this header sounds like!
also... how do i make my car street legal in VA if i were to have this installed...
You'll likely need to just avoid Fairfax County. Seriously though, you will need to run a resonated or muffled mid pipe and large muffler(s). A catted front-pipe will help keep you legal in terms of having a cat in place too.
- Toan
Old 08-14-2014, 06:02 PM   #102
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by G-Man View Post
yes please?!
Old 08-14-2014, 06:14 PM   #103
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
"We'll likely offer an optional stainless steel puzzle piece header heat shield system later on down the road."
Would love more info on this for us California drivers.
Originally Posted by humfrz
I'm old and lazy
Old 08-14-2014, 06:20 PM   #104
jdmblood
jdmblood's Avatar
Drives: white subaru brz
really love how you guys are focusing towards those of us who wants to do more of an n/a build. its greatly appreciated.
jdmblood is offline   Reply With Quote
The Following User Says Thank You to jdmblood For This Useful Post:
ptuning (08-14-2014)
Old 08-14-2014, 06:20 PM   #105
buddy32
Drives: WRB Subaru BRZ Limited
Our intention was to dyno test our header with an exhaust system that we had on hand. We're considering potentially building a 2.5-2.75 inch header/over-pipe/front-pipe combo using the v-band that we have in place with our header. We may also look into creating a competitive SCCA STX Class tuned power package with a lightweight single exhaust system too.
- Toan
Haha, that was one of the future questions coming along. Has someone asked for a single exit turbo setup with all this in place. I'm pretty sure I read that you guys tested the single and dual exit and didn't find a significant flow difference, correct?
buddy32 is offline   Reply With Quote
Old 08-14-2014, 06:43 PM   #106
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by Celigts View Post
Wait...The FA20 has vvti/vvtli? My 03 celica had this...and at like (if my memory serves me correct) it gave a power boost at around 5k rpm...This isn't seen in the frs...least it doesn't feel the same. Felt like a mini turbo kicked in. I'm confused...
We might not have variable lift, but sure have a nice torque dip to make it feels like it has Mini-vvtil. Haha
Old 08-14-2014, 06:44 PM   #107
ptuning
ptuning's Avatar
Drives: White FR-S
The idea would be to make a heavy gauge stainless steel plate or possibly even inconel that bolts between the header and engine/cylinder head to reduce radiant heat onto the engine. We would also make a piece(s) to position above the header to reduce underhood heat as well. The pieces would help to sort of encapsulate the header and allow for better heat retention. Basically the same way factory headers and exhaust manifolds are done. Maybe we could also stamp Subaru on the upper piece to help out the Cali folks. BTW, kinda, sorta kidding on that last comment.
- Toan
The Following 5 Users Say Thank You to ptuning For This Useful Post:
cactus (03-24-2015), chaoskaze (10-13-2014), Clipdat (08-14-2014), Sellout (09-13-2014), Simpleviet (02-18-2015)
Old 08-14-2014, 06:50 PM   #108
ptuning
ptuning's Avatar
Drives: White FR-S
Generally speaking, you would expect a single exhaust system to outperform a dual (BTW, I'm referring to a typical 4 cylinder platform like this where the dual split occurs behind the rear axle). However, due to the design layout of our dual exhaust system, we've managed to make the same power with our dual exhaust system when configured in single exhaust mode.
- Toan
Old 08-14-2014, 06:50 PM   #109
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sorry guys, back on topic now.
To answer the questions posted about sound. We'll have a dyno video clip posted by tomorrow. Our header and 3" header-back exhaust system, as is, will definitely be loud. We would have performed a sound level test using our db meter, but I think that this combination will be too loud for most owners.
We'll test our header with a 2.5" over-pipe and front-pipe when we get our first local customer cars in for installation and dyno tuning with the header. I honestly don't foresee any major power differences to our 3" test set-up.
- Toan
What do you think about running 3 inch back to the axle, where the gasses have likely cooled somewhat then stepping down to ~2.5 inch for the mufflers? Could a set up like that keep the best aspects of both worlds, allow you to stock fewer parts, and allow easier upgrades later? Or would it still be too loud?
Old 08-14-2014, 07:06 PM   #110
ptuning
ptuning's Avatar
Drives: White FR-S
I don't think that would be such a bad idea. I think an efficient header, over-pipe, front-pipe combo that can bolt-on to an existing 2.5" cat-back exhaust system may be just the ticket for getting the best of both worlds in terms of performance and sound. I think a 2.5" mid-pipe would probably be fine too.
Sometimes I wish we had more than 3 shop FR-S' for testing with. Only one is NA at the moment.
- Toan
Calum (08-14-2014), Turdinator (08-14-2014)
Old 08-14-2014, 11:16 PM   #111
Alita
Alita's Avatar
Drives: 2015 Subaru BRZ Series.Blue
- Toan
i live in fairfax >.<
i'm running a resonated 3" Perrin catback, and 2.5" Perrin overpipe.
just how much louder does this header make things? can i stop down and listen to it?
^ Click for build thread ^
Alita is offline   Reply With Quote
Old 08-15-2014, 12:12 PM   #112
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
See, I know you guys said no UEL because you focus on performance, but an argument can be made that if you guys did make a UEL it would be the highest performing UEL on the market. So, that's something.
Either way, those are some gorgeous numbers. If I wanted EL this would be tempting...
Nevermore is offline   Reply With Quote
The Following 2 Users Say Thank You to Nevermore For This Useful Post:
ptuning (08-19-2014), Silent_Dan (08-15-2014)
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 08:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 10:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 06:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 11:17 PM
