Old 02-16-2015, 12:11 AM   #99
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Schroth Rallye 3 harnesses ordered. I also order Speedhut Revolution Gauges. I think the Prosport Evo Gauges would have looked better, but I know the quality can be a bit off. They are saying about 2-3 weeks for the gauges to be shipped.
I plan on going back to my stock seat for awhile as well. It will get swapped out when the Harnesses go in. I am getting tired of the creaking from the seat. I also need to sit up a little bit taller(being short sucks). I will save up for a set of Blue Brides in the future. I need to start saving for the engine rebuild/manual swap on the 9-5 :/. I also want to start paying the FRS off early.
Edit: So we got hit with a crazy snow storm and because they didn't start salting till very late, I couldn't drive the FRS home from work. So I had to get a ride home and get the old land cruiser running:
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Jrryjms07 (03-27-2015)
Old 02-17-2015, 01:04 PM   #100
DustinS
DustinS's Avatar
This was the view yesterday morning(battery working). Went out last night after work only to find the battery Completely dead. Due to my work scheduled I won't have time to jump it and let it run before having to go back to work. So I am thinking about upgrading to a smaller battery. I have heard people going to Lawn and garden battery, which I may do. I was also looking at Miata batteries. The are AGM and somewhat small.
Driving my saab in the mean time:
Old 02-19-2015, 03:32 AM   #101
DustinS
DustinS's Avatar
Found out the tires do NOT like snow/slush.
I also accidentally left my OFT plugged in a killed my stock battery, no better time to upgrade.
Miata battery ftw.
Girlfriend grabbed this on the way out of the parking lot. Super Glad everything was dry so I could get her home
The guys that helped push my car into that place in the first picture must have ripped my spoiler off and didn't say anything. It flew off shortly after the last picture was taken and my girlfriend almost ran it over. It will need new paint.
but she made it home:
Harnesses come in tomorrow, and the gauges are currently at the "Art Department". Can't wait for those to come in.
[ame="https://www.youtube.com/watch?v=aTd0g2AWAaI"]Cold Start with the new Battery[/ame]
edit: May have an awesome project coming up with the rear quarter windows + LED's + mirrors. I really hope it turns out.
Old 02-19-2015, 11:23 PM   #102
DustinS
DustinS's Avatar
Can't wait to get these installed.
Old 02-26-2015, 12:06 PM   #103
DustinS
DustinS's Avatar
Went to St. Louis to pick up some WRX wheels for winter.
They almost fit over the Wilwoods(need 20mm spacer). Seems the corner of the outside brake pads sits up and rubs the wheel. I am going to touch it up a bit and see if that fixes it. If I could run these brakes that would be the best. I really don't want to have to switch back to stock bakes for the last month or so of winter.
Got the harness in on the passenger side. It still needs some tweaking. Just need to finish the driver side.
Old 02-27-2015, 11:36 AM   #104
DustinS
DustinS's Avatar
STI Rotor with Wilwood superlight caliper will fit under a 16" WRX Wheel(Slight modification needed).
I also filled up with e85 in St. Louis and the minimum is 70% ethanol, compared to the 50% here. My car started no problem with the e85 here, but will barely start with the e85 from STL. This is my first time have problems starting with e85 in winter. Takes 10-15+ crank overs to sputter to life. I am most likely going to switch back to 93 tune for the rest of winter. The Miata battery is holding up well. So that will likely stay.
Old 03-02-2015, 12:30 PM   #105
DustinS
DustinS's Avatar
The rear end is sagging due to the extra 200lbs of gravel in the trunk.
This pretty sums up the 100 Acre Wood Rally. I unfortunately had to leave after the first stage on Saturday. Took a hour and a half to make it the 27 from Salem to Rolla before a crazy wreck had us staying at a hotel. Glad we did, the roads took many more cars that night, all while my car was parked safely for the night.
Lesson I learned from this years. I need to get new snow tires for next year, these last minute very used set I grabbed (while doing okay, were still very sketchy at times) weren't enough. I also need to raise the car. I plan on going stock suspension with 1" lift kit. Still deciding between some Nokian Hakka R2/ Hakka 7 or General Grabber AT2.
Old 03-10-2015, 12:01 PM   #106
DustinS
DustinS's Avatar
Luckily my one day off work for the week is looking to be the warmest/not rainy. So I am hoping to get quite a bit done tomorrow. I am going to paint and re-install my bumper beams, do a good wash/wax, interior cleaning, stock seat back in?, clean wheel wells/suspension of all the road grime and salt, and possibly paint the calipers(They have some bare spots due to sanding to get the 16's to fit.)
Old 03-12-2015, 01:14 PM   #107
DustinS
DustinS's Avatar
Well I didn't get anything other than Washing/waxing her. I also got the interior wiped down. She does look gorgeous though!
I also got my gauges in the mail. I can't wait to get them installed:
jcw99 (01-13-2017)
Old 03-26-2015, 01:04 PM   #108
DustinS
DustinS's Avatar
Wing was sent to the Painters, not sure when it will be back, but I'm not too worried. Also got some pictures with the Storm we got yesterday:
Storm Pictures by Dustin[Smith], on Flickr
The Following 2 Users Say Thank You to DustinS For This Useful Post:
djdnz (07-18-2015), REAV3R (04-15-2015)
Old 03-30-2015, 12:10 PM   #109
DustinS
DustinS's Avatar
Got the gauges installed:
My good friend owns a machine shop and makes 02 bungs from stainless, and they just so happen to be the same thread as the galley plug. So instead of waiting to get one shipped, he drilled and tapped the center. Looks sweet, and always up for supporting a local business.
The Blue isn't exact, but I love it anyway.
Old 04-15-2015, 07:40 PM   #110
DustinS
DustinS's Avatar
Went ahead and bit the bullet. I pulled the stock tails off and cut them open. I am currently waiting on the second trim piece to dry before I put it back together. The RTV is taking way too long to dry (or maybe I am just too impatient).
I am also hoping to order the SBD Turbo kit here within the next week.
Old 04-15-2015, 08:04 PM   #111
REAV3R
Former Boost Junkie
REAV3R's Avatar
Drives: Ultramarine FR-S
Originally Posted by DustinS View Post
Wing was sent to the Painters, not sure when it will be back, but I'm not too worried. Also got some pictures with the Storm we got yesterday: Storm Pictures by Dustin[Smith], on Flickr
Nice photos; good looking car!
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." ~ J.Clarkson
REAV3R is offline   Reply With Quote
The Following User Says Thank You to REAV3R For This Useful Post:
DustinS (04-15-2015)
Old 04-15-2015, 10:49 PM   #112
DustinS
DustinS's Avatar
Thank You!
On another Note. The paint on the taillights scratched when putting them back together -_-
So Taillights will be the next purchase after turbo kit.
Edit: Payment for the turbo kit has been sent. The wait is going to kill me. It's the largest sum of money I have spent on one thing(besides my cars, heck my 9-5 only cost me 3k). So it has me sketched out a bit.
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 11:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 12:43 PM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 06:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 01:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 03:50 PM
